Local Time 23:14 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EXECUTE command$
PhenixRising
Posted: 09:12pm 28 Feb 2026
Looks like it could be useful but how is it used.... typically?
Is it a more efficient approach than something else?
I have the feeling that I'm missing-out
Posted: 09:43pm 28 Feb 2026
I'm using it right now in a program with video output so that a user can arbitrarily inject a command, especially for debugging, by typing at the console, e.g., "!test Execute print a$, b$, c$" or "!test EXECUTE someSubroutine.
It can also be useful for injecting a command into a 2nd connected Picomite. Here's a program from some years back in which a picomite connected to a primary picomite receives serial (while perhaps running a program, not just listening) and in addition to executing canned routines on command, can submit EXECUTE some command if sent, say, "! some command": serial control of 2nd Picomite.
Note: it cannot be multiple commands separated by ":".
Posted: 11:34pm 28 Feb 2026
I think the Port command and function still require literal GP pin numbers, so to use a string variable for the Port command and function you need EXECUTE.
Eg. from keypad program.
For n=RowPinGP To RowPinGP+rows-1
  SetPin MM.Info(pinno "GP"+Str$(n)),DOUT 'set the Port out pins
Next
For n=ColPinGP To ColPinGP+Cols-1
  SetPin MM.Info(pinno "GP"+Str$(n)), INTH, Key.Pad, PULLDOWN 'set the Port input pins and ISR
Next
   Execute "Port(GP"+Str$(RowPinGP)+",rows) = 1 << y" 'set the row to read
   Execute "x=Port(GP"+Str$(ColPinGP)+",cols)" 'read the columns
Though in the latest firmware you could probably simplify that a bit.
PhenixRising
Posted: 10:43am 03 Mar 2026
So, for example:
-I have two PicoMites that are UART linked, Pico #1 and Pico #2
-Pico #2 has a var named cntr
-Pico #1 would like to know the value of cntr on Pico #2
-Pico #1 sends a command$ = "print #[comport], cntr" (to Pico #2)
-Pico #2 EXECUTEs the command$ thus sends the value of cntr to Pico #1
If this is true then presumably Pico #1 can also change the value of a var on Pico #2?
This is exciting....if I understand it correctly
Posted: 01:23pm 03 Mar 2026
  PhenixRising said  presumably Pico #1 can also change the value of a var on Pico #2
Absolutely. The thread I linked to goes over this in some detail. There's a bit of complicated parsing on the part of Pico #1 to get the answer back confirming that the command it sent was executed.
PhenixRising
Posted: 02:15pm 03 Mar 2026
Oh man, this is one of those "I wish it was possible" things for me and I was just about to start doing it the long-winded way.
I'll string a couple together
PhenixRising
Posted: 02:26pm 03 Mar 2026
Wrong thread
Edited 2026-03-04 00:29 by PhenixRising
circuit
Posted: 09:54am 04 Mar 2026
I was very excited when the EXECUTE command appeared and saw it as most uncomplicated way of controlling several PicoMites that are running different tasks on a simple network.  I have a master 2350 with a USB keyboard using a simple serial link to the other PicoMites.  Keyboard errors are ignored, as are calls to PicoMites other than the one with the appropriate subroutine on board that I am calling.  For me, it is wizard stuff.  I just wish that the EXECUTE command could be retrospectively installed into the MicroMite series; MX270, 470, MZ series and so forth.  I tried to get AI to write me a CSUB without any success.
'Picomite Simple Serial Master
Option AUTORUN ON
SetPin GP1,GP0,com1 '
Open "com1:115200, 256" As #1
'program the commands here onwards...in the form PRINT #1,"COMMAND+PARAMETERS"
And on the remote picomite
'Picomite Simple Serial Client
Option AUTORUN ON
Dim string cmd
SetPin GP1,GP0,com1 'Set up comms channel 1
Open "com1:115200, 256, ActionCommand, 3" As #1
WatchDog 500        'This recovers from errors not ignored but resets the chip
Sub ActionCommand   'Message receipt detected
ON ERROR IGNORE     'This avoids system reset if duff command arrives
 Pause 30          'ensure all characters in command have arrived
 Line Input #1,cmd 'Get the command
 Execute cmd       'Action the received command
End Sub             'Return from the interrupt
PhenixRising
Posted: 11:59am 04 Mar 2026
Yeah, it's just what I need but in my case, I will prefix an 8bit node address. Need to get to my bench to try this. Pulled in all directions, right now.
dddns
Posted: 03:44pm 04 Mar 2026
Once I used it to dim variables and the variable names were sourced from a text file on a: or b:
