Local Time 22:16 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : can MM.MESSAGE$ be cleared?
wolfme
Posted: 07:43am 19 Apr 2026
can i manually clear mm.message$?
E.g. set it to "".
If yes, how?
If no, when is mm.message$ cleared?
Wolfgang
Posted: 08:14am 19 Apr 2026
  Quote  ... They are reset to zero and an empty string by RUN, ON ERROR IGNORE or ON ERROR SKIP.
An experiment you could try.
Put ON ERROR SKIP above a statement at a suitable point in a program  after a deliberate error then Print MM.ERRMSG$.
Eg.
'... Various statements
ON ERROR SKIP
statement with a deliberate error
Print MM.ERRMSG$
ON ERROR SKIP
If MM.ERRMSG$ = "" then Print "No error message"
Edit.
Yes, that works.
Well it did eventually after making some stupid mistakes!
Edited 2026-04-19 19:00 by phil99
wolfme
Posted: 11:13am 19 Apr 2026
Thanks, i'll try that.
Posted: 11:53am 19 Apr 2026
Here is my test.
'Test clearing error messages.
On error skip
SetTick 200,Show_Pos 'this Sub does not exist
Print "An Error Occured = ";MM.ErrMsg$
On ERROR SKIP
Stepper close 'Stepper was never opened
On error skip
If MM.ErrMsg$ = "" Then Print "Error message cleared"
Print MM.ErrMsg$
Print "finished"
End
Output
> RUN
An Error Occured = Cannot find label
An Error Occured = Stepper not initialized
finished
