Forum Index : Microcontroller and PC projects : Video news briefs
| homa Guru Joined: 05/11/2021 Location: GermanyPosts: 723 |
You're away for a few days and miss out on all the cool new features (PicoMiteHDMI MMBasic USB RP2350A). For anyone else who's in the same situation, here's a quick video summary of the news. I finally got round to testing my video grabber (HDMI and VGA! - Colour Maximite 2 is also possible). I hope it helps some of you. https://youtu.be/0g14Llv0SuA - Breakout https://youtu.be/Hh9D13UEVrY - GamePlatform https://youtu.be/YT_DTjbK3bw - Blit RESIZE abused ;-) https://youtu.be/KgFP00FgVPA - Vectorball Matthias PS Videos are so much more entertaining than photos, right? Edited 2026-03-13 08:03 by homa |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10073 |
Good stuff. Yes, videos are better then still images. ![]() Smoke makes things work. When the smoke gets out, it stops! |
@Martin H. ccast1.zip - https://www.thebackshed.com/forum/ViewTopic.php?TID=18619&P=5#251759 I set resStep=4 here and inserted numbers into the graphic to see what the quality is like. I noticed that the back is mirrored ;-) https://youtu.be/L9PwrDNqu_Q Matthias |
Thanks a lot. |
https://youtu.be/JUeAbKCXSnA - road @Martin H. - thx! |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1573 |
Looks good at 315MHz... I've commented on it Edited 2026-03-26 19:03 by Martin H. 'no comment |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 667 |
Brilliant |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 252 |
Great job Martin H. - looks better than Pole Position on the Atari 8-bit computer. |
Homa, Your Blit Resized demo looks like your half-way to BallBlazer! |
Here is missing Petscii Robots Video by "Volhout and the Backsheds" I recorded that back then using a simple VGA-to-HDMI adapter connected to an HDMI grabber, and then captured it with OBS. There was a lot of lag while playing, so I often end up missing my targets Unfortunately, the audio got very quiet along the way 'no comment |
That was exactly the idea behind it: the entire ground is generated from the two lines in the middle, and the speed would be high enough to display an additional “viewport” for a second player or NPC. The extra enhancements from vegipete really let the player glide. The rules in BallBlazer aren't overly complicated; they should be possible to replicate in Basic. 'no comment |
https://youtu.be/HQb_nPCfa1Y - GEMS'n'ROCKS Hi Martin, I’ve also captured your GEMS'n'ROCKS (on PicoMiteHDMI). When I have time , I might do the same with all the animated graphics. The “PicoMiteVGA DEMO” with moving graphics is pretty cool, too. Matthias |
