Local Time 23:27 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how do setup picomite hdmiusb ??
     Page 1 of 3
tenij000
Posted: 06:21pm 27 Feb 2026
out of the box the hdmi works how do activate sound and the sd card
and need the correct firmware i try the newest firmware from the webpage then cant do
Posted: 06:46pm 27 Feb 2026
Which PicoMite board are you using? They vary.
tenij000
Posted: 06:53pm 27 Feb 2026
Reference Design for HDMI/USB Computer
Posted: 06:58pm 27 Feb 2026
It's in the instructions for that board on Geoff's site.
  Quote  Final Assembly
Solder the Raspberry Pi Pico 2 direct to the motherboard ensuring it is completely tight to the PCB
On the rear side of the board there are 4 holes without solder mask. Apply liquid flux to these and
solder through them. These connect the USB programming micro-USB, Pin GP23, and improve cooling
for the USB HUB chip.
Then:
• Leave all jumpers off the board and insert a micro-USB into the PROG connector
• Load up the HDMIUSB firmware (V6.00.00b10 or greater) then remove the microUSB connector
• Install jumpers to enable the USB hub circuit (1 to 2 and 3 to 4)
• Install jumpers to enable the SDcard (default is GP26, GP27, and GP28)
• Install a CR2032 battery
• Connect a USB-C cable and an HDMI cable and press the on/off switch
• The Raspberry Pi Pico 2 should create a virtual USB drive to which you should copy the firmware
file “PicoMiteHDMIUSBV6.00.01.uf2”. See the PicoMite User Manual for more details.
• You should then get the Copyright logo on the screen
• Type "OPTION RESET HDMIUSB" to fully configure the board and you are good to go.
The onboard USB hub allows you to connect up to 4 USB devices, keyboards mice, gamepads. A green
LED adjacent to the USB connector will light up to indicate they are operational. See the PicoMite User
That should configure eveything automatically. :)
tenij000
Posted: 07:01pm 27 Feb 2026
OPTION RESET HDMIUSB then get error
Posted: 07:15pm 27 Feb 2026
Have you got the right firmware installed? You'd better check as they are easily confused.
What error are you getting?
tenij000
Posted: 07:21pm 27 Feb 2026
can still use the sd card if only try the hdmi firmware whit out the usb
do then need to do option sdcard ?,GP26,GP27,GP28
Posted: 07:29pm 27 Feb 2026
No. There are never 3 arguments for the SDcard.
OPTION RESET HDMIUSB should set everything up, including the SDcard. It's specific to that board. If you are getting an error then what is it?
It's a HDMI USB board so both will be configured along with the sound and the SDcard.
Make sure you are following the instructions when setting it up. Once the USB is configured the socket on the Pico is in Host mode and can't connect to the console.
Bleep
Posted: 07:48pm 27 Feb 2026
Hi Mick,
It depends on the age of the Ref Design, the version with a Pico2 board soldered on was Option Reset HDMIUSB, However there was a later version, with a 2350 directly soldered to the board, which used Option Reset HDMIUSBI2S
It has I2S sound.
A Photo of the board would make it obvious.
Regards, Kevin.
tenij000
Posted: 07:51pm 27 Feb 2026
think fail so hard can only connect the board to micro usb then do firmware on the board no jumpers on board then if do the firmware pico hdmiusb on the board it is over
sofar do usb c cable in the board do the power switch a  COM port comes up i connect to it and it fails :( i give up on this picohdmi board maby i can donate my 4 unsoldert boards from jlcb then place all the parts on it missing leds that command says got wrong firmware whit this board so dont think ever gone work
Edited 2026-02-28 05:52 by tenij000
Posted: 07:53pm 27 Feb 2026
In theory it's this one, but of course he could have built the other. :)
Without the error message, at least, I can't really help any further.
Edited 2026-02-28 05:53 by Mixtel90
tenij000
Posted: 08:02pm 27 Feb 2026
yes it is
tenij000
Posted: 08:06pm 27 Feb 2026
now stuck here cant login to the board only what working if use the hdmi firmware whit out the usb
Posted: 08:19pm 27 Feb 2026
Those boards do work.
If you can't install the firmware, and the links at CN4 have been removed, then you are probably trying to install the wrong firmware. You are using a Pico 2 aren't you?
I hope I've got this right...  :)
Open File Manager so that you can see the list of MMBasic versions
Switch off the Pico board
Remove the CN4 links
Connect the USB-C on the Pico to the PC
Hold down BOOTSEL on the Pico and switch the Pico board on
Release BOOTSEL
You should see the virtual drive appear
Find the correct file and drag it onto the virtual drive.
(It will be called PicoMiteHDMIUSB - nothing else will work)
You should get a pop-up box while the file copies
After a few seconds the Heartbeat LED should start flashing
Unplug the USB lead from the Pico and move it to USB2
Replace the links on CN4 1-2 and 3-4
Connect a USB keyboard to one of the USB connectors
Switch on the Pico board
Start Tera Term and look for the new COM port. Connect to it at 115200 baud
You'll probably get a blank screen. Press Enter a couple of times and you should see the ">" prompt.
Enter OPTION RESET HDMIUSB
Try OPTION LIST and you should see things that make sense.
Now you can connect your HDMI display, where you should see the same thing as the console. You may want to change your keyboard language.
At this point the console isn't really being used so you can carry on working with the HDMI display.
I'm sorry if I've messed up any of the above, but It's been ages since I set mine up and my memory isn't what it once was. :)
tenij000
Posted: 08:21pm 27 Feb 2026
maby still use the board if can figure out what that command does
try this firmware
Posted: 08:24pm 27 Feb 2026
You can't use the USB display until it's been set up by OPTION RESET HDMIUSB. You will be in the console until then. The console is on USB2, NOT the USB port on the Pico - that's in host mode as soon as MMBasic starts. It's also disconnected from the USB-A ports until you put the CN4 links back.
Use the HDMIUSB firmware and follow my instructions. Don't use the HDMI firmware as there is no default keyboard if you use that. The board is designed for a USB keyboard.
Edited 2026-02-28 06:27 by Mixtel90
tenij000
Posted: 08:26pm 27 Feb 2026
PicoMiteHDMI MMBasic RP2350A Edition V6.02.00
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION RESOLUTION 640x480 @ 252000KHz
if use the hdmi version but now how do gues the cs pin for the sdcard
Bleep
Posted: 08:27pm 27 Feb 2026
As Mick says the Option reset hdmiusb will setup all options. I think another possible problem might be you have not, or not well enough, put solder through the 4 holes on the back of the board, as the instructions say in the first paragraph. These holes need to make contact with the Gold plated pads on the back of the Pico, if they do not, the USB will not work.
I fed a reasonable amount of solder onto each hole, while holding the soldering iron in place for a good 5 seconds, if still not working, try for longer. But don't damage the PCB.
Regards Kevin.
Edited 2026-02-28 06:30 by Bleep
Posted: 08:28pm 27 Feb 2026
What's written on the bottom of the PCB? Anything?
tenij000
Posted: 08:29pm 27 Feb 2026
Edited 2026-02-28 06:33 by tenij000
     Page 1 of 3
