Local Time 21:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : makerfabs 3.95" display
cdeagle
Posted: 12:04pm 26 May 2026
Will this display work with MMBASIC?
https://www.tindie.com/products/makerfabs/matouch-lite-esp32-s3-spi-resistive-touch-395/
Posted: 12:18pm 26 May 2026
Almost certainly not.
But if you are willing to get one and prove me wrong.....  :)
It's designed to be an integrated ESP32 and display. There's no reason to assume that you can use either without the other. After a quick look at the wiki and github I couldn't find a schematic so, TBH, I wouldn't even consider it for MMBasic.
Posted: 02:10pm 26 May 2026
cdeagle,
The display has a ESP32-S3 soldered onto it. There is no MMBasic for ESP32.
So the answer is NO.
