terekgabor Senior Member Joined: 02/01/2026 Location: HungaryPosts: 155
Posted: 02:47pm 10 Jan 2026
Hello!
I am using SELECT..CASE structure, after a number of CASE I get Not enough memory error. Is there a maximum number of CASE pieces? I use SELECT on a string variable for a command line editor.
Maybe better to switch back to IF-ELSEIF?
Thanks!
Peter63 Senior Member Joined: 28/07/2017 Location: SwedenPosts: 217
Posted: 04:25pm 10 Jan 2026
Hello
I made a simple test program, it actually stops with Error: Not enough memory ... hmmm
Posted: 04:40pm 10 Jan 2026
Hello
Reading the manual page 33... maybe 50 is the limit ???
/Peter63
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4391
Posted: 04:59pm 10 Jan 2026
After how many?
Which CPU etc?
LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625
Posted: 05:09pm 10 Jan 2026
Maybe you need to rethink the way you are implementing the feature
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807
Posted: 06:54pm 10 Jan 2026
I've only used 8 case statements. what's wrong with if x=1 then whatever else if whatever then whatever :else :end if. ie if instead of case and when condition met then end if.... or goto end :)
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12057
Posted: 07:24pm 10 Jan 2026
I'll put a fix for this in 6.02.00
Posted: 05:54am 11 Jan 2026
Hello, terekgabor
I made a small change in my test program. You can enter numbers between 1-64 but not over because then it will be Error: Not enough memory If U Run the program, you can see that 64 is OK but 65 is not...
> run input string? 45 45 input string? 60 60 input string? 64 64 input string? 65 [138] Case "65" Error : Not enough memory >
If you know about the limitation or the reason you can still use Select case... in your program. According to Peter, he will fix this in the next version...
/ Peter63
' ' select case - test program 2 '
Input "input string";s$
Select Case s$ Case "1" Print "1" Case "2" Print "2" Case "3" Print "3" Case "4" Print "4" Case "5" Print "5" Case "6" Print "6" Case "7" Print "7" Case "8" Print "8" Case "9" Print "9" Case "10" Print "10" Case "11" Print "11" Case "12" Print "12" Case "13" Print "13" Case "14" Print "14" Case "15" Print "15" Case "16" Print "16" Case "17" Print "17" Case "18" Print "18" Case "19" Print "19" Case "20" Print "20" Case "21" Print "21" Case "22" Print "22" Case "23" Print "23" Case "24" Print "24" Case "25" Print "25" Case "26" Print "26" Case "27" Print "27" Case "28" Print "28" Case "29" Print "29" Case "30" Print "30" Case "31" Print "31" Case "32" Print "32" Case "33" Print "33" Case "34" Print "34" Case "35" Print "35" Case "36" Print "36" Case "37" Print "37" Case "38" Print "38" Case "39" Print "39" Case "40" Print "40" Case "41" Print "41" Case "42" Print "42" Case "43" Print "43" Case "44" Print "44" Case "45" Print "45" Case "46" Print "46" Case "47" Print "47" Case "48" Print "48" Case "49" Print "49" Case "50" Print "50" Case "51" Print "51" Case "52" Print "52" Case "53" Print "53" Case "54" Print "54" Case "55" Print "55" Case "56" Print "56" Case "57" Print "57" Case "58" Print "58" Case "59" Print "59" Case "60" Print "60" Case "61" Print "61" Case "62" Print "62" Case "63" Print "63" Case "64" Print "64" Case "65" Print "65" Case "66" Print "66" Case "67" Print "67" Case "68" Print "68" Case "69" Print "69" Case "70" Print "70" Case "71" Print "71" Case "72" Print "72" Case "73" Print "73" Case "74" Print "74" Case "75" Print "75" Case "76" Print "76" Case "77" Print "77" Case "78" Print "79" Case "80" Print "80" Case "81" Print "81" Case "82" Print "82" Case "83" Print "83" Case "84" Print "84" Case "85" Print "85" Case "86" Print "86" Case "87" Print "87" Case "88" Print "88" Case "89" Print "89" Case "90" Print "90" Case "91" Print "91" Case "92" Print "92" Case "93" Print "93" Case "94" Print "94" Case "95" Print "95" Case "96" Print "96" Case "97" Print "97" Case "98" Print "98" Case "99" Print "99" Case "100" Print "100" Case "101" Print "101" Case "102" Print "102" Case "103" Print "103" Case "104" Print "104" Case "105" Print "105" Case "106" Print "106" Case "107" Print "107" Case "108" Print "108" Case "109" Print "109" Case "110" Print "110" Case "111" Print "111" End Select
