Forum Index : Microcontroller and PC projects : RP2350 - HDMIUSB - GUI Functions
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1135 |
Is anyone aware of why the extended GUI commands/functions (eg. switch, display box, area etc.) are not available for VGA and HDMI versions of MMBasic? I have made extensive use of them in previous projects, some of which I am now trying to port to the RP2350 Pico 2B Computer. Doug ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Bryan1![]() Guru Joined: 22/02/2006 Location: AustraliaPosts: 2297 |
Doug I used a 2350B for my stepper project and it ran fine making the GUI using a 3.5" LCD, got 5 pages working and it's now inhand with the stepper guru's to move forward. Now in the pico manual it does state with the VGA and HDMI versions of the software won't work so the standard 2350.uf is used. Edited 2026-05-08 14:43 by Bryan1 |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1158 |
Hi Doug, Not sure of exact reason, most likely not enough resources when HDMI or VGA present. See this thread where a GUI editor was started by @Amnesie that produces MMBasic versions of some of the controls. Not sure how complete it is. Introducing: GUI Editor for the PicoMiteVGA Gerry F4 H7FotSF4xGT |
I think its probably also a case of which touch system would be supported? Standard VGA and HDMI displays don't have touch fitted so it's either something proprietary for each display or some sort of third party panel (probably a serial port, although I think there are USB versions now). Either would assume that it was being used on a Windows system so would be designed for control over over a specific Windows driver, unless it simulated a mouse using hardware rather than software. IMHO there are probably too many variations. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12055 |
GUI functionality is entirely integrated with touch screen processing and can't be used without it. HDMI/VGA screens in general don't have touch therefore the GUI controls make no sense. For those screens that do have touch, there is no standardised I/F like the XPT2046 so it is impossible to support them. Remember, this is a single chip uP with limited resource. |
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 527 |
OK but the CMM2 has the UI commands using a mouse and I have used that and like that option. Is the overhead for the commands too high? They call me Shai-Hulud (The maker) |
Yes |
Thanks. They call me Shai-Hulud (The maker) |
