Forum Index : Microcontroller and PC projects : Imposible entrar en http://geoffg.net
| kermess Regular Member Joined: 04/04/2013 Location: SpainPosts: 50 |
Good morning. I don't know what I'm doing wrong, but for about two or three weeks now I haven't been able to access the "Geoffg" website, http://geoffg.net. Does anyone have any idea what the problem might be? I've tried it from Chrome, Opera, and Edge, and it's impossible to access in all three cases. This is happening to me from Barcelona, Spain. Thank you very much. |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 361 |
Good morning, works for me (Germany) in Firefox and Chrome Best Thomas |
| Supertech Regular Member Joined: 13/11/2016 Location: AustraliaPosts: 67 |
Supertech from Australia @ 5:57pm, indeed good morning. Try:- https://geoffg.net/webmite.html Then navigate to where you want to go. Otherwise, try rebooting your router or internet box provision. Its most likley a DNS blockage or error at your end dependant on your WAN ISP DNS provision. Note also, not HTTP, but HTTPS as above. As at above time, site is live. Regards. |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1573 |
I can confirm that, Gummersbach/Germany. No problems opening the website. It could be a DNS problem with your provider or router. Cheers Martin 'no comment |
The site is really https not http, though my browser auto-selects the https. If even that fails, try a different browser or even the tor one. John |
If you do a search for 'picomite basic' Geoff's site is usually top of the list. If you still can't get it that way then it's probably a problem with your ISP, which *should* be temporary. Mick Zilog Inside! nascom.info for Nascom & Gemini |
