Local Time 00:39 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem programming Nano
Bryan1
Posted: 04:11am 19 Jan 2026
G'Day Guy's, Well as I said in my inverter build thread trying to program a new nano is just refusing to work.
First tried on my shed laptop running linux and no joy the same with my shed computer running win10.
So just now on my house computer running win10 downloaded the Arduino software and tried to program the Nano with the lcd code as before and still no joy.
so got Nano selected as the board
COM3 checked and working
old bootloader used
clicked the first entry on the programmer list.
Now this worked on my old computers before they died so with a fresh install of the Arduino with a board connected on 3 of my computers why does it refuse to program.
Regards Bryan
Edit: just went and tried on my good laptop and got the error programmer not responding. This was the same error on the other computers too
Edited 2026-01-19 14:47 by Bryan1
Bryan1
Posted: 06:04am 19 Jan 2026
Well lets just say going from a 275A mig welder back to a soldering iron was the culprit with having no luck went and got a new nano and it programmed first time and when I used my phone camera to look at what the leds are for saw 2 solder globs shorting the pins. So used my solder sucker and tried again and it programmed   Before the rx/tx leds were on and the arduino software went into a never ending loop.
Posted: 08:09am 19 Jan 2026
I'd have got rid of the Arduino IDE forever and dropped the welder on the Nano, but that's just me, I'm like that.   ;)
Sasquatch
Posted: 05:50pm 19 Jan 2026
Just FYI:
I recently purchased a batch of Nano clones with USB-C ports from China.  They seemed to be programmed with some kind of "BLINK" test code, but they wouldn't program with the Arduino IDE.  I finally flashed the latest bootloader onto them and now they are working fine.  Either they had no bootloader installed, or at least not one that worked with Arduino IDE (AVRDUDE?) China is like a box of chocolates, you never know what you are going to get!
-Carl
Bryan1
Posted: 09:19pm 19 Jan 2026
Well the grey cells did remember with these clones a driver was needed to get these chip to work but no way could I remember what driver it was. So onto google and soon enough remembered so downloaded that CH340 driver and today I can do a test on a win10 computer to see if that is the issue   or was it just my heavy hand trying to see what I was soldering.
I did convert a magnifier to led's and never set it up so thats a job to do for future soldering as one does need to see with these old eyes.
Regards Bryan
KeepIS
Posted: 10:42pm 19 Jan 2026
A ordered a few NANO USBC devices with no BL as I usually don't use a bootloader.
Quite often the sites obscure this using miniature text with yellow foreground on a white background.
The CH340 USB controller is usually a 16 pin chip, the FTDI controller "driver" is normally a 28 pin chip, baud rate is different between the Old and New Bootloaders, most Nanos can be upgraded to the new bootloader from the IDE which comes with the options to do so, from memory, you would need the little USBasp hardware programmer though, it's long time since I installed a bootloader.
The Linux Arduino IDE Version: 2.3.7 - Date: 2025-12-17 AppImage is brilliant, it works perfectly under Linux, the editor has crisp clear text, dark mode is perfect for me, it also loads, runs and programs fast, leaves the Windows version in the dust
Edited 2026-01-20 08:42 by KeepIS
Posted: 11:01pm 19 Jan 2026
Last time I got a blank Nano I found instructions on the Arduino site for using another Nano or Uno (that has a bootloader) as a programmer to load the bootloader to a blank Nano or Uno.
Edit.
Tried to find it on the Arduino site but the site has completely changed. Appears to be all about flogging products. If there is anything useful left in there it is well hidden.
Edited 2026-01-20 09:18 by phil99
KeepIS
Posted: 12:19am 20 Jan 2026
I still have that project on the old PC somewhere, but Jaycar USBasp Programmer at $14.95 is hard to beat in AU, some lower cost on Amazon etc, works brilliantly and is the fastest universal design that I tested.
Posted: 07:20am 20 Jan 2026
If you have a working nano/uno. There is also an instruction how to wire up the working one, to program a new bootloader in the bricked one. Using the UNO as a USBasp burner.
Posted: 07:39am 20 Jan 2026
Found some info:-
  Quote  Using an Arduino Uno as a USBasp programmer is possible by configuring it as an ISP (In-System Programmer) using the ArduinoISP sketch.  This allows you to program other ATmega microcontrollers (like the ATmega328P) without needing a dedicated USBasp programmer.
Steps to set up:
Upload the ArduinoISP sketch to your Arduino Uno via USB.
Connect the Uno to the target ATmega chip using the following wiring:
MISO → MISO
MOSI → MOSI
SCK → SCK
RESET → RESET
5V → VCC
GND → GND
In the Arduino IDE, go to Tools > Board and select the target board (e.g., Arduino Uno).
Go to Tools > Programmer and select Arduino as ISP.
Use Tools > Burn Bootloader to program the target chip.
✅ Note: This method works best with older IDE versions (e.g., 0022) for compatibility, especially with certain boards like the Metaboard. The Arduino Uno can act as a functional ISP, but it is slower than a dedicated USBasp.
Limitations:
The Arduino Uno must remain connected during programming.
Not ideal for frequent use due to speed and reliability constraints.
Some users report issues with newer IDE versions or specific chips (e.g., ATmega2560).
Edit, here is the sketch.
ArduinoISP.zip
Edited 2026-01-20 17:56 by phil99
