Local Time 20:30 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.03.00 Release
     Page 1 of 5
Posted: 03:38pm 30 Jun 2026
V6.03.00 is now available at https://github.com/UKTailwind/PicoMite/releases/tag/PicoMite-V6.03.00
The user manual, gui manual and all other ancillary documentation is available at https://github.com/UKTailwind/PicoMite/tree/main/docs
Various python scripts for use by users are on https://github.com/UKTailwind/PicoMite/tree/main/user-tools
The latest version of the CFunction header is here
In the next days I'll get all this packaged up for Geoff to include on his site and will post release notes on this thread.
As far as I'm aware the release picks up the various comments on the RC thread and the documentation thread (where I agree with them ).
Posted: 04:57pm 30 Jun 2026
For info, the github is now completely re-organised. If you want to build the PicoMite firmware for yourself and assuming you have the compiler and pico sdk loaded and set up then all you need to do is as follows:
Create a new directory and cd to that directory
git clone https://github.com/UKTailwind/PicoMite.git
cd Picomite
buildpicomite [what]
'what' can be nothing (builds every version) rp2350, rp2040, or a specific build
PICOMIN:PicoMiteRP2040MIN PICOUSB:PicoMiteRP2040USB VGA:PicoMiteRP2040VGA VGAUSB:PicoMiteRP2040VGAUSB WEB:WebMiteRP2040 WEBRP2350:WebMiteRP2350 VGARP2350:PicoMiteRP2350VGA VGAUSBRP2350:PicoMiteRP2350VGAUSB PICORP2350:PicoMiteRP2350 PICOUSBRP2350:PicoMiteRP2350USB PICOBTRP2350:PicoMiteRP2350BT PICOBTHRP2350:PicoMiteRP2350BTH HDMI:PicoMiteHDMI HDMIUSB:PicoMiteHDMIUSB HDMIWEB:PicoMiteHDMIWEB
Edited 2026-07-01 03:04 by matherp
Frank N. Furter
Posted: 05:13pm 30 Jun 2026
Peter,
this version doesn't start up every time on my PicoCalc; it takes a long time to boot and then displays the following message:
Invalid clock speed - reset to default
In addition, you hear a "pop" through the speaker every time a launch is successful.
That wasn't the case with version PicoMiteRP2350V6.03.00RC26 - everything was fine back then...
Frank
Posted: 05:30pm 30 Jun 2026
Nuke the pico and try again. I've borrowed the PicoCalc again and it works perfectly for me. If you still have problems then we need to wait for any other PicoCalc users to report
Frank N. Furter
Posted: 05:35pm 30 Jun 2026
I nuked it again ( universal_flash_nuke.uf2 ) and flashed it with PicoMiteRP2350V6.03.00.uf2.
No difference...
Frank
Posted: 05:52pm 30 Jun 2026
Do the following, if this doesn't work I'm beginning to suspect your PicoCalc is on the way out.
Load PicoMiteRP2350VGAV6.03.00.uf2
You should see it boot up as follows: then reload PicoMiteRP2350V6.03.00.uf2 and it should immediately re-confiure for the PicoCalc
Frank N. Furter
Posted: 06:10pm 30 Jun 2026
On this PC, the terminal only works through the USB-C port. And that port isn't enabled by default yet.
Okay, I loaded universal_flash_nuke.uf2, then the USB version, and then the regular version.
I had to restart PicoCalc twice, then I saw the message "Formatting the A: drive," and when I entered "OPTION LIST", "OPTION PLATFORM PicoCalc" was displayed.
After a restart, the following message appeared again:
Frank
Frank N. Furter
Posted: 06:30pm 30 Jun 2026
What's really striking is that it almost never starts up with an SD card inserted, but it works more often without one.
Sometimes the "Invalid clock speed" message doesn't appear either...
Frank
Posted: 06:49pm 30 Jun 2026
The console should work connected to the Pico irrespective of whether the PicoCalc is turned on or not
al18
Posted: 07:05pm 30 Jun 2026
Peter, thanks for all your hard work on this release. You’ve made huge improvements over the years!
toml_12953
Posted: 07:06pm 30 Jun 2026
  matherp said  For info, the github is now completely re-organised. If you want to build the PicoMite firmware for yourself and assuming you have the compiler and pico sdk loaded and set up then all you need to do is as follows:
cd Picomite
What OS is this for? It won't run in Ubuntu at all, it fails in PowerShell Admin mode with a permission error. It looks like a windows batch file but it won't run in Windows, either.
Edited 2026-07-01 05:12 by toml_12953
dddns
Posted: 07:30pm 30 Jun 2026
  Frank N. Furter said  What's really striking is that it almost never starts up with an SD card inserted, but it works more often without one.
Frank
No idea of the hardware design but if the 3V3 output of the Pico itself is used I would check if the current is for some reason too high.
Edit: ..and if the Pico runs isolated with these cpu speeds.
Do you use a diffent SD card than before?
Edited 2026-07-01 05:53 by dddns
Posted: 07:56pm 30 Jun 2026
Looks to use
buildpicomite.bat
so, Windows
homa
Posted: 08:53pm 30 Jun 2026
  matherp said  Nuke the pico and try again. I've borrowed the PicoCalc again and it works perfectly for me. If you still have problems then we need to wait for any other PicoCalc users to report
I’ve just updated the PicoCalc with a 2350 (also known as pico2) to version 6.03. It’s been running smoothly so far.
However, the "new" command alone sometimes results in a screen that isn’t displayed properly (the command simply appears twice at the bottom of the screen). But "cls" sorts it out.
Edited 2026-07-01 06:58 by homa
Posted: 10:01pm 30 Jun 2026
  Quote  What OS is this for?
W11, run in a developer command prompt window. Get an AI to convert to linux, should be trivial, but first make sure you can execute cmake and nmake from the command prompt to build one of the Pico example programs
toml_12953
Posted: 11:28pm 30 Jun 2026
I tried Linux commands directly.
One problem was that I had to edit PicoMite/net/mbedtls_config.h to add
#include <stdio.h>
then I actually get the compile stage to 98% Now I get this:
Relocating gpio_default_irq_handler into RAM (.time_critical)
CMake Error at cmake/relocate_gpio_irq_to_ram.cmake:36 (message):
 relocate_gpio_irq_to_ram: no hardware_gpio/gpio.c.obj found under
 /home/tlake/PicoMite/CMakeFiles/PicoMite.dir
I'm stuck. Any ideas?
Edited 2026-07-01 09:57 by toml_12953
ville56
Posted: 06:21am 01 Jul 2026
The release version cannot be reset to OLIMEX USB ....
> option list
PicoMiteHDMI MMBasic USB RP2350B Edition V6.03.00
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION RESOLUTION 640x480 @ 315000KHz
> option reset list
PICO COMPUTER 3
HDMIUSB
OLIMEX USB
PICO COMPUTER
HDMIUSBI2S
> option reset olimex usb
Error : Invalid board for this firmware
73 de OE1HGA, Gerald
Frank N. Furter
Posted: 06:42am 01 Jul 2026
  matherp said  The console should work connected to the Pico irrespective of whether the PicoCalc is turned on or not
Yes, you're right about that! That's a problem with my stupid Linux PC. Knoppix doesn't have a driver for the Raspberry's serial port. That's why I can only access it through the USB-C port.
I think I'm going to toss that piece of crap PicoCalc in the trash soon!!!
Frank
Edited 2026-07-01 16:44 by Frank N. Furter
fred777
Posted: 08:12am 01 Jul 2026
  al18 said  Peter, thanks for all your hard work on this release. You’ve made huge improvements over the years!
I would also like to say thank you for the new release.
You are doing fantastic work!
Posted: 08:22am 01 Jul 2026
The github is updated (8:21 UTC 1/7/26) with a fix to OPTION RESET OLIMEX USB and a fix to LIST PINS if no display is connected
     Page 1 of 5
