Local Time 22:35 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WEB Connect from program
terekgabor
Posted: 11:28pm 04 Apr 2026
Hello!
Is there any way to solve possibility connecting wifi from program?
WEB CONNECT only works from command line.
But WEB SCAN is working from program. Not logic why, because I can’t connect from program.
Thx,
G@bor
Posted: 07:01am 05 Apr 2026
I thought it did - providing you have set OPTION WIFI up.
I've not played with one of these for ages.
It might not if you haven't set OPTION WIFI as your password would have to be in the clear text MMBasic program. Only guessing.
terekgabor
Posted: 11:23am 05 Apr 2026
If I use WEB CONNECT ssid, pswd in a program I got Invalid in a program error.
Can be good if I can connect to a wifi network choosing it in my program for example.
G@bor
Posted: 11:45am 05 Apr 2026
You can't do it in a program. Like your PC, you connect to a wifi network and then you use whatever application. You can't choose a wifi network inside Excel. This functionality isn't going to change
terekgabor
Posted: 12:58pm 05 Apr 2026
Okay! Thanks, I will do in this way!
