Local Time 23:53 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GWBASIC MERGE
Frank N. Furter
Posted: 07:31pm 12 Feb 2026
is there something like the GWBASIC MERGE command in MMBASIC? I would like to load small code snippets (which are not worth loading into the library) into a current program.
Frank
twofingers
Posted: 08:04pm 12 Feb 2026
Hi Frank,
if you're using an HDMI version,
have you tried my version of the HDMI-FileManager (Javavis FM)?
Or the MERGE function (alt F9) of the FileManager?
https://www.thebackshed.com/forum/ViewTopic.php?TID=17283&P=20#246808
Best regards
Michael
Shouldn't the built-in editor in version 6.020 already be able to do that, or have I missed something?
Edited 2026-02-13 06:13 by twofingers
Bleep
Posted: 08:20pm 12 Feb 2026
Built in editor.
"Finally, F9 can be used to INSERT the contents of a file at the current cursor position. Press F9 and you will be prompted for the name of a file and when you press return the file will be INSERTed."
Frank N. Furter
Posted: 09:18pm 12 Feb 2026
@twofingers:
I use miniFM from dddns ( https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=18365  )
@Bleep:
I have version V6.02.00 here – unfortunately, the editor does not respond at all when I press F9 or ALT + F9...
Frank
twofingers
Posted: 09:40pm 12 Feb 2026
Hi Frank,
if you're feeling adventurous, you could tr upgrading mini-FM by adopting the merge function from my HDMI version. However, the data structures are somewhat different. I'm confident you can manage it easily, though.
Another option would be the Klingon version (fmvt0203-Klingon.zip) of FileManager, which apparently includes the merge function and should at least work with Teraterm.
In my HDMI version, I'll probably also remove the cut/merge and replace functions, as they're redundant due to the new editor features.
Bleep
Posted: 10:18pm 12 Feb 2026
There was an update to 6.02 this was done around the 26th Jan, maybe try re-download it.
link
Edited 2026-02-13 08:19 by Bleep
Frank N. Furter
Posted: 06:28pm 14 Feb 2026
@twofingers:
I'm afraid you're overestimating my programming skills.
@Bleep:
Thank you for pointing that out – that was the reason why F9 wasn't working for me.
Frank
