Forum Index : Microcontroller and PC projects : Option Prompt
| kermess Regular Member Joined: 04/04/2013 Location: SpainPosts: 50 |
Good morning. Is it possible to change the generic ">_" prompt to an alternative, for example, "AR_Motor >_" or "DEC_Motor >_"? This is simply to avoid confusion about which session you're in when you have multiple sessions open (Teraterm). Un saludo. David. |
I don't think that's possible. If you have multiple sessions in Windows you could put them on different desktops and switch them using Ctrl-Win-arrow. With different desktop pictures/colours it would be easy to know where you are. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12057 |
Put this in the library Sub mm.prompt Print "Myprompt >"; End Sub |
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 646 |
Same here, I'm using OPTION PLATFORM to set where I am. OPTION LIST reveals it then. 73 de OE1HGA, Gerald |
Manual page 23 expands Peters answer. Edited 2026-01-18 20:19 by phil99 |
Good morning. Thank you very much. Issue resolved. David. |
