Local Time 22:48 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Been thinking about a SticoMite
PhenixRising
Posted: 08:28pm 10 Mar 2026
I have seen Stick PCs with a male HDMI that plugs directly in to the monitor.
Anyone seen something that already exists with a Pico?
My application is a standalone display.
dddns
Posted: 08:39pm 10 Mar 2026
Almost
PhenixRising
Posted: 11:23pm 10 Mar 2026
Hey, close enough
Many thanks, bud.
IanT
Posted: 11:37pm 10 Mar 2026
These work wiuth the Pico2 adapter Mick designed...
Waveshare HDMI displays
IanT
Posted: 01:17am 11 Mar 2026
Nice, but aren't resistors recommended?
Also here: Pico DVI sock
Resistors shown:
3 for $11.37 USD, shipping included
This makes many Pico PCB designs DVI/HDMI capable with Pico2s.
Edited 2026-03-11 11:37 by lizby
PhenixRising
Posted: 11:40am 11 Mar 2026
Perfect
Edited 2026-03-11 21:40 by PhenixRising
Posted: 01:26pm 11 Mar 2026
  PhenixRising said
  lizby said  This makes many Pico PCB designs DVI/HDMI capable with Pico2s.
Perfect
Don't forget the Pico2 16mb PSRAM version
Edited 2026-03-11 23:27 by lizby
PhenixRising
Posted: 02:25pm 11 Mar 2026
Looks like it still has micro-USB (?)
mozzie
Posted: 02:49pm 11 Mar 2026
G'day,
This was knocked together during early testing with HDMI, rather crude but it does the trick.
Plugs straight into just about anything, the HDMI plug breakout is widely available.
Apologies for the crap photo, cropped from an old image.
Lyle.
Posted: 08:45pm 21 Mar 2026
DVI sock working with the WeAct RP2350A module with 15MB on drive a:
(Looks like it might not be too hard to solder a PSRAM chip on this module.)
Edited 2026-03-22 06:46 by lizby
PhenixRising
Posted: 11:31am 23 Mar 2026
This is perfect
Posted: 12:57pm 23 Mar 2026
  lizby said  DVI sock working with the WeAct RP2350A module with 15MB on drive a:
The flash chip is a wide-body, 208 mil, and I can't find a PSRAM chip that size. I'm not going to be soldering a bunch of wires--the soldering would have been hard enough for me anyway--so I'll wait. It can't be too long before the Chinese cloners do their work on the Pimoroni model.
Posted: 03:33pm 23 Mar 2026
I say again the magic incantation: "PGA2350"
It's not that much bigger than a Pico and includes PSRAM.
Or there's the Pimoroni Pico Plus 2, which also has 16MB flash, the RP2350B and PSRAM (on GP47) fitted and is pin compatible with the Pico 2.  Obviously it doesn't bring out all the pins of the RP2350B!
Posted: 03:53pm 23 Mar 2026
  Mixtel90 said  I say again the magic incantation: "PGA2350"
Are you talking about a chip? The goal here is the PicoStick with HDMI and PSRAM. The Pimoroni is expensive (by picomite standards). That's what I'm willing to wait for the cloners to address. Shouldn't be more than $6-$7.
Posted: 06:06pm 23 Mar 2026
It's another Pimoroni module. 1 inch square.
Link
I know what you mean about the clones. Whether they'll bother is something else though, WeAct do the 48-pin module but don't include PSRAM, although they could easily. The problem may be that it costs extra to populate both sides of a board and you need very short traces for RAM, which is why it's on the bottom. It's all a case of how cheap can they make them.
Posted: 06:15pm 23 Mar 2026
  Mixtel90 said  It's another Pimoroni module. 1 inch square.
Not exactly PicoMiteStick-friendly.
Posted: 08:17pm 23 Mar 2026
Only because no-one has designed one yet. :)
Yes, it would end up an inch wide. It might possibly be slightly shorter though, if you don't mind some SMD work.
dddns
Posted: 08:28pm 23 Mar 2026
  lizby said  Shouldn't be more than $6-$7.
Maybe this waveshare is easier to get and cheaper in the US. The USB-C adapter is also nice. Too bad it has a slightly different layout compared to the PGA.
For a stick I think the slim standard design is best, maybe with a thin sandwich PCB containing a basic audio filter for PWM sound, a 3231 RTC in the middle and on the other a microSD..should be doable even on a stripboard.
Edited 2026-03-24 06:47 by dddns
Posted: 09:37pm 23 Mar 2026
  dddns said  For a stick I think the slim standard design is best
Absolutely. With the DVI "sock", it's a doodle which works on all the 40-pin Pico2 modules. Most probably wouldn't need the PSRAM, but I have a use for it.
dddns
Posted: 10:33pm 23 Mar 2026
Well, @mozzie showed a real stick. But HDMI/VGA doesn't have +5V so you need the USB cable anyway and thus a stick isn't that necessary. The PGA/Waveshare is 4,4mm larger, not that much ;)
The HDMI breakout board directly soldered is IMHO in any way a nice solution.
