Local Time 22:02 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 include limitations
Macer_D
Posted: 09:24am 25 Apr 2026
Hi all, new member here. I just got my Colour Maximite 2 in the mail yesterday, and I've been having lots of fun with it. I have a question about the program size limitation - it says in the manual that the maximum size of a program is 512k as a plain text file. Does the include command allow the user to bypass this limitation, or does the file it includes count towards the same total? Thank you for your time.
Macer
Posted: 09:43am 25 Apr 2026
512k is a hard limit for the whole program. It represents over 10,000 real world line of code
Macer_D
Posted: 10:30am 25 Apr 2026
  matherp said  512k is a hard limit for the whole program. It represents over 10,000 real world line of code
I see, thanks. Do images and sound files count towards the program size? Also, do you know of any programs that reach this limit?
Posted: 10:33am 25 Apr 2026
This limit is just the actual code. AFAIK no-one has got remotely close. A program that calculates solar_eclipse and is 3000 lines long is less that 80K
Macer_D
Posted: 10:45am 25 Apr 2026
  matherp said  This limit is just the actual code. AFAIK no-one has got remotely close. A program that calculates solar_eclipse and is 3000 lines long is less that 80K
Fantastic. I guess in that case you could even import a separate plain text file without it counting toward the limit, couldn't you?
PhenixRising
Posted: 11:36am 25 Apr 2026
Well you have 32MB RAM. I use the CMM2 but don't fully understand the memory thing because I don't require much but I believe that it can accommodate arrays. The manual states "for larger BASIC programs."
PeteCotton
Posted: 01:12am 29 Apr 2026
I've written some huge programs and not got close to the 512K limit. And yes the include files do count towards that limit.
But, if I did get close, then you can save variables to a disk file, and run a new program - which then loads those variables and effectively carries on. Because the SD card system is so fast, it will only take a few seconds. Or you could just push the variables into memory and read them back from the new program. Obviously you wouldn't want to do this all of the time, but if you were transition from one part of a game to another then this technique would work well.
If it did really become an issue, I wonder if you could swap the program memory into/out of the 32MB graphics memory (i.e. swap a whole program). Self-replicating code - always a fun time. But such a complicated solution would really require the program to be truly massive (and like I said - there isn't really a need for it - I have yet to see a program anywhere near the limit). If you did hit the limit there's plenty of other tricks to do first, such as shortening variable names and optimising functions to free up space.
I love that you're enjoying your CMM2. It's a great machine, that provides endless hours of enjoyment and tinkering.
GerryL
Posted: 11:20pm 29 Apr 2026
Hi Macer,
some time ago I wrote a MMBasic solar system program for the CMM2 and H7 to give a stack of information about the solar system bodies based on Jean Meeus's Astronomical Algorithms.  I then added to it a whole stack of test routines comparing it to the US Naval Observatory Computer Almanac (MICA 2.0).  It was 6575 lines long and only came to 315k, 512k is a massive amount of memory for even the most challenging program.
One thing I did do to manage the number of variables was to use a single array of floats for a lot of the calculations.
Enjoy your CMM2.
Gerry
