Local Time 20:44 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Text positioning
aaaaaaaargh
Posted: 09:27am 20 Jul 2026
Hello everyone!
I have just take my first small steps with the picomite. What a fantastic system and what great documentation! As a Basic enthusiast I feel right at home here, the forum looks like a friendly place with loads of useful information.
On that subject: How do I print something to a certain screen location. I can't find a "LOCATE row,column" like function.
I am using a Pico 2 and Teraterm. I have found a PRINT @(X,Y) command but X and Y have to be specified in pixels, that seems odd for a serial terminal.
When using pixel-like coordinates e.g. PRINT @(100,100) "Hello", the text is positioned somewhat away from top/left edge so I'm assuming there is some multiplication factor needed?
I'm sure I missed something obvious...
Thanks,
Arthur
Posted: 09:38am 20 Jul 2026
Hi Arthur,
It's one of those gnarly parts of MMBasic, I haven't got H/W in-front of me, but try getting the values of MM.INFO(FONTHEIGHT) and MM.INFO(FONTWIDTH) and using those as multipliers for the font you aren't using .
If you are accessing the PicoMite through a serial console then you can also PRINT the ANSI escape codes to move the terminal cursor.
Posted: 10:31am 20 Jul 2026
Ah... confusion reigns. lol
Welcome to the forum, Arthur. :)
When you have a serial connection to a Picomite you aren't strictly controlling an ASCII device from an ASCII terminal at all. You are at the command line (console) of a device with full graphics capabilities in its own right. You have to think of it along those lines. When you do it makes sense, you can't specify a character position on such a system as the resolution is naturally in pixels, not characters. The character size is set by the font in use.
aaaaaaaargh
Posted: 10:56am 20 Jul 2026
Thanks to both of you, it makes sense to me now.
I used
Const my=MM.Info(FONTHEIGHT)
Const mx=MM.Info(FONTWIDTH)
For x = 2 To 70
 For y = 2 To 20
   Print @(x*mx,y*my) "X",
 Next
Next
to get characters positioned correctly.
So this is to keep it sort of compatible with a graphic screen, I guess.
But for now i'll only be using Teraterm so i'm going to use vt100 sequences. I found some nice examples elsewhere in this forum :-)
Thanks for the quick response!
Edited 2026-07-20 20:57 by aaaaaaaargh
PhenixRising
Posted: 11:55am 20 Jul 2026
aaaaaaaargh as on the Parallax forum?
Welcome. The PicoMite makes a great front-end for the P2
Martin H.
Posted: 12:06pm 20 Jul 2026
Yes, I did implement 3DMonster Maze also for VT100 once.
Or Mandelbrot
   Martin
Edited 2026-07-20 22:23 by Martin H.
'no comment
aaaaaaaargh
Posted: 12:29pm 20 Jul 2026
  PhenixRising said  aaaaaaaargh as on the Parallax forum?
Yes, you caught me ;-)  And you, different handle over there?
I guess the PicoMite and P2 would be a nice combo, needs more thinking...
Edited 2026-07-20 22:34 by aaaaaaaargh
aaaaaaaargh
Posted: 12:54pm 20 Jul 2026
Or Mandelbrot
   Martin
Cool examples! This is going to be fun.
PhenixRising
Posted: 01:34pm 20 Jul 2026
Yeah, I'm Mickster over there but I figured that it was too similar to Mixtel90 for here.
I was on the old KISS thread. I have two P2-Edge modules, two KISS modules and the Cluso99 module.
I currently have the Edge modules talking to the (awesome) RP2350DIL modules but I am considering switching to the KISS because it is similar format to the RP2350DIL.
RP2350DIL
I guarantee that you'll get hooked on the PicoMite
fred777
Posted: 02:13pm 20 Jul 2026
  PhenixRising said  am considering switching to the KISS because it is similar format to the RP2350DIL.
Maybe get one of the new P2 sunnyside modules, that would fit the
RP2350DIL nicely. And now I know about it, I will have to get an RP2350DIL, I do love a dil/dip board 😋
PhenixRising
Posted: 03:07pm 20 Jul 2026
RP2350DIL nicely.
It's nice but he lost too many pins. I'm already tight with 58
aaaaaaaargh
Posted: 08:51am 21 Jul 2026
  PhenixRising said  It's nice but he lost too many pins.
Unfortunately yes...
So I'm curious, how are u using the Pico as a frontend?
Edited 2026-07-21 19:56 by aaaaaaaargh
PhenixRising
Posted: 10:08am 21 Jul 2026
The PicoMite or ARMite H7 or CMM2 is the command processor for my bespoke CNC controls.
These are not G-Code interpreting controls and five-axis is the minimum (I have 22 and 17 axis machines in the field).
I specialize in Tube Forming machines that not only bend tubes but automatically load/unload themselves.
The sequences can get complicated because unlike metal cutting (subtractive process), the workpiece grows.
Having a BASIC interpreter running the show, cuts down development time dramatically. Furthermore, I don't want to waste the precious resources of the Prop on displays and SD storage.
The PicoMite has become a serious controller in it's own right with low-level math, EIGHT PIDs, PIO, CRC, etc.
Two PicoMites can even be coupled (8bit one-way or 4bit bidirectional).
However, for personal satisfaction, I aim to exceed every metric of what the industry giants have and so the Prop is the only way to do this. It's really silly because we are talking ridiculous specifications that are practically useless.
The book "Programming and Customizing the Propeller" introduced me to RPCs (remote procedure calls) and so I am doing similar. The PicoMite calls out to procedures on the Prop.
Breaking News: St Georges Hall, Blackburn is being refurbished and they just placed an order for 4,000 chairs. They will all be made on a MicroMite-controlled CNC tube bender.
Edited 2026-07-21 20:10 by PhenixRising
aaaaaaaargh
Posted: 05:23pm 21 Jul 2026
Very impressive! It is always nice when Basic is used for serious stuff
PhenixRising
Posted: 06:21pm 21 Jul 2026
  aaaaaaaargh said  Very impressive! It is always nice when Basic is used for serious stuff
The masochist in me has me lurking over at PLCtalk.net.
All I do is read and shake my head. The problems that these guys struggle with and I'm thinking...five minutes with MMBasic and we're done.
I get the "oh but that's hobbyist stuff, not industrial"
WTF does that even mean....galvanic isolation is not rocket science and
you'll never have the problem of a PicoMite losing its entire program because a battery died....Yup, lots of PLCs lose everything if they don't pay attention to that red LED.
I don't watch TV and so this is my entertainment
"I need 200KHz PWM from my PLC."
"Yeah there's a $1,200 module for that but getting it to work is another problem"
aaaaaaaargh
Posted: 07:31am 22 Jul 2026
So if I understand you correctly, your saying that using a picomite you could make something like this a bit cheaper?
Bargain Timer Relay
Posted: 09:21am 22 Jul 2026
I see it's special offer time. You really shouldn't spend so much of your time browsing the bargain basement area.
PhenixRising
Posted: 11:56am 22 Jul 2026
Ludicrous   But it's often worse; "Backordered six weeks" and then the real cost is downtime.
A selector switch for one of our Bridgeport mills failed. The replacement was only £70 but what the heck, here is an opportunity to eliminate it in favour of a Chinese VFD. I set it up in vector mode and talk about smooth  . It was £50, including the optional remote pendant.
Last year, I was called out to three motor-starter failures but didn't have the time to replace them with VFDs. Such a shame because there is no comparison.
