Forum Index : Microcontroller and PC projects : 8 COM ports and 600MHz
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2100 |
A bit pricey (teensy 4.1) Edited 2026-01-20 21:15 by PhenixRising |
| darthvader Senior Member Joined: 31/01/2020 Location: FrancePosts: 101 |
Teensy 4.1 is old now Paul Stoffregen is looking forward for his successor , but nothing is sure for now. At first they spoke of the iMX RT1170 as successor , but now he say : And if Paul get more information , we will not be able to get any information because : But one is sure ... MMBasic on a teensy will probably be the most powerful of all voila ![]() Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 667 |
I have a few Teensy 4.1's and I really like them. Great USB support, but the best bit is the 600Mhz processor. I have one running some quite complex flame calculations. But I do struggle to find a use for them in most projects because of the price. But if you need raw processing speed - then these are the best I've found so far. I have been mulling over using one as a network hub for multiple CMM2's. So, it would provide a central storage unit (SD Card), internet access and shared memory that could be accessed via RS-232/Com. Sort of like a mini-mainframe. I did even think about shunting some of the processing onto the Teensy - but the CMM2 is so fast, that I don't think there would be a huge advantage - besides, with this setup you could shunt some of the processing off to other CMM2s. So this would either be for a small multi-processor computer or a distributed network (like Mainframe terminals, except the bulk of the processing would be done on the terminals). |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6195 |
Pete, Is the teensy 4.1 more powerfull than the STM32H743 on CMM2 ? The clock speed is not that much higher (600 vs 500MHz). It feels they are all in the same ballpark (Teensy, Beaglebone, STM32H series). Volhout Oops, the AM3358 on the Beaglebone the leader of the pack (DMIPS). Edited 2026-01-21 02:17 by Volhout PicomiteVGA PETSCII ROBOTS |
Sorry, I can't give a definitive answer to that, because I'm coding the Teensy in compiled C and the CMM2 in interpreted BASIC. So, the compiled C is always going to be significantly faster. Having said that, the CMM2 is so fast, that I don't feel that it's lacking in any power. And an extra 20% speed boost in processing might not make a significant difference to games etc. If you're asking if I feel MMBasic would be significantly better on the the Teensy 4.1, then my answer would probably be no. There have been supply issues with the Teensy in the past (it's not open source), and I know there is an ongoing dispute with AdaFruit over it. Edited 2026-01-21 02:43 by PeteCotton |
| vegipete Guru Joined: 29/01/2013 Location: CanadaPosts: 1185 |
The i.MX RT1180 is available in a 144 ball MAPBGA package. (And bigger ones.) How many layers do you need to break that out? Memory does not look expansive, so RAM and Flash would be needed. Runs on 3V3 with internal 1V8 regulator and other lower voltages. Max current is 1 Amp! It's available now at Digikey. So a custom board is not out of the question, but it doesn't seem worth it to me. Not when, say, an entire Pi Zero 2 is cheaper than just the RT1180 and easier to get. Visit Vegipete's *Mite Library for cool programs. |
@PeteCotton One SD card feeding multiple UARTs....great idea |
It all depends on how fast you want the UARTs and if you are using flow control. You could probably bitbang half a dozen on a PicoMite in MMBasic. :) Flow control (hardware or XON/XOFF) could let you freeze each data stream while you check the others - all on a single COM port with gated data lines. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Oh heck. Totally forgot about bit banging com ports but I think they are blocking??? No Tx buffers? |
Volhout has done a PIO Com Port |
Well, naturally 😁 |
