Forum Index : Microcontroller and PC projects : PicoMite V6.02.02 betas
| Page 1 of 8 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12056 |
V6.02.02b0 PicoMiteV6.02.02B0.zip PicoMiteRP2040 no longer supports the CAMERA command All versions: Support for 4 and 8 bit parallel memory sharing interconnect MEMORY_SHARE_User_Manual.pdf USB versions Support as host for up to 4 CDC devices allowing a USB PicoMite to connect directly over USB to a non-USB PicoMite Easter Egg - all versions ' MandelbrotTest.bas ' Demonstrates all features of the MANDELBROT command ' ' Requires a configured display (SPI LCD, VGA, etc.) ' Press Ctrl-C at any time to abort a draw in progres s ' Start with a clean slate MODE 2 CLS ' --- 1. Basic draw (default 64 iterations) --- Print "Drawing Mandelbrot set (default view)..." Timer = 0 Mandelbrot Draw Print "Done in " Str$(Timer) "ms" Pause 2000 ' --- 2. Draw with higher iteration count --- CLS Print "Redrawing with 128 iterations..." Mandelbrot Reset Timer = 0 Mandelbrot Draw 128 Print "Done in " Str$(Timer) "ms" Pause 2000 ' --- 3. Bare command (no subcommand, 64 iters) --- CLS Print "Bare MANDELBROT command..." Mandelbrot Reset Timer = 0 Mandelbrot 64 Print "Done in " Str$(Timer) "ms" Pause 2000 ' --- 4. Centre on a point of interest --- ' Re-centre on approx (3/4 width, 1/2 height) - nea r the ' boundary of the main cardioid, then zoom in CLS Print "Centre on interesting region..." Mandelbrot Reset Mandelbrot Draw Pause 1000 Mandelbrot Centre MM.HRES*3\4, MM.VRES\2 Print "Centred and redrawn" Pause 2000 ' --- 5. Zoom in sequence --- CLS Print "Zooming in x2, x2, x2..." Mandelbrot Reset Mandelbrot Draw Pause 1000 Mandelbrot Zoom 2 Print "Zoom x2" Pause 1000 Mandelbrot Zoom 2 Print "Zoom x4 total" Pause 1000 ' --- 6. Zoom out --- CLS Print "Zooming back out..." Mandelbrot Zoom 0.5 Print "Zoom x2 total (zoomed out x4)" Pause 2000 ' --- 7. Pan around --- CLS Print "Panning right 50 pixels..." Mandelbrot Reset Mandelbrot Draw Pause 1000 Mandelbrot Pan 50, 0 Print "Panned right" Pause 1000 Print "Panning down 30 pixels..." Mandelbrot Pan 0, 30 Print "Panned down" Pause 1000 Print "Panning left and up..." Mandelbrot Pan -80, -30 Print "Panned left+up" Pause 2000 ' --- 8. Combined: centre, zoom, pan workflow --- CLS Print "Interactive-style exploration..." Mandelbrot Reset Mandelbrot Draw Pause 1000 ' Centre on the seahorse valley (approx left-centre o f set) Mandelbrot Centre MM.HRES\4, MM.VRES\2 Pause 1000 ' Zoom in deep Mandelbrot Zoom 4 Pause 1000 Mandelbrot Zoom 4 Pause 1000 Mandelbrot Zoom 2 Pause 1000 Mandelbrot Zoom 2 Print "Deep zoom into seahorse valley" Pause 2000 ' Increase iterations for detail at this depth Mandelbrot Draw 256 Print "Re-rendered with 256 iterations" Pause 2000 ' --- 9. Reset back to default --- CLS Print "Resetting to default view..." Mandelbrot Reset Mandelbrot Draw Print "Back to default" Pause 2000 CLS Print "Mandelbrot demo complete!" End ![]() Edited 2026-04-05 00:45 by matherp |
This looks terrific if I understand correctly. Does this mean I can plug a powered 4-port USB hub into Picomite1's USB_C port, and plug Picomite2-5 into the hub, and Picomite1 can talk to all as if talking to their consoles? What provides console on Picomite1? And I can plug a usb-serial module into the hub and connect the serial to any device which outputs serial and have a link to PicoMite1? And at the same time have another Picomite connected with 4-pin parallel? ~ Edited 2026-04-05 02:10 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
The USB CDC host capability applies to the USB variants of the firmware. For these the console by default is standard UART serial on GP8/GP9. This is how it has been forever. The code is tested connecting my HDMIUSB reference design to a VGARP2350. You can have up to 4 connections simultaneously. I theory it could connect to a USB-serial module but untested. and in theory this can run at the same time as the parallel link - untested. |
| bfwolf Senior Member Joined: 03/01/2025 Location: GermanyPosts: 258 |
Great that you took my suggestion about 4 bits into account! Just in case that was the reason? Otherwise, anyway fantastic! First of all: Brilliant! Super! Thanks again! Question: Isn't the baud parameter passed trough to USB-to-serial converters (like the FT232)? How do USB-to-RS232 adapter cables then determine the baud rate, nbits, and parity? Regards |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 924 |
Thank you for the enhancements! Would it be possible to use Xmodem with a custom com port? |
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 736 |
I'm trying the beta. When I exit the editor with Esc, the prompt disappears except for a tiny dot in the upper left corner. Before you blame it on the PicoCalc, the final version of 6.02.01 runs fine. Here's my OPTION LIST: PicoMite MMBasic RP2350B V6.02.02B0 OPTION SERIAL CONSOLE COM1,GP0,GP1,BOTH OPTION LCD SPI GP10,GP11,GP12 OPTION SYSTEM I2C GP6,GP7, SLOW OPTION BAUDRATE 19200 OPTION FLASH SIZE 16777216 OPTION LIBRARY_FLASH_SIZE 51000 OPTION COLOURCODE ON OPTION CONTINUATION LINES ON OPTION CASE UPPER OPTION TAB 8 OPTION DEFAULT COLOURS GREEN, BLACK OPTION KEYBOARD PICOCALC OPTION PICO OFF OPTION CPUSPEED (KHz) 384000 OPTION LCDPANEL CONSOLE ,, FF00 OPTION DISPLAY 26, 40 OPTION LCDPANEL ST7365P, PORTRAIT,GP14,GP15,GP13 OPTION BACKLIGHT LCD 80 OPTION SDCARD GP17, GP18, GP19, GP16 OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5 OPTION RTC AUTO ENABLE OPTION MODBUFF ENABLE 192 OPTION PLATFORM PicoCalc OPTION PSRAM PIN GP47 Edited 2026-04-05 09:37 by toml_12953 |
I got it to work with this module (Peter's): ![]() I plugged a RP2350A-Zero pcb with ILI9341 LCD directly into one of the board's USB connectors, got recognition, did OPEN "COM3:9600" as #1 and then PRINT #1, "CLS RGB(BLUE)" and got a blue screen. But the PCB didn't supply enough power to do much more--it would restart. So now I'm looking for a USB-A to USB-A cable for my powered hub. I'm pretty sure I used one back in December for something. Found one--right in front of me, connecting to my USB-3 HDMI recorder. But it's not working with the powered hub, which has switchable USB ports. I switch one on, and nothing happens on the host. I tried another powered hub--no joy. Is this an issue of a hub being plugged into another hub (on the HDMI PCB)? Ok, I plugged the two into the HDMI PCB. Then: > open "com4:9600" as #2 > print #1,"Text mm.hres/2,mm.vres/2,"+chr$(34)+"Testing COM3"+chr$(34)+",C,,3" > print #2,"Text mm.hres/2,mm.vres/2,"+chr$(34)+"Testing COM4"+chr$(34)+",C,,3" ![]() Pretty nifty. So how do you power locally? ~ Edited 2026-04-05 11:20 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| mozzie Guru Joined: 15/06/2020 Location: AustraliaPosts: 469 |
G'day, From memory (could be faulty) you cannot connect more than 1 USB hub, either in series or parallel, to the PicoMite USB host, maybe try a bare PicoMite with just the powered hub, and USB to serial for console. YMMV Regards, Lyle. |
One line fix for editor bug for TFT versions - no version change PicoMiteV6.02.02B0.zip The PicoMite supports 2 hubs. This allows a Raspberry Pi keyboard with its in-built hub to be plugged into the HDMIUSB reference board hub Edited 2026-04-05 17:42 by matherp |
Does that mean that in theory, my plugging a powered hub into a USB port on the HDMIUSB reference board should work? PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Try it and tell us. From the manual This is because the USB protocol stack cannot reset the hub and it may be confused if the power on the Pico is cycled without doing the same for the hub. The hub can also be confused if devices are swapped while the hub is powered. If this happens you should cycle the power on the Pico followed by the hub then add the USB devices one by one. |
| terekgabor Senior Member Joined: 02/01/2026 Location: HungaryPosts: 155 |
OPTION FLASH SIZE 16777216 OPTION LIBRARY_FLASH_SIZE 51000 These are I haven’t found in documentation. How to use them? Thx! |
For info only |
Thanks! |
What versions run the MANDELBROT command? Only the VGA and HDMI versions? The LCD version doesn't seem to understand it. |
Does for me. |
Does for me. Yup, it does. I don't know what I was donig wrong before. Oh, now I see it in the previous sentence. |
G'day, Oops, I learn a new thing every day Have tested many variations of Picomite over USB-CDC and so far very impressed, this opens up many possibilities Also plugged in several kinds of USB-Serial converters, no joy so far with any although some do show up as a CDC device. Is this because the baud rate etc needs to be set from the host device unless it defaults to a known value. More testing to follow. Further to this, would there be a possibility of adding support for the Microbridge? this is built into many MMite projects and would make communicating with these a breeze as well. I realize there are 1000's of different USB-Serial devices out there, however the MicroBridge is a known entity. Thanks again. Regards, Lyle. |
The baud rate from the PicoMite USB port is that of the USB (probably 1.5 Mbps, but 12 Mbps is also a standard for USB 1.1 if you reduce the cable from 9m to 3m). The COM ports don't support handshaking (unless you write your own). Therefore any USB-serial converter will have to buffer the data and slow it down to a known baud rate to be useful. That means that they will have to be "intelligent" devices, not simple "converters". COM3-6 aren't really conventional COM ports, they are a bridge to USB. I think the ESP32 sometimes has USB CDC ACM built in. If so, that opens up the possibility of high speed links directly to those. . Edited 2026-04-07 00:51 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Page 1 of 8 |
