Forum Index : Microcontroller and PC projects : No Subject
| depand Newbie Joined: 07/04/2026 Location: United StatesPosts: 4 |
Hi Peter, Have been following your developments. Have MMBasic running and now micropython. Micropython interests me as I am working with a fellow in England on an automatic telescope Could really use your book to learn your micropython. Would appreciate your sending me a copy. Thank You Don Epand epanddon985@gmail.com Edited 2026-07-25 07:27 by Gizmo |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9237 |
Hi Don, Just bear in mind that Peter's book is only being proofread at the moment and isn't on general release yet. There may be errors. Also, this "flavour" of Micropython is heavily dependent on the hardware of the "Pico Computer 3" board, which Peter also designed. It's not really intended for anything else. Mick Zilog Inside! nascom.info for Nascom & Gemini |
