Local Time 21:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about HTTPS/TLS
Doktorn
Posted: 05:23pm 26 May 2026
Hi all
Has anyone used WebMite 2350 with the new HTTPS/TLS?
I have tried to make an API request but can't get it to work.
I only get  400 Bad Request.
How should I format a REQUEST for the following web site?
https://www.elprisetjustnu.se/api/v1/prices/2026/05-26_SE4.json
The code below worked with the previous version 5.07.07RC3 of WebMite with TLS.
Dim buff%(8192/8)
Dim b$=”GET /api/v1/prices/2023/04-15_SE4.json” +Chr$(10)+Chr$(13)
WEB open tls client Wwww.elprisetjustnu.se”,443
WEB tls CLIENT REQUEST b$,buff%(),10000
Pause 1000
WEB close tls client
/Lasse
Posted: 05:49pm 26 May 2026
The old request was malformed but the previous TLS stack was lenient enough to let it through. The new mbedTLS path needs a proper HTTP/1.1 request — specifically a CRLF (not LF+CR), an HTTP/1.1 version token, a Host: header, and a blank line terminator.
Note the b$ lines will need connecting together.
Dim buff%(8192/8)
Dim CRLF$ = Chr$(13) + Chr$(10)
Dim b$ = "GET /api/v1/prices/2026/05-26_SE4.json HTTP/1.1" + CRLF$ + "Host:  _
www.elprisetjustnu.se" + CRLF$ + "User-Agent: WebMite" + CRLF$ + "Accept:  _
application/json" + CRLF$ + "Connection: close" + CRLF$        + CRLF$
WEB OPEN TLS CLIENT "www.elprisetjustnu.se", 443
WEB TCP CLIENT REQUEST b$, buff%(), 10000
LongString print buff%()
Pause 1000
WEB CLOSE TCP CLIENT
Key points vs. your original:
CRLF order: HTTP requires \r\n (Chr$(13)+Chr$(10)), your code had them reversed.
HTTP version: must include HTTP/1.1 after the path.
Host header: mandatory in HTTP/1.1 and required by virtual-hosted servers like this one; without it you'll usually get a 400.
Blank line: a request ends with an extra CRLF on its own.
Connection: close: makes the server close after responding so your buffer/timeout behavior is predictable.
Fixed the Wwww typo and the smart quotes (” → ") — those would also fail to compile as-is.
Doktorn
Posted: 07:49pm 26 May 2026
Peter
I didn't copy the code, I typed it in, so the mistake was that I
typed shift-w instead of shift-2. These keys are quite
close to each other. I don’t know about the inverted \n\r, it worked
at least with the old code. Now it works as expected, only get the
Invalid JSON data. As you pointed out in the discussion last November
”The json listed doesn’t confirm to the norm” so I have to insert the needed
part[1].name. Strange however because both MicroPython and
Annex RDS decodes the same JSON without complains.
Many thanks for the help.
/Lasse
Doktorn
Posted: 05:06pm 06 Jun 2026
Peter,
The first SITE$ works OK, switch to the second one gives Error : TLS client error -15
Dim buff%(16384/8)
Const CRLF$ = Chr$(13)+Chr$(10)
Const SITE$ = "www.elprisetjustnu.se"
'Const SITE$ = "se.elpris.eu"
WEB NTP 2
idag$="20"+Mid$(Date$,9,2)+"/"+Mid$(Date$,4,2)+"-"+LEFT$(Date$,2)
' ------------ Build HTTP/1.1 Request ----------------------------
reg$ = "GET /api/v1/prices/"+idag$+"_SE4.json HTTP/1.1" + CRLF$
Cat reg$, "Host: " + site$ + CRLF$
Cat reg$, "User-Agent: WebMite" + CRLF$
Cat reg$, "Accept: application/json" + CRLF$
Cat reg$, "Connection: close" + CRLF$ + CRLF$
' ----------- End Build HTTP/1.1 Request -------------------------
Print reg$
WEB open tls client SITE$ ,443
WEB tcp CLIENT REQUEST reg$,buff%(),10000
Pause 1000
WEB close tcp client
/Lasse
Posted: 05:30pm 06 Jun 2026
Have you tried RC16 or RC17? There is a enhancement to enable RSA encryption in these latest releases
Doktorn
Posted: 05:35pm 06 Jun 2026
Running WebMite MMBasic RP2350A Edition V6.03.00RC16
Posted: 06:57pm 06 Jun 2026
TLS client error -15 is lwIP's ERR_CLSD. For se.elpris.eu  the cause is that PicoMite Web supported MBEDTLS_SHA512_C but not the separate MBEDTLS_SHA384_C that mbedtls 3.6.2 requires. Without SHA-384, the ecdsa-with-SHA384 OID descriptor is compiled out, so mbedtls can't even parse the site's SHA-384-signed ECDSA certificate — the handshake aborts before verification, and altcp reports it as -15.
Now included
PicoMite.zip
Doktorn
Posted: 07:39pm 06 Jun 2026
Thank you, much appreciated.
The payload from "se.elpris.eu" is about ten times smaller.
/Lasse
