Local Time 17:57 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Patched Webmite 6.04.00RC1 WeAct RP2350B Wifi
Gerad
Posted: 04:12pm 05 Oct 2026
“WebMiteRP2350V6.04.00RC1_RM2.uf2 file fixes the Wi-Fi problem.  See Patch Report.
It works with WeAct & RM2 and Pico2 W. Not with Waveshare RP2350B-Plus-W.
Manual, page 81 describes  the Problem "With some routers it can take some time or a couple of attempts to connect, so if you are using OPTION
AUTORUN ON, it would be worth inserting something like this at the very start of your program:
DO WHILE MM.INFO(IP ADDRESS) = "0.0.0.0"
IF TIMER > 5000 THEN CPU RESTART
LOOP
This would wait 5 seconds for a connection and restart
if still not connected."
WebMite_RP2350B_RM2_WiFi_Patch_Report.pdf
WebMiteRP2350V6.04.00RC1_RM2.zip
Edited 2026-10-06 02:20 by Gerad
Posted: 04:45pm 05 Oct 2026
I will analyse this further but, for the avoidance of doubt, this is a Fritzbox specific issue or at least I'm not aware of any reports on a non-Fritzbox router.
I can type cpu restart forever on my network and it will always re-connect.
I'm unclear why the patch limits to rp2350 only as presumably the rp2040 has the same issue?
Gerad
Posted: 05:06pm 05 Oct 2026
I'm having the same problem with the RP2040, which is why I'm using a “do while...” loop. Maybe it's a “Fritzbox” issue. But in Germany, that's pretty much the norm. Still, after 2–3 connection attempts, the connection is established.
Edited 2026-10-06 03:30 by Gerad
Posted: 05:47pm 05 Oct 2026
I will implement the retry code but not the soft reset change.
It isn't safe when called from an interrupt.
SoftReset() is called from the 1 ms timer callback, for the WATCHDOG timeout and the hang-detection timer (PicoMite.c:2433, PicoMite.c:2439).
cyw43_arch_deinit() must not run from an interrupt: the SDK's own check panics there (async_context_poll.c:49).
In a release build that check is off. The network stack is then shut down from inside an interrupt that may have arrived in the middle of a network call.
If that crashes, the hardware watchdog hasn't been started yet, so the board hangs instead of restarting. WATCHDOG exists to get a stuck board running again, and this would make it hang.
In any case, the driver already does this: every cyw43_arch_init() drives WL_REG_ON low for 20 ms, then high, then waits 250 ms (cyw43_bus_pio_spi.c:360).
dddns
Posted: 05:51pm 05 Oct 2026
  matherp said  I will analyse this further but, for the avoidance of doubt, this is a Fritzbox specific issue or at least I'm not aware of any reports on a non-Fritzbox router.
I have seen the same behavior as with a Fritzbox with an ESP01S module running ESP-Link acting as AP.
Gerad
Posted: 07:25pm 05 Oct 2026
Peter
Of course, you're absolutely right. That was just some leftover software from when I was trying to figure out why the connection wasn't working. It's been removed in "WebMiteRP2350V6.04.00RC1_RM2_V1.uf2"
WebMiteRP2350V6.04.00RC1_RM2_V1.uf2.zip
WebMite_RP2350B_RM2_V1_Technical_Report.pdf
maxwelloau
Posted: 05:16am 06 Oct 2026
While this may be an unrelated or another modem problem (either way extremely minor in my opinion) it is closely related to what is being reported (I think). This is provided just for extra information, but happy if you disregard it!
I have observed that once wifi is connected its 100% bullet proof. On every CPU RESTART it always fails the first wifi connection. A cpu restart is initiated anyway, and wifi connection always occurs on the 2nd attempt.
Equipment.
TPlink DECO X50 mesh unit 2.4 wifi and 5 wifi (pico mac address is configured to use only 2.4 wifi and only the closest unit, and mesh is disabled for this mac address.
RP2350 Pico 2W genuine, configured with static IP details AU.
In the main router DHCP server, the mac address will only use a reserved IP address, 192.168.1.200. (same as the static IP in the Pico, tried both ways, same result).
Doing a WEB SCAN after the first boot and after the second boot there is a huge difference in reported WIFI strength. I have observed the connection quirk over all V6 and V7 firmware. Is this a firmware or an internal module hardware timing thing I ask myself, with very little actual knowledge in this area!
--------------------MMCC logging---------------------------------------
14:53:23] finished     3844   (running program, total # pings since WIFI restart)
[14:53:28] > CLEAR
[14:53:33] > CPU RESTART
[14:53:37]  14:53:37 Port: COM5 removed
Disconnected
14:53:38 Port: COM5 inserted
Connected to COM5 at
PicoM connecting to WiFi...
[14:53:44] failed to connect.
[14:53:54] Timeout - Reboot
[14:53:55]  14:53:55 Port: COM5 removed
Disconnected
14:53:55 Port: COM5 inserted
[14:54:01] Connected 192.168.1.200
[14:54:11] Reply from 1.1.1.1: seq=1 time=11.648ms
[14:54:11] Ping statistics for 1.1.1.1: sent=1 received=1 lost=0 average=11.648ms
[14:54:11] finished     1
[14:54:21] Reply from 1.1.1.1: seq=1 time=11.958ms
[14:54:21] Ping statistics for 1.1.1.1: sent=1 received=1 lost=0 average=11.958ms
[14:54:21] finished     2
[14:54:24] >
------WEB SCAN after connected + then WEB SCAN before connected-----------
[15:07:56] Connected 192.168.1.200
[15:07:59] >
[15:07:59] >
[15:08:00] > web scan
[15:08:03]
[15:08:03] Performing wifi scan
[15:08:03] ssid: tweedle                          rssi:  -40 chan:   8 mac: b0:19:21:3c:3f:86 sec: 5
[15:08:03] ssid: tweedle_Guest                    rssi:  -40 chan:   8 mac: ba:19:21:3c:3f:86 sec: 5
[15:08:03] ssid: tweedle_IoT                      rssi:  -41 chan:   8 mac: be:19:21:3c:3f:86 sec: 5
[15:08:03] ssid:                                  rssi:  -71 chan:   8 mac: b6:19:21:3c:3f:82 sec: 5
[15:08:08] > cpu restart
[15:08:09]  15:08:09 Port: COM5 removed
Disconnected
15:08:09 Port: COM5 inserted
[15:08:15] failed to connect.
[15:08:16] > web scan
[15:08:19]
[15:08:19] Performing wifi scan
[15:08:19] ssid: tweedle_Guest                    rssi:  -84 chan:   5 mac: ba:19:21:3c:6e:8a sec: 5
[15:08:19] ssid: tweedle_IoT                      rssi:  -86 chan:   5 mac: be:19:21:3c:6e:8a sec: 5
[15:08:19] ssid: tweedle                          rssi:  -72 chan:   8 mac: b0:19:21:3c:3f:82 sec: 5
[15:08:20] ssid:                                  rssi:  -38 chan:   8 mac: b6:19:21:3c:3f:86 sec: 5
[15:08:25] >
ville56
Posted: 06:56am 06 Oct 2026
Interestingly all APs have different channels after reboot. I think they should be the same except they all have repeaters for their SSIDs. Then this may happen but is strange anyway as there are big differences in the RSSI values before and after reboot. Don't know what the PRI RF hardware is capable (automatic attenuators?)
73 de OE1HGA, Gerald
maxwelloau
Posted: 10:53am 06 Oct 2026
Wow a blinding fast change to test. I believe it is heading in the right direction Peter.
After FW update to 7.0b6, first load, no wifi, 2nd boot wifi ok.
Amended the basic program to perform the ping, wait then do a CPU RESTART.
Now 50% average result. That is, after a reboot where wifi is good, 2nd reboot is failed.
On a DC power cycle first boot seems to always fail, then ok on the next RESTART.
Again I caution that nothing else is affected by the change, and this quirk is not taking valuable time from something else.
Due to the short cycle I noticed not accepting incoming pings!
Modified basic to
ping out, wait 10 seconds. Repeat this 4 times. (total 5 pins out)
Then CPU RESTART.
Even with this it works like a toggle switch on CPU RESTART! wifi connection, wifi fail, wifi connection, wifi fail.
Ping incoming slow to work, taking 3.5 to 5 periods.
Hope this is useful but it is ok to tell me where to go, what to do too!
Maxwelloau.
ville56
Posted: 03:41pm 06 Oct 2026
Compared to the actual release V7.00.00 RC6 there is no change in the behaviour at network connect in a wifi network controlled by a Fritzbox router. Every 2nd time it reliably fails. Maybe the network connect should have a retry counter with, say, 3 retries. Otherwise we will have to stay with the already proven solutions. They are IMHO not beautiful but at least they work.
WEB SCAN is not delivering reliable results at all. The scan periode seem to be too short to list all networks available at any given time.
The RSSI values do vary abt 10 dB here, which is IMHO acceptable. As the internal circuitry for measuring the RSSI and the level control is probably not very sophisticated and results may be rather coarse.
Gerald
Gerad
Posted: 05:02pm 06 Oct 2026
9. Detailed patch behavior
Initial result value: connect_result is initialized to PICO_ERROR_CONNECT_FAILED only so it has a
defined value before the loop. Each loop iteration immediately replaces it with the real join result.
Maximum of three joins: rm2_attempt runs from 1 through 3. This matches observed behavior on
similar WebMite systems where two or three attempts can occasionally be required.
Success path: If the join returns 0, the loop exits immediately. The original WebConnect() success
logic then continues unchanged: WIFIconnected is set, LastWifiErr becomes 0, and TCP/TFTP/UDP
services are opened as configured.
WebMite RP2350B + RM2 - RM2 V1 | 6
Selective retry: A retry happens only when connect_result equals PICO_ERROR_CONNECT_FAILED.
Authentication errors and other error classes are not blindly retried.
One-second settle interval: Between failed -8 attempts, cyw43_arch_poll() is called 100 times with
10 ms between calls. This lets the polling-based CYW43/lwIP context process pending work instead of
simply sleeping.
Final failure behavior: If all three attempts return -8, or another non-retriable error occurs, control
falls through to the original WebMite failure handling. The patch does not bypass or replace the
existing error logic.
Posted: 05:25pm 06 Oct 2026
Sorry, but I am not making any more changes. Web connection is completely reliable for most people and I can't remote diagnose specific local issues. Previously changes went in which fixed Jim's Fritzbox issues and I have added the retry loop for -8. That is it. Anything else will have to be coded individually in Basic
Gerad
Posted: 07:23pm 06 Oct 2026
I have two FritzBoxes on my network. I no longer have any connection errors with WebMite. With ESP (Arduino), I also use three connection attempts. Everything works.
