Forum Index : Microcontroller and PC projects : Stoned (merging game for Game*Mite and PicoGamer)
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6195 |
Stoned In this game you gave to move gems (stones) around to create groups of 3 or more in one line (horizontal or vertical). ![]() You move in the grid with the D-pad, and select a stone to move with A. SELECT quits to menu, and finally closes the game. START starts the game. B provides a hint (just in case you don't see it anymore). ![]() Find the game in below ZIP. stoned.zip The controls are for Game*Mite/PicoGamer, but in essence are string based, so it is quite simple to patch the program for mouse or keyboard control. The game uses LOAD JPG, so it should run fine on 6.02.01 official release, but is tested on 6.03.00. In this thread you can find means to upgrade your Game*Mite. GameMite upgrade Happy gaming Volhout PicomiteVGA PETSCII ROBOTS |
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
It looks great Volhout |
Thanks ! It is always nice to get a positive reaction. Gives energy for more new things. Volhout PicomiteVGA PETSCII ROBOTS |
Help requested ! I do not own a 2350 HDMI setup yet. I could use some help from someone who does. Please install the "stoned.zip" from the first post. Use add this MMBasic program to the same folder. stoned_kb.zip Set the HDMI to OPTION RESOLUTION 640x480 in OPTIONS (I use MODE 4 = 15bit colors, resembling the ILI9341 display). RUN "stoned_kb.bas" Start the game with "s", stop with ESCAPE, help menu = ESCAPE Please report any problems, a screenshot will be appreciated (I can run the game on 2040 VGA, but it looks ugly). Thanks in advance for the support. Volhout Edited 2026-07-16 19:08 by Volhout PicomiteVGA PETSCII ROBOTS |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Hi, I tested it on "PicoMiteHDMIUSBV6.03.00" works just perfect! Here is a video: Dropbox P.S.: I just commented out the whole play MOD thing, because I didn't want to allocate memory to play mod, so I didn't tested the playback. Cool game! Greetings Daniel |
| Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 217 |
Hello, Did a quick test, Pico2 HDMI seems to work just fine. A bit of older firmware installed V6.03.00RC11 ![]() ![]() ![]() ![]() PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC11 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP10,GP11 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION MOUSE SENSITIVITY 1.0000 OPTION KEYBOARD US OPTION RESOLUTION 640x480 @ 252000KHz OPTION DISPLAY 30, 53 OPTION SDCARD GP5, GP6, GP4, GP3 OPTION RTC AUTO ENABLE /Peter63 |
Thanks Daniel, Peter, Now I know the engine works on HDMI. I can think about implementing mouse control, and adapt the screens to support the correct instructions. The video is helpfull. !! Volhout P.S. I fixed a nasty bug with initialization. You have not found it yet, but may run into it eventually. It happens when the initial screen has no matches. I included 2 files (stoned, and stoned_kb) although stoned_kb should also work on Game*Mite but I did not test it yet... stoned.zip Edited 2026-07-16 23:52 by Volhout PicomiteVGA PETSCII ROBOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12054 |
For fun, here is the program converted to micropython and tested under v0.8 using a HDMI touch screen on a Pico Computer 3. The D-pad/A/B controls became touch: Drag a stone toward a neighbour (≥13px of finger travel picks the dominant axis) — the classic match-3 gesture, or tap a stone (cyan box, the old "A select") then tap an adjacent one to swap. The green partner box and the two 100ms beats of the original swap animation are kept. Tap the HINT bubble — the suggested stone flashes white three times (instead of teleporting the cursor), and the dial fills as before. Tap the MENU bubble — pause menu over the board; the game clock stops while it's open (the original's timer kept running, but its blocking key-wait meant pausing was effectively free — this preserves that spirit). On the intro, menu and end screens: TAP continues / replays, HOLD (long press) quits — replacing START/SELECT. The intro JPG's baked-in "SELECT to QUIT / START to begin" caption is covered with a "TAP to begin" bar. stonedpy.zip |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 252 |
Volhout, Thanks - great looking game. Peter63, What is that device with cheese wiz on it? |
Hi Peter, Thanks for the python version. That must have been an AI conversion, since it töok me hours and hours to write Stoned. , and do the artwork. Once I have python, I will analyze how it is implemented. Volhout P.s. as you can read in the source code, there are still 2 todo's. 4 in a row leaves a bomb charged stone behind, that when triggered (3 in a row) next time clears a 3x3 field. 5 in a row leaves a pulsung gem behind(new type) that you can move any normal gem upon, and when you do, the whole field is cleared of that particular gem type (erases 5-20 stones in 1 move).But these require new tiles, an mod samples that are not in this file set. Edited 2026-07-17 05:13 by Volhout PicomiteVGA PETSCII ROBOTS |
![]() breadboard from the side The HDMI adapter might have ended up a bit unnecessarily tall when I built it. /Peter63 |
| PilotPirx Senior Member Joined: 03/11/2020 Location: GermanyPosts: 164 |
Great game! It's a ton of fun. My wife loves it! I installed it on the PicoGamer on drive B:. It would be nice to have a high score display. Good job—the sound is great, too. |
This is a version that uses KB control, and should work on an HDMI. stoned_kb.zip Type "g" to start, "h" for help, ESC to quit, SPACE to mark/swap Cursor keys to move focus. Using 640x480 @ 252MHz Selects mode 4 since it is identical to Game*Mite LCD. Too bad there is no mode with 640x480 @ 256 colors. That would be better for this game. I will look if I can convert to mouse control. Cannot do touch, since my screen does not provide touch. Volhout Edited 2026-08-29 23:13 by Volhout PicomiteVGA PETSCII ROBOTS |
