Local Time 20:30 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2040-zero controlling the LED
Posted: 02:20am 28 Jul 2026
Ordered in a RP2040-zero to play around with, and see its got a RGB LED on the board. How would I use this LED. I've read its pin16, but switching that high or low has no effect. I'm guessing its I2C or something like that?
PS, sorry, using the Picomite 2040 firmware.
Edited 2026-07-28 12:21 by Gizmo
mozzie
Posted: 02:39am 28 Jul 2026
G'day Glenn,
The LED on the RP2040-Zero is a WS2812 RGB on pin 16, the inbuilt WS2812 command should do the trick
WS2812 o,gp16,1,&h0f0f0f
Makes a good status indicator if nothing else. The red and green on the units here are reversed, its GRB instead of RGB
Hope the flow bench is progressing well, looking forward to an update.
Regards, Lyle.
Edited 2026-07-28 12:50 by mozzie
EDNEDN
Posted: 02:42am 28 Jul 2026
If it is a WS2812, you might try this piece of code and see if it lights up.
I wrote this code to locate the LED on an off market board so there is some extra fluff code to scan different GPIO's.
But it found my LED on GPIO-41.   Yours might be the same.   If not, you can start expanding the search loop by changing the "for p=41 to 41" to have a bigger range of pins.    And it does use the    Bitbang ws2812 o, p, 2, dd%()   command suggested up above.
'WS2812 color LED program
' The YD-RP2040 board needs the R58 solder pads bridged
' in order for the WS1280 LED to work.   Otherwise it is
' disconnected.
 Dim c%(16), dd%(1), n$(16)
 c%(0) = RGB(BLACK)    : n$(0) =  "Black    "
 c%(1) = RGB(BLUE)     : n$(1) =  "Blue     "
 c%(2) = RGB(CYAN)     : n$(2) =  "Cyan     "
 c%(3) = RGB(RED)      : n$(3) =  "Red      "
 c%(4) = RGB(MAGENTA)  : n$(4) =  "Magenta  "
 c%(5) = RGB(YELLOW)   : n$(5) =  "Yellow   "
 c%(6) = RGB(WHITE)    : n$(6) =  "White    "
 c%(7) = RGB(COBALT)   : n$(7) =  "Cobalt   "
 c%(8) = RGB(MYRTLE)   : n$(8) =  "Myrtle   "
 c%(9) = RGB(MIDGREEN) : n$(9) =  "Mid-Green"
 c%(10) = RGB(GREEN)   : n$(10) = "Green    "
 c%(11) = RGB(CERULEAN): n$(11) = "Cerulean "
 c%(12) = RGB(RUST)    : n$(12) = "Rust     "
 c%(13) = RGB(FUCHSIA) : n$(13) = "Fuchsia  "
 c%(14) = RGB(BROWN)   : n$(14) = "Brown    "
 c%(15) = RGB(LILAC)   : n$(15) = "Lilac    "
print "                 Red     Green     Blue"
for p=41 to 41
print "Doing pin "; p
   For i=1 To 15
     dd%(0) = c%(i)
     Print i;
     If i<10 Then Print " ";
     Print "  ";n$(i);" ";
     Prt_Bits(c%(i))
     Bitbang ws2812 O, p, 2, dd%()
     Pause 150
     'Do While Inkey$=""
     'Loop
   dd%(0) = RGB(black)
   Next i
next_pin:
next p
dd%(0) = RGB(black)
'Bitbang ws2812 o, GP23, 2, dd%()
Pause 1000
End
Sub Prt_Bits(arg1)
   Local i, j, k%, b$
   b$ = ""
   k% = arg1
   For i=23 To 0 Step -1
     If i = 15 or i = 7 Then b$=b$+" "
     j = 1 << i
     If k% And j Then
       b$ = b$ + "1"
     Else
       b$ = b$ + "0"
   Next i
   Print b$
Edited 2026-07-28 12:56 by EDNEDN
Glen0
Posted: 03:17am 28 Jul 2026
I use this:
Device WS2812 O, GP16, 1, RGB(BLUE)
Posted: 04:23am 28 Jul 2026
Bitbang and Device are no longer needed, but are still accepted.
> Bitbang WS2812 O, GP16, 1, RGB(BLUE)
