Local Time 00:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - version specific commands
Posted: 08:57am 26 Jan 2026
Attached is a html file that identifies all commands that aren't universally available. Just open this file on your computer using a browser
Commands.zip
Posted: 09:29am 26 Jan 2026
@Peter,
Thanks for the overview.
It may need a bit of tuning. Example: I can use Backlight in mt RP2040 GEEK, which the overview says I can not.
Posted: 10:57am 26 Jan 2026
Is it fair to expect a non-pico board such as a RP2040 GEEK, RP2040-Zero, YD-RP2040 etc. to always behave as expected? :)
Posted: 05:10am 27 Jan 2026
Thanks for that Peter, it will be useful.
Can you ask Claude to rethink the STAR command "Star shape drawing"
Posted: 07:05am 27 Jan 2026
  Mixtel90 said  Is it fair to expect a non-pico board such as a RP2040 GEEK, RP2040-Zero, YD-RP2040 etc. to always behave as expected? :)
@Mick,
The GEEK uses the normal microcontroller picomite image (non VGA). That picomite image supports a variety of LCD panels (also the GEEK). And these LCD panels have BACKLIGHT. So it is a mistake that the microcontroller image, according that list, does not support the BACKLIGHT command. It does.
Edited 2026-01-27 17:05 by Volhout
Posted: 08:28am 27 Jan 2026
Ah, I see. :)
