Local Time 23:40 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : gone build the ref hdmi board
tenij000
Posted: 05:18am 20 Feb 2026
wondering why not made the spot where pico2 goes no holes
tenij000
Posted: 05:33am 20 Feb 2026
those ports1 to port4 are those needid ? just leds ?
Posted: 05:34am 20 Feb 2026
The Pico2 is intended to be soldered directly to the PCB.
The reason is the USB pads are on the underside of the Pico module. On the PCB the pads that align with them have holes so you can feed solder in to make the join.
There should be complete instructions In the "Other Downloads" section here https://geoffg.net/picomitevga.html
tenij000
Posted: 06:13am 20 Feb 2026
can also use pico 2 w on the pcb
Posted: 06:48am 20 Feb 2026
No, the WiFi code takes enormous resources.
Simply not enough left for HDMI or VGA.
