Local Time 19:56 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - Attractor Mode
Nimue
Posted: 11:13am 15 Aug 2026
Here we go ...
Not a heavy GitHub user, but it works:
PicoMite Attractor
Currently only Missile Command in there as I need to clean up my trashy code and add comments.
This plays against itself, so no actual user control.  If anyone want to refactor and add that, go for it.
The autoload part is in there, but in the upload it forces just missile.bas to reload - should be obvious where this is.
Also, no sound.
Used a ST7735S_W - but should work on anything 128x128 - but didnt code anything to cope with different screens as this is what I have ;-)
G
Nimue
Posted: 05:37pm 15 Aug 2026
Missile Command
Asteroids
AI used to comment the code as I generally skimp on that.
AI also used to get the frame rate up -- it suggested / implemented:
1 - scaling the graphics by x16 and then downsizing (to use Ints)
2 - not using trig but a lookup table
3 - use of Framebuffer on Asteroids for the background BUT drawing the user ship straight on the LCD bypassing the framebuffer - sort of hybrid.
4 - collision detected tweak by AI (still not sure it's 100%)
G
Bleep
Posted: 05:48pm 15 Aug 2026
Hi Nimue,
I am surprised that 1 & 2 made it faster, I have usually found there is almost no difference using Ints, especially if you then have to rescale;  when I, and I think Peter, tried using lookup tables, to speed up Bubble Universe  for trig, it was slower?
I do use Int where it's easy loop counts, maths that doesn't require the precision etc.
Have you tried implementing each item and then timing individually.
Regards.
Edited 2026-08-16 03:52 by Bleep
Nimue
Posted: 06:00pm 15 Aug 2026
  Bleep said  Hi Nimue,
Regards.
Honest answer - no.
Just by inspection of the game on the screen.  I was happy with the percieved frame rate.
I implemented them Int first, then look up.
Moving to INTs seems to make a visible difference - so I left it.  The look up - not so much as obvious, but I still left it as it didnt break anything.
This raises the "AI" question again, where I was happy to delegate some of the thinking as this was for "fun" and not mission critical -- but I didnt test for sure, so dont have numbers.
I'm working on Space Invaders that AI has done all the heavy lifting after I uploaded the MMBasic Manual - my Missile Command prog and told it what LCD panel it was using.
One prompt and a runnable version stright to the 'Mite.
Lots of tweaking still to do, but it worked first time with my working example to lean on.
Colour me impressed.
mozzie
Posted: 07:35am 16 Aug 2026
G'day Nimue,
Very nice job on this project, self playing games are a great idea
Downloaded your code from GITHUB and tried out on LCD and it looks neat
After making a few adjustments to try on HDMI (1024x600 Mode2 = 256x150) the following caused an error:
Dim lnew
Dim newload As Integer
Dim attract$ As String
SetTick 180000, lnew
newload = 0
Sub lnew
   Select Case 2 'Int(Rnd * 4) + 1
       Case 1
           attract$ = "defender.bas"
       Case 2
           attract$ = "asteroids2.bas"
       Case 3
           attract$ = "lander.bas"
       Case 4
           attract$ = "missile.bas"
   End Select
   newload = 1
Having LNEW as a variable and a subroutine name should not be possible, this might be causing some problems
Oddly it works on the LCD version but errors on the HDMI version
Regards, Lyle.
Nimue
Posted: 10:26am 16 Aug 2026
  mozzie said  G'day Nimue,
Regards, Lyle.
That's odd - the error is probably mine.
Dim Lnew as used as Sub as have Option Explicit.   Do I not need to do that and just define the sub and call it?  Its not a variable - just the sub name.
Getting in a bit of a knot I think (me that is ;-))
G
Posted: 10:41am 16 Aug 2026
You should only DIM variables, not Sub names. Strange that it works at all. :)
Nimue
Posted: 11:33am 16 Aug 2026
  Mixtel90 said  You should only DIM variables, not Sub names. Strange that it works at all. :)
Yup - fixed / removed.
Not very good at maintaining code, I think at somepoint lnew was going to be a variable with an IF check and it just got left behind.
G
PilotPirx
Posted: 10:11am 17 Aug 2026
Hi Nimue,
where can I get *Missile Command* so I can play it normally? I don't have it in my collection yet.
Nimue
Posted: 07:07pm 17 Aug 2026
  PilotPirx said  Hi Nimue,
Hi
Here you are:  https://github.com/gpg342/PicoMiteAttract
As I sanitise and double check them I'll pop them in the GitHub page.
Missile and Asteroids already there.
You will need to tweak the code to make an actual playable game as there is no "player" code just the AI playing itself ;-)
G
PilotPirx
Posted: 01:30pm 18 Aug 2026
Got some Errors on my PicoCalc:
Example Missile Command
[32]Error: A sub/fun has the same name:LNEW
Uncommenting works
and
[512] Error: Frame not created
Renaming "Frame" works
Nimue
Posted: 04:20pm 18 Aug 2026
  PilotPirx said  Got some Errors on my PicoCalc:
Uncommenting works
and
I'll double check - running on my plain old 'Mite here -- probably something I've done (or not done!)
G
mozzie
Posted: 04:46pm 18 Aug 2026
G'day Nimue,
Frame is a command on the RP2350 / Pico2, if you are using a Pico1 you may not get an error message.
To get it working on PicoHDMI I renamed it to Framed. Might be worth letting the "AI" know so it avoids in future.
Thanks again for posting them up, they are both a great example to learn from
Regards, Lyle.
Nimue
Posted: 07:51pm 18 Aug 2026
Regards, Lyle.
Thanks for the feedback - will do -- never used the HDMI flavour (yet) - so missed that one.
Space Invaders and Araknoid coming soon.
G
