Local Time 22:34 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Coming soon....
Posted: 01:49pm 04 Apr 2026
4 channel CDC host capability alongside the normal USB keyboard/mouse/gamepad support
PhenixRising
Posted: 02:51pm 04 Apr 2026
oh great, now we have another zillion possibilities to keep me awake at night
PhenixRising
Posted: 03:57pm 04 Apr 2026
Does this mean that a PicoMite can talk to four other PicoMites via their USB ports?
Posted: 04:06pm 04 Apr 2026
Yes
Peter63
Posted: 04:22pm 04 Apr 2026
/Peter63
mozzie
Posted: 04:31pm 04 Apr 2026
G'day Peter,
A huge thank you for this, it's been on my wish list since the very first PicoMite USB firmware was mentioned
Lyle.
PhenixRising
Posted: 05:53pm 04 Apr 2026
This is insane. Might need to go grab a beer and ponder the possibilities 🍺
javavi
Posted: 06:29pm 04 Apr 2026
Awesome!
Is it possible to do something else so that you can connect a USB Flash drive to a hub and have it available in the system as drive C:?
Edited 2026-04-05 04:43 by javavi
Posted: 11:41pm 04 Apr 2026
I guess USB laser-printer support will be next......
You amaze us all, Peter.
Posted: 07:09am 05 Apr 2026
I doubt if it will handle USB devices that aren't actually serial. That would rule out all types of USB flash drives, USB printers etc. Also, you can't set the baud rate so it's not something you could connect to a serial printer.
Time to plug some USB drives into a Raspberry Pi and turn it into a modernised  Commodore 64 disk drive. :)
Posted: 12:30am 06 Apr 2026
Well, I WAS joking about that, Mick!
Posted: 07:00am 06 Apr 2026
I wasn't. :)
I think the possibilities of a high speed serial-controlled usb-connected (preferably) drive are definitely there. You need a command structure to talk to the Pi to give it commands and get it to accept or send data over the link. Obviously it needs to be set up to use its USB system in a suitable mode and respond to those commands. You could then access whatever drives or devices that could be plugged into a Pi. No need for the latest and greatest either, a Pi 3 or 3B would probably be adequate as a file server. Of course, this may not be possible. I don't know enough about the Pi. Or much else, for that matter. lol I do know that the Commodore 1541 floppy drive was on their own serial version of the IEEE-488 interface though.
bfwolf
Posted: 10:17am 06 Apr 2026
A 1541 floppy emulator already exists for the Raspberry Pi.
https://cbm-pi1541.firebaseapp.com/
However, an ATMEGA1284 is sufficient for this.
https://www.c64-wiki.de/wiki/SD2IEC
https://www.sd2iec.de/
And I just found this: Someone is working on a solution using a Pi-Pico:
https://rastertail.net/scm/pico1541.git/tree/
By the way: Happy Easter everyone!
Posted: 12:44am 07 Apr 2026
  Mixtel90 said  I wasn't. :)
LOL!
