Local Time 18:10 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.03.02 betas
     Page 1 of 7
Posted: 08:54am 25 Aug 2026
V6.03.02b0 is available at https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.02b0
This include a big change I have been wanting to do for ages - single element arrays. WHY?
Single_Element_Dimensions_Briefing.pdf
In addition there a bunch of small bug fixes.
Please try existing programs on the new release. In theory the change shouldn't have broken anything but....
Report any issues on this thread - thanks
Posted: 12:47pm 25 Aug 2026
If the program in memory gives some odd errors after the update reload it from source.
There may have been some token changes.
Eg Backlight becomes CtrlVal( .
javavi
Posted: 03:19pm 25 Aug 2026
@matherp
Hi Peter,
Is it possible to make the COLOR MAP(N) command work in MODE 1 to set the current PRINT and TILE color?
It's much more convenient to programmatically specify the available 16 colors as numbers than as RGB(255,255,255) constants, which are still converted to the same 16-color (4-bit) code for tiles.
ville56
Posted: 05:15pm 25 Aug 2026
Peter,
WEB PING seems to have a problem with DNS names, plain IP works ok.
> web ping "router-1"
Error : ping dns request failed
> web ping "192.168.0.254
Reply from 192.168.0.254: seq=1 time=2.612ms
Reply from 192.168.0.254: seq=2 time=2.458ms
Reply from 192.168.0.254: seq=3 time=1.650ms
Reply from 192.168.0.254: seq=4 time=3.882ms
Ping statistics for 192.168.0.254: sent=4 received=4 lost=0 average=2.650ms
Environment:
WebMite MMBasic RP2350A Edition V6.03.02b0
OPTION WIFI JN88fg, *********, Nixie, 192.168.0.162, 255.255.255.0, 192.168.0.254, AT
Gerald
Edited 2026-08-26 03:17 by ville56
73 de OE1HGA, Gerald
terekgabor
Posted: 05:27pm 25 Aug 2026
Hello Peter,
just right now I can't reach the new release on Github. (error 404)
G@bor
Posted: 05:29pm 25 Aug 2026
Link died...
update:
It is back....
Edited 2026-08-26 03:31 by Volhout
terekgabor
Posted: 05:33pm 25 Aug 2026
Yes, it is back!
Posted: 05:35pm 25 Aug 2026
Web ping works if there is a dns to resolve the name and the address accepts pings
Try
> web ping "www.geoffg.net"
Reply from 103.27.34.13: seq=1 time=284.945ms
Reply from 103.27.34.13: seq=2 time=285.355ms
Reply from 103.27.34.13: seq=3 time=284.810ms
Reply from 103.27.34.13: seq=4 time=284.881ms
Ping statistics for 103.27.34.13: sent=4 received=4 lost=0 average=284.997ms
  Quote  Is it possible to make the COLOR MAP(N) command work in MODE 1 to set the current PRINT and TILE color?
Not sure what you are asking for. COLOUR MAP works in mode 1
PicoMiteHDMIWEB MMBasic USB RP2350B Edition V6.03.02
Copyright 2011-2026 Geoff Graham
Copyright 2016-2026 Peter Mather
Total of 6 Mbytes PSRAM available
PICOCD6AC067597 connecting to WiFi...
Connected 192.168.1.79
> dim a%(15)
> dim b%(15)=(0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15)
> mode 1 ' was in mode 1 anyway
>  colour map b%(),a%()
> ? a%(1)
255
Edited 2026-08-26 03:45 by matherp
javavi
Posted: 06:28pm 25 Aug 2026
> dim a%(15)
Yes, but in other modes (2, 3) the MAP(n) function works directly without any initialization of arrays
MODE 3
For n=0 to 15: ? Hex$(Map(n)) : Next
0
80
4000
4080
8000
8080
C000
C080
800000
800080
804000
804080
808000
808080
80C000
80C080
Edited 2026-08-26 05:12 by javavi
ville56
Posted: 07:14pm 25 Aug 2026
  matherp said  Web ping works if there is a dns to resolve the name and the address accepts pings
Try
works for all non-local dns names, but doesn't work for me with local DNS names, even not if they are fully qualified like "dnsname.fritz.box"
My fritzbox IS acting as a local DNS and works with all local dns names in Windows and Linux as there are no extra entries in the hosts files. Is there anything else I could have done wrong?
Gerald
Posted: 09:23pm 25 Aug 2026
  Quote  WEB PING seems to have a problem with DNS names, plain IP works ok.
What happens if you connect with a dynamic IP instead of static?
Posted: 09:44pm 25 Aug 2026
Nothing to do with a Fritzbox merits any further discussion. They are different to every other router available and I cannot waste any more time on their idiosyncrasies
Posted: 04:57am 26 Aug 2026
I normally prefer dynamic IP but just tested with static.
My Fritz performs the same. The name is listed in the network lists but unable to use the name to connect.
With dynamic, I can Ping the mite using the name and the Fritz does do the DNS lookup.
C:\Users\Jim>ping tpico.fritz.box
Pinging tpico.fritz.box [10.1.1.53] with 32 bytes of data:
Reply from 10.1.1.53: bytes=32 time=4ms TTL=254
Reply from 10.1.1.53: bytes=32 time=1ms TTL=254
Reply from 10.1.1.53: bytes=32 time=2ms TTL=254
Ping statistics for 10.1.1.53:
   Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
   Minimum = 1ms, Maximum = 4ms, Average = 2ms
A Fritzbox can recognize a picomite on the local network, provided you use dynamic and let the fritz issue the IP.
It can reserve the desired IP making it similar to static.
fred777
Posted: 05:37am 26 Aug 2026
Hi Peter,
since your are working on the Picomite at the moment...
I would love to have a MM.ERRLINE read only variable. For those of us using a "self made" editor this would make jumping straight to the line that produced an error possible.
Cheers,
Fred
ville56
Posted: 06:03am 26 Aug 2026
  TassyJim said  I normally prefer dynamic IP but just tested with static.
Many thanks Jim for that hint !!!!
Not a friend of dynamic IPs ....
IMHO, basically all IPs in the Fritzbox seem to be dynamic. I've assigned them "quasi-static via the MAC" but outside the specified DHCP IP range. I'll try to lay the DHCP range over this quasi-static range and see if the DNS will resolve then.
Edit: bingo, the IP-address must be within the DHCP range of the Fritzbox for the DNS-request from this node TO BE PROCESSED !!!!.
I had DHCP range from 192.168.0.100 to 192.168.0.119 and the Webmite was tied down to 192.168.0.156 via the MAC address outside DHCP. This did not resolve the Webmites DNS name.
Now I've just extended the end of the DHCP range to 192.168.0.169, reconnected the Webmites and the DNS-request from the Webmite now resolves the IP for ALL OTHER NODES (inside and outside DHCP range). So only nodes with IP within the specified DHCP range can resolve local names on the Fritzbox. Strange ....
I did this seperation intentionally to keep the "static" range free from "DHCP accidents". So there would never be any address clash in the static range. Maybe I have to redesign my IP scheme now ...
Thanks again and 73,
Gerald
Edited 2026-08-26 16:40 by ville56
aaaaaaaargh
Posted: 06:07am 26 Aug 2026
  fred777 said  I would love to have a MM.ERRLINE read only variable. For those of us using a "self made" editor
+1
Yes, that would be a nice addition. I'm new to the Picomite and building my own editor is my first bigger project. The MM.ERRLINE could be passed to an editor using the function keys, is my take.
Posted: 08:26pm 27 Aug 2026
Question at Peter,
Is there anything in MMBasic that can detect a Brown out , or do we have to write that in the MMBasic program?
I am asking because I was playing with the idea of adding a supercap to Vsys, to let the pico ride through short power interrupts.
First test, running the pico (genuine pico with Buck boost converter) from Vsys is 4.6V to below 1.8v, I lost the flash content, so had to reimage. Maybe because the pico core Will run down to 1Vat the 3.3v bus, but the flash chip not.
Second test, I lost all communication with the LCD, most likely because the pico core kept running, but IO did not. So the pico did not coldboot.
It would be a real asset when the core would detect 3,3v is below 2.9, and force the arm cores into an infinite loop, or keep in reset.
Note that because the supercap this proces is slow, so big chance things can go wrong (I.e. flash write at low 3v3) But statistically this coul also happen once in a million times with the bare pico as is.
Do you have any info about Brown out detection in the pico?
P.s. I know in picomputer 3 this is solved with the 809 reset controller.
Edited 2026-08-28 06:39 by Volhout
Posted: 07:33am 28 Aug 2026
The Pico can't detect a brownout on its own. It can tell if VBUS is there, but that's a digital signal on GP24, not analogue. It can check your VSYS voltage as an analogue input on GP29 (multiply it by 2). You could use a similar potential divider and another analogue input, I suppose.
The RPnnnn does have a degree of brownout detection on chip but it's minimal and is to do with having enough voltage to run the system clock etc. It won't detect the supply voltage to external memory or the IO system voltage, of course.
El-Cheapo solution:
2of AA cells in series powering VSYS. Under normal conditions the diode is reverse biased and they will last for their shelf life. You could even use a CR2032, I suppose. A genuine pico will run for ages off 2x AA. :)
Edited 2026-08-28 17:38 by Mixtel90
Posted: 12:13pm 28 Aug 2026
Hi Mick,
Your solution is one of postponing. The AA cells will in the end also deplete, with same result.
I think an external reset switch at 3V3 should do the task. The pico has (indeed) nothing for this. Only for brownout of 1.1V DVDD. Since pico has the buck boost switcher, checking GP29 is not much use. For a pico zero, with LDO, it could make sense.
Edited 2026-08-28 22:15 by Volhout
Posted: 12:58pm 28 Aug 2026
The AA cells weren't intended to be taken too seriously. :)
I'm still not sure about a supercap. If its voltage drops to the "grey area" for any reason the pico can get in a knot, shut down and - importantly - can't be restarted until the cap is discharged a long way or is disconnected. You may need a much bigger safety margin than you may first think.
This is, of course, true of any standby supply apart from a UPS, which can first issue a low battery alarm to the operator followed by telling the pico to shut down gracefully immediately.
     Page 1 of 7
