Local Time 23:15 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : pico hdmi usb mouse cursor
tenij000
Posted: 12:36pm 08 Mar 2026
can mouse the mouse around then can see where it is by the numbers but dont have acursor if use circle for example it draws it all over the screen
is way to set picture as a background pic above that then maby i can delete old cursor pic if mouse moves
twofingers
Posted: 01:35pm 08 Mar 2026
Sprites?
Michael
Peter63
Posted: 01:57pm 08 Mar 2026
Check out the Paint program, maybe you can get some ideas.
https://www.thebackshed.com/forum/ViewTopic.php?TID=17589&PID=232395#232395
/Peter63
Edited 2026-03-09 00:05 by Peter63
Peter63
Posted: 03:27pm 08 Mar 2026
Hello, tenij000
Test this program:
' Program: m-sprite.bas
' program to make a mouse sprite.
' Version: 2026-03-08 / Peter63
' used: PicoMiteHDMI MMBasic USB RP2350A Edition V6.02.01RC2
MODE 3
Font 1
' activate mouse cursor (create mouse-sprite file, if missing)
On error skip 1
Sprite load "mouse.spr",1,1
If MM.Errno Then
 Print "Mouse-sprite file created... wait..."
 make_sprite_mouse ' create mouse cursor
 Pause 3000
End If
CLS
Color RGB(white),RGB(black)
Text 100,0," MOUSE-SPRITE TEST-PROGRAM ,  ESC=QUIT PROGRAM "
Text 100,16," USE LEFT MOUSE BUTTON, AND RIGHT MOUSE BUTTON "
xold=-9999:yold=-9999
' -------- MAIN LOOP: START  --------
t=Asc(Inkey$)
' get mouse info
x=DEVICE(mouse 2,X)
y=DEVICE(mouse 2,Y)
lm=DEVICE(mouse 2,L) ' left mouse button
rm=DEVICE(mouse 2,R) ' right mouse button
mm=DEVICE(mouse 2,M) ' middle mouse button
dd=DEVICE(mouse 2,D) ' double click of the left mouse button
If xold<>x Or yold<>y Then ' show mouse on screen
 Sprite show 1,x,y,1
 xold=x:yold=y
End If
If lm Then ' check if left mouse button is pressed
 Sprite hide 1
 Circle x,y,20,1,1,RGB(red) ' print a circle to screen
 Sprite show 1,x,y,1
End If
If rm Then ' check if right mouse button is pressed
 Sprite hide 1
 Circle x,y,20,1,1,RGB(black),RGB(black) ' filled black circle
 Sprite show 1,x,y,1
End If
Loop Until t=27
' -------- MAIN LOOP: END  --------
End
' --- make a sprite mouse file "mouse.spr" ---
Sub make_sprite_mouse
Open "mouse.spr" As output For #1
Print #1,"16,1"
Print #1,"FFFFFF0000000000"
Print #1,"FF00000000000000"
Print #1,"F0F0000000000000"
Print #1,"F00F000000000000"
Print #1,"F000F00000000000"
Print #1,"F0000F0000000000"
Print #1,"000000F000000000"
Print #1,"0000000F00000000"
Print #1,"00000000F0000000"
Print #1,"0000000000000000"
Close #1
/Peter63
tenij000
Posted: 03:43pm 08 Mar 2026
cool thx :)
Posted: 08:29pm 08 Mar 2026
  Quote  Open "mouse.spr" As output For #1
  manual said  Open "mouse.spr" For output As #1
But both work without error.
Edit.
"Pause 3000" can be reduced to "Pause 100" and still have time to spare.
Edited 2026-03-09 08:09 by phil99
Peter63
Posted: 03:27pm 09 Mar 2026
Hello, phil99
Yep in "open" it should be As #1 and not For #1 as I have written.
One could also create the mouse.spr file every time without checking if it already exists. The program would be a bit shorter then, I think.
/Peter63
