Local Time 01:06 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unintended GPIO output during start of program
Arne
Posted: 10:48am 18 Jan 2026
Is there an easy possibility to block the output of data to the GPIOs before/during setting of GPIOs as outputs. My code is as follows:
SetPin 24,dout
SetPin 25,dout
SetPin 26,dout
SetPin 27,dout
SetPin 29,dout
SetPin 31,dout
SetPin 32,dout
SetPin 34,dout
SetPin 11,dout
SetPin 12,dout
SetPin 14,dout
SetPin 15,dout
SetPin 16,dout
SetPin 17,dout
SetPin 19,dout
SetPin 20,dout
Port(11,2,14,4,19,2,24,4,29,1,31,2,34,1)=&B1111111111111111
If I start the program for approx. 5ms (during the SetPin - phase) unintended outputs to the GPIOs happen. A flickering of < 1 ms would be ok.
Any ideas ?
Arne
Posted: 11:06am 18 Jan 2026
The pins will be high-Z when the program starts. If important you would need pullup or pulldown resistors on your board
Posted: 11:23am 18 Jan 2026
> pin(1)=1 :setpin 1,dout :? pin(1):pin(2)=1 :setpin 2,dout :? pin(2)
1
1
So you could try:-
Pin(24)=1 : SetPin 24,dout
Pin(25)=1 : SetPin 25,dout
Pin(26)=1 : SetPin 26,dout
Pin(27)=1 : SetPin 27,dout
Pin(29)=1 : SetPin 29,dout
Pin(31)=1 : SetPin 31,dout
Pin(32)=1 : SetPin 32,dout
Pin(34)=1 : SetPin 34,dout
Pin(11)=1 : SetPin 11,dout
Pin(12)=1 : SetPin 12,dout
Pin(14)=1 : SetPin 14,dout
Pin(15)=1 : SetPin 15,dout
Pin(16)=1 : SetPin 16,dout
Pin(17)=1 : SetPin 17,dout
Pin(19)=1 : SetPin 19,dout
Pin(20)=1 : SetPin 20,dout
It should make them go straight from high-Z to 1 without first being set to 0 (the default after Setpin) before the port command.
Edited 2026-01-18 21:33 by phil99
Arne
Posted: 12:22pm 18 Jan 2026
To set the pins before SetPin command worked perfect.
Thanks all,
Arne
DaveJacko
Posted: 09:26pm 18 Jan 2026
While we're on the subject of GPIO..
can anyone point out what stupid mistake I'm making here?
wire together GP0 and GP1
setpin GP0,dout
setpin GP1,din
pin (GP0)=1
print pin(GP1)   - prints a 0 !!
also tried pin(GP0)=0, and PWM 1Khz 50%
checked with a meter, volts/freq as expected.
Just getting 0 on GP1
(I'm ultimately trying to get a settick type interrupt > 1 KHz )
Thanks in anticipation mates.
Try swapping 2 and 3 over
Posted: 10:24pm 18 Jan 2026
> setpin GP0,dout : setpin GP1,din
> pin(GP0)=1 : ? pin(GP1)
1
Check with a meter that you are getting 3.3V on GP1 at the pad on the Pico module.
If so you may have a dead pin. Try GP2 etc.
DaveJacko
Posted: 10:54pm 18 Jan 2026
Thanks, Phil, I've tried that bit of code verbatim right now..
mine returns a zero
yes, I previously checked with meter, 3+ volts
tried another pico zero, same.
I think I may be making an even more fundamentally stupid mistake,
I'll sleep on it with a glass of Aussie red,
will let you know how I get on
Posted: 11:12pm 18 Jan 2026
  DaveJacko said  While we're on the subject of GPIO..
setpin GP0,dout
setpin GP1,din
pin (GP0)=1
You have a space after pin in
pin (GP0)=1
Please try it without the space (sorry, I'm guessing it matters here but may be wrong).
DaveJacko
Posted: 11:25pm 18 Jan 2026
thanks, John, but well spotted!
tried it, don't think that's the problem.. sleeping on it
Posted: 11:31pm 18 Jan 2026
I would have expected that to be the issue too, had I noticed it. A CODE window makes spaces clearer.
However :-
> pin(GP0)=0 : ? pin(GP1)
0
> pin (GP0)=1 : ? pin(GP1) '1 space
1
> pin (GP0)=0 : ? pin(GP1) '1 space
0
> pin  (GP0)=1 : ? pin(GP1) '2 spaces
1
Did not expect that!
Posted: 11:52pm 18 Jan 2026
It should work as presented.
As Phil suggested, try GP2 etc
To see if one of the pins is reserved for some system purpose, try
new
option list
list pins
mozzie
Posted: 02:12am 19 Jan 2026
G'day DaveJacko,
It might be a good idea to post the version of PicoMite and options list you are using, it could be a problem with a specific variant or option rather than generic.
I have tried your code on a RP2350A and RP2040 using V6.02.00RC7 and both work as expected, something strange going on somewhere.
What happens if you apply 3v3 direct to GP1?
Lyle
EDIT: Also tested on RP2040-Zero with V6.02.00RC7 and it works as expected. Possibly an option setting conflict?
Edited 2026-01-19 12:45 by mozzie
DaveJacko
Posted: 10:12pm 19 Jan 2026
I went back in my shed to experiment further..
(objective; simply to link two pins, one with a pwm output >1000 Hz, the other to trigger an interrupt, >1000 Hz)
using gp0 as PWM out and gp1 as interrupt in, just returns constant gp1=0
other way round, gp0 as int and gp1 as pwm produces interrupts as expected!
Just to experiment further, tried random pins GP10,GP11
linked together,
GP10 won't drive GP11, and GP11 won't drive GP10, just get pin()=0
despite meter showing 0v/3v3 levels,
at 1 Hz in case you were wondering
on RP2040 Pico Zero running V6.00
aaargh!.. surely something that's my fault
Posted: 10:50pm 19 Jan 2026
Jim made an important suggestion earlier.
  Quote  To see if one of the pins is reserved for some system purpose, try
new (deletes the current program)
option list
list pins
If that doesn't reveal anything save the contents of A: and the current program then apply Clear_flash.uf2. That should restore it to Factory Fresh.
Then when you install new firmware it won't be compromised by the remains of the previous one.
DaveJacko
Posted: 10:23pm 20 Jan 2026
I'm putting my perceived GPIO problem on the back-burner for now
(I'll try the clear_flash.uf2 nuke in due course, thanks Phil and all for your help)
I'm sure it will ultimately be my fault.
Having read the excellent manual carefully, using a hardware int to give a steady clock is unlikely to work, hardware ints are only serviced after completion of commands, so can be missed.
Thought of a new approach. I forgot that 'TIMER' counts in microseconds,
(assumed milliSecs)
so something like this might give a steady loop time
mainloop:
timer=0
<do your stuff>
waitloop:
if timer<0.1 then goto waitloop 'ie 10 kHz
goto mainloop
That said, the new stepper commands for RP2350 really are marvellous !
Posted: 07:43am 21 Jan 2026
If it's of any use, the Count input has a hardware interrupt rather than being software dependent.
DaveJacko
Posted: 09:07pm 21 Jan 2026
Thanks Mick, I'll try that with a count of 1
