Local Time 00:39 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Terminal row and column width
Posted: 04:41pm 15 Jan 2026
I think I've seen it, but didn't note it. How do I set the rows and columns visible when using the built-in editor with TeraTerm (Picomite)?
dddns
Posted: 05:06pm 15 Jan 2026
AFAIK and IIRC: With VGA or HDMI firmware you are bound to the display variable that is set according to the resolution (edit:and font) been set. This is also true for an LCD display used as console.
In non VGA/HDMI firmware you can use: OPTION DISPLAY lines[,chars]
Edited 2026-01-16 03:15 by dddns
Posted: 10:25pm 15 Jan 2026
  dddns said  OPTION DISPLAY lines[,chars]
That's what I didn't remember. Thanks.
All good now. Spacious.
