Local Time 23:53 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : picomite play modfile  what are the specs for the modfiles
tenij000
Posted: 10:36pm 12 Feb 2026
play modfile
wondering what are the specs for the modfiles can use
Posted: 08:12am 13 Feb 2026
Hi tenij000,
I cannot tell you the exact specifications, but all the MOD files I tried from internet (the mod archive) seem to work on PicoMite.
There is only 1 requirement I know of. The MOD buffer should be sized to hold the MOD file.
OPTION MODBUFF ENABLE xxx
Where xxx is the size in kilobytes. This will be subtracted from the size of the A:/ drive. Default the MODBUFF size is 128kbyte, but some platforms use
OPTION MODBUFF ENABLE 192
So you can play up to 192kbyte sized MOD files. Such as the 180kbyte sized MOD files in PETSCII ROBOTS.
Martin H.
Posted: 08:42am 13 Feb 2026
An Amiga MOD file is a tracker-based music module, featuring
up to 31 raw 8-bit signed PCM samples, 4–32 channels (originally 4, matching the Paula chip), and pattern-based sequencing. It defines instrument samples, pitches, and effects within 64-row patterns, historically using "M.K." or "FLT4/8" signatures for 15 or 31 instrument trackers like ProTracker.
Technical details see The Amiga MOD Format (berkeley)
'no comment
Posted: 10:15am 13 Feb 2026
Hi Martin,
The sample can be used as a note (i.e. piano). What note is assumed that sample represents ? a C3 ?
Martin H.
Posted: 10:47am 13 Feb 2026
  Volhout said  Hi Martin,
yes, When I play the instruments for the sample myself, I always try to sample a C2 or C3 note. However, as far as I can see, you also have the option in the sample editor to assign the sample to a note.
Martin
'no comment
