Local Time 19:43 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI TEXTBOX cannot switch to lower case letters
musterkonsument
Posted: 06:40pm 22 Aug 2026
tried to use the gui textbox, but cannot switch to lower case letters.
Tapping the triangel switches to the alternate keys insted.
My options:
OPTION LIST
WebMite MMBasic RP2350A Edition V6.03.01
OPTION SYSTEM I2C GP0,GP1
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL ILI9488W, RLANDSCAPE,GP8,GP15,GP9,GP13
OPTION TOUCH GP16,GP17
GUI CALIBRATE 0, 206, 3910, 1273, -870
OPTION WIFI MyFritzbox, ********************, Ladestation
OPTION GUI CONTROLS 100
OPTION SDCARD GP22
Hans-Werner
Posted: 10:03pm 22 Aug 2026
Confirmed.
  Quote  When the box is touched a QWERTY keyboard will appear on the screen.
Using this virtual keyboard any text can be entered into the box including
upper/lower case letters, numbers and any other characters in the ASCII
character set. The new text will replace any text previously in the box.
The Shift button (middle row, right side) only gives numbers and other characters. The ABC button (bottom left) toggles between numbers and other characters and capitals.
musterkonsument
Posted: 03:52pm 25 Aug 2026
Hi Peter @matherp,
could you confirm this and include into the latest update(V6.03.02b0)?
Hans-Werner
Posted: 05:34pm 25 Aug 2026
I've updated the v6.03.02b0 release with the fix
Edited 2026-08-26 03:48 by matherp
musterkonsument
Posted: 06:07pm 25 Aug 2026
Hi Peter @matherp,
thank you very much!
Hans-Werner
