Local Time 23:27 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Proposed change to PicoMite: remove A: drive filename case sensitivity
Posted: 07:02pm 24 Feb 2026
One of the oddities of MMbasic is that filesnames on the A: drive are case sensitive. Nothing else is. This means that HELLO.bas is different to hello.bas is different to hello.BAS etc. Filenames on the B: drive are not case sensitive and doing something like copying a directory from A: to B: which contains both "HELLO.bas" and "Hello.BAS" will probably result in one of them going missing.
Unless anyone strongly objects, I propose to remove the case sensitivity of LFS on the A: drive.
Is this OK?
Posted: 07:11pm 24 Feb 2026
I'm all in favour.
circuit
Posted: 07:45pm 24 Feb 2026
I agree - a sensible approach.
bfwolf
Posted: 09:47pm 24 Feb 2026
How do you plan to do that? I don't recall seeing a configuration switch like "IGNORECASE" when I used LittleFS in a project, and I just checked again and couldn't find anything about it in either the documentation or the source code.
One possible solution would be a dynamic option that converts all path names from MMBasic to lowercase before passing them to LittleFS.
But existing files with mixed case would then be invisible/inaccessible.
All in all, changing that is a delicate matter!
The oddity is actually inherent in FATFS, which only supports "ignorecase". I think I saw somewhere that NTFS can also be case-sensitive. Case sensitivity is standard for Unix filesystems anyway.
Regards, bfwolf.
Posted: 10:27pm 24 Feb 2026
  Quote  But existing files with mixed case would then be invisible/inaccessible.
Presumably the introduction of this would involve a firmware update that will erase A:, as some previous ones have, so there won't be any existing files.
  Quote  Case sensitivity is standard for Unix filesystems anyway.
And that is fine as it does so consistently, but on the Pico there is inconsistency.
In MMBasic and B: case is ignored so a change makes sense.
As for the method of changing it another possible solution, with the aid of Claude, may be to change LittleFS itself, rather than the interface to it.
Converting all path names from MMBasic to lowercase before passing them to LittleFS may require a place to store the names with case intact to match the way B: behaves.
For the user interface it displays the original character cases. A hidden file that mirrors the FAT / ToC but with cases preserved might work.
No doubt Peter will find the best method.
Edited 2026-02-25 10:36 by phil99
Posted: 06:14am 25 Feb 2026
Since mmbasic is in essence case ignorant, it is best the a drive also is.
My 5 cents
P.S. The only case sensitivity that sometimes catches me is when I have a file that is EDIT-ed at a CMM2. Because default it save the file with upper case ".BAS" extension. And MMEdit in default configuration on Linux ignores .BAS files, it expects .bas (lower case). But that may be more of a Linux (case sensitive) thing than MMBasic or MMEdit.
Edited 2026-02-25 18:45 by Volhout
Peter63
Posted: 12:09pm 25 Feb 2026
  Quote  Is this OK?
Yes, from me / Peter63
Posted: 12:19pm 25 Feb 2026
Linux does tend towards lower case by default (a bit like ordinary writing like this does).
MMEdit could easily have a setting to use .BAS or anything as needed (sorry Jim, more work).
Posted: 08:43pm 25 Feb 2026
Not really any more work for me.
MMEdit already has the option to "use *.* for file selector" in Preferemces.
That is the best I can do.
Windows is happy finding all caSes with ".bas" and I am not going to try and add .Bas, .baS etc when *.* is already available.
Posted: 12:48pm 26 Feb 2026
Maybe that's all Harm needs.
