Forum Index : Microcontroller and PC projects : Picomite USB Keyboard issues when using KVM switch
| fred777 Senior Member Joined: 01/07/2021 Location: United KingdomPosts: 106 |
Hi, again. I tried to use hdmi/usb version of the Picomite with a KVM Switch. The keyboard does not work reliably and often drops some characters or suddenly repeats a key endlessly. The same keyboard is working fine when attached to the picomite directly and the KVM switch is fine under Windows&Linux. Also tried different keyboards, but no change. Data: Original Pi Pico2 V6.03.00 - but the error happened with older versions as well KVM: ATEN CS1794 Cubiq Is there anything that might explain or even fix this? Cheers, Fred |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1573 |
Hi Fred, With the KVM switch, it seems you don’t have a permanent connection between the Pico and the Keyboard. I don’t think the devices are meant to be unplugged and plugged back in whilst in use. After all, that’s all the KVM switch does. It’s an interesting problem, but unfortunately I’ve got no other solution than to use a separate keyboard with the Pico. Cheers Martin 'no comment |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Hi "... or suddenly repeats a key endlessly." same here. I also have to use it without a KVM switch. Greetings Daniel |
No, this is not a cheap kvm, the clients don’t know if you’re switching, usb stays connected and monitor as well (edid emulation) Footnote added 2026-07-20 16:59 by fred777 I was referring to “ it seems you don’t have a permanent connection between the Pico and the Keyboard. I don’t think the devices are meant to be unplugged and plugged back in whilst in use. After all, that’s all the KVM switch does.” … just to avoid confusion |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9237 |
Bear in mind that this isn't a "full fat" USB stack like you find in Windows. It's TinyUSB - appreciably cut down to be shoehorned into the available storage and, particularly, RAM. What you are seeing may not be a fault, merely something that was never included. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Understood, I’ll have a look on the TinyUsb GitHub for similar issues |
What make/type of kvm are you using? I’m trying out different kvms to see if the problem can be reproduced |
Hi, I am using the AIMOS AM-KVM201-CL Greetings Daniel |
