Local Time 17:44 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Redirecting Text Output
PilotPirx
Posted: 06:50am 22 Oct 2026
Hello,
Is it possible with MMBasic to redirect text output, such as OPTION LIST, to a COM port? (PRINT #1)?
I have a printer connected to COM1 and would like to print OPTION LIST.
Posted: 10:12am 22 Oct 2026
I don't know, it's not something I've ever wanted to do. I can't think of a way to do it directly from the Pico. OPTION LIST is a console command and displays on the console. Anything that is normally sent to a COM port is from the user's program.
PilotPirx
Posted: 12:18pm 22 Oct 2026
I can print a screen dump, but then I have too much white space on the printout.
Martin H.
Posted: 12:29pm 22 Oct 2026
how about
option console serial
  Quote  OPTION CONSOLE output
Specifies where print statements will output. Valid settings are BOTH (i.e.
SCREEN and SERIAL), SERIAL, SCREEN, NONE. This is a temporary
option that is reset when a program exits.
Edited 2026-10-22 22:30 by Martin H.
'no comment
Posted: 12:40pm 22 Oct 2026
  PilotPirx said  I can print a screen dump, but then I have too much white space on the printout.
Maybe I my memory is confused, but before the WYSIWYG age printing ALWAYS wasted paper before you got it right.
Apple fixed it with the MAC, and soon after that Windows.
ville56
Posted: 01:02pm 22 Oct 2026
PilotPirx,
you could try MMCC start/end capture. Everything that prints to the serial console can be captured and processed later, no matter how long the output is (more or less). Very handy IMHO and often used to  document output.
Gerald
73 de OE1HGA, Gerald
PilotPirx
Posted: 01:03pm 22 Oct 2026
"option console serial" uses COM3, but i use COM1.
You can redirect it with OPTION CONSOLE PORT 1, but this causes a reset and its permanent. Thats not a good solution.
PilotPirx
Posted: 01:05pm 22 Oct 2026
  Quote  Maybe I my memory is confused, but before the WYSIWYG age printing ALWAYS wasted paper before you got it right.
That's true...
Posted: 01:38pm 22 Oct 2026
Patient: "It hurts when I do this, Doctor."
Doctor:  "Don't do it then. Next please!"
Posted: 08:46pm 22 Oct 2026
  Quote  before the WYSIWYG age printing ALWAYS wasted paper before you got it right.
Off topic, but with 3D printers history repeats.
