Local Time 20:56 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Wifi webmite and Pi Pico Plus 2W
xardomain
Posted: 04:46pm 08 Jul 2026
I got the boards now (six!), time to try to make them work together.
I would like to know:
1) How to differentiate between MCUs, like acquiring the MAC address. The same program will be flashed on 6 pico, but only one will be the controller so I detect its specific MAC and behave differently from the others.
The others are all equal with the same connections but the controller will have to be always the same, it is wired differently.
Apparently I can't detect the current MAC address from Webmite.
2) I see that on boot there is an ID displayed(PICO5FF0ED8XXXX), same as before. How to get access to it(supposed it is unique of course)?
3) Netmask and broadcast address
I would like to dynamically acquire these parameter in the program, I don't know how. Searched for it, I was unable to do it.
4) Manual wifi configuration: I am okay with the DHCP but I need to somewhat "order" the nodes, and assign a different parameter (a different delay offset) to each one. Again with the MAC address I could sort them in ascending order, or something similar.
The IP address could be used too but probably with the MAC address is easier.
Still, would it be possible to "force" a specific IP address?
5) After powering on, the wifi connection fails:
17:00:12 Port: COM6 removed
Disconnected
17:00:16 Port: COM6 inserted
Connected to COM6 at 115200
PICO5FF0ED861FD connecting to WiFi...
failed to connect.
Initializing...
If I press the RESET subsequently it always connect.
Is there any way to correct this behavior? My fix was trying to reset with the command CPU RESTART until I don't get an IP:
IF IP$ = "0.0.0.0" then
  'WATCHDOG 1000   ' arm a 1-second watchdog
  'DO : LOOP       ' do nothing — let it expire and force a restart
  PRINT "Wifi initialized failed. Retrying..."
  PAUSE 500
  cpu restart
endif
I was hoping to avoid the double boot process.
Thanks.
Giuseppe Marullo
IW2JWW - JN45RQ
Posted: 11:25pm 08 Jul 2026
> ? MM.INFO(ID)
D531A797204
It's a string so this may be better.
> s$ = MM.INFO$(ID) : ? s$
D531A797204
Or as an integer.
> execute "x% = &H"+MM.INFO$(ID)
> ? x%
14650577613316
My startup routine.
Sub MM.STARTUP
  Pause 500 'ensure connection routine is finished
  On error skip
  If MM.Info(ip address) = "0.0.0.0" Then    'test for WiFi link
    Print "WiFi not found";
    Pause 8000  'if router is slow give it time before next attempt
    Print "...Rebooting now"
    CPU restart  'endless re-boot until WiFi found
  Local float TZ = 10, DS = 0    'Time Zone, Daylight Saving
  Local integer n = 0
  Do While Date$ = "01-01-2024" 'test internet connection, wait for date$ to update
    On error skip
    WEB NTP TZ+DS, "203.12.160.2" 'Second choice is 0.au.pool.ntp.org or 1.au.pool.ntp.org
   Inc n : Print n; " tries", DateTime$(now),
   Pause 2000
   If n=15 Then Exit Sub 'give up!
  Print
  RUN 'start main program
Edited 2026-07-09 15:23 by phil99
Posted: 10:42am 09 Jul 2026
Instead of
maybe
x% = val("&H"+MM.INFO$(ID))
xardomain
Posted: 03:58pm 10 Jul 2026
Thank you Phil99 and John.
Nice improvement for retrieving NTP time.
At the moment I am planning to use the ID instead of the MAC, then I will decide if it is enough.
Still I am don't know why wifi fails at first power on, it is sistematic.
Is it a known bug?
I am using a Pico Plus 2W, RP2350A04.
Giuseppe Marullo
IW2JWW - JN45RQ
Posted: 09:44pm 10 Jul 2026
What make of router are you connecting to?
There were problems with some FritzBox models but I thought that was now fixed with later Fritz firmware.
xardomain
Posted: 05:33am 11 Jul 2026
Hi TassyJim,
router is a UniFi Cloud Gateway Fiber UCG-Fiber.
Giuseppe Marullo
IW2JWW - JN45RQ
ville56
Posted: 07:12am 11 Jul 2026
  TassyJim said  What make of router are you connecting to?
Not quite. I still have to use the restart logic to get a reliable connection to my FritzBox which is always running the latest firmware.
73 de OE1HGA, Gerald
Posted: 07:39am 11 Jul 2026
I must have got lucky with my Fritz 7530AX.
It looks like a retry is always going to be programmed in as a backup.
