Forum Index : Microcontroller and PC projects : "Driver" for vl53l5cx 8x8 pixel time-of-flight distance sensor
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 361 |
Hi, I case someone is interested in a distance sensor - I recently wrote a "driver" for the vl53l5cx sensor, which can provide an 8x8 pixel "image" of distances in a field-of-view of approx. 60 degrees. It's available on breakout boards from several companies and a nice solution for robotic "vision". The writing the driver was challenging, as it first needs to upload approx. 90k of driver binaries to the chip via I2C. All the files are in this zip. Up to a point, I used AI to port the MicroPython version, but the code has still two issues I could not solve even with the support of different LLMs (at some point, the complained that Basic does not work as its in the code, despite having the excellent MMBasic manual ...). In any case, the driver works in 8x8 mode but the distances are approx. a (linear) factor 4 off, pointing at some issue with the complex way the sensor uses calibration data. Thanks to all the fast MEMORY, MATH etc. commands, the driver loads within a few seconds and retrieving (and converting) a new distance image takes only a few ms. This really demonstrates what one can do with MMBasic on the hardware/data processing side. ' VL53L5CX Driver for MMBasic (PicoMite) v0.7.3 ' -------------------------------------- ' Copyright (c) 2025-26 Thomas Euler ' MIT Licence ' ' Many functions are a direct port of the underlying API functions from the ' `vl53l5cx_api.cpp` library (`SparkFun_VL53L5CX_Arduino_Library`) written by ' SparkFun Electronics, November 2024 ' ' v0.7.0 (2026-01-01) ' - LInput command for reading binary files accelerates loading firmware ' v0.7.1 ' - Using structures (Types) for internal variables ' - Main program to test subroutine towards library ' v0.7.2 ' - Before loading firmware, check if sensor has already initialized to ' shorten startup time ' - BytesToInt16 improved, now faster ' - ToF functions tested, including calibration ' v0.7.3 ' - ToF functions removed; turned into a library ' ' Unsolved issues: ' --------------- ' - 8x8 data is not correctly scaled (approx. 4x larger); this is currently ' "heuristically" corrected ' - 4x4 mode does not generate data ' ' Requirements: ' ------------ ' File structure on SD card: ' /vl53l5cx/firmware.bin (86016 bytes) ' /vl53l5cx/config.bin (972 bytes) ' /vl53l5cx/xtalk.bin (776 bytes) ' /vl53l5cx/nvm_cmd.bin (40 bytes) ' ' I/O pins: ' - GP12 (SDA) and GP13 (SCL) for I2C2 ' ' List of available target status: ' 0 - Ranging data are not updated ' 1 - Signal rate too low on SPAD array ' 2 - Target phase ' 3 - Sigma estimator too high ' 4 - Target consistency failed ' 5 - Range valid ' 6 - Wrap around not performed (typically the first range) ' 7 - Rate consistency failed ' 8 - Signal rate too low for the current target ' 9 - Range valid with large pulse (may be due to a merged target) ' 10 - Range valid, but no target detected at previous range ' 11 - Measurement consistency failed ' 12 - Target blurred by another one, due to sharpener ' 13 - Target detected but inconsistent data. Frequently happens for ' secondary targets. ' 255 - No target detected (only if number of targets detected is enabled) ' ' ---------------------------------------------------------------------------- Option Base 0 Option explicit Option Default Integer Option Escape Print "VL53L5CX sensor driver in library" Print "| Hardware requirements: I2C (GP12, GP13)" ' ---------------------------------------------------------------------------- ' Constants Const VL53_I2C_SDA = MM.Info(PinNo GP12) Const VL53_I2C_SCL = MM.Info(PinNo GP13) Const VL53_I2C_ADDR = &H29 Const VL53_BUF_SIZE = 16384 ' Buffer size for reading Const VL53_I2C_CHUNK = 192 ' I2C write reliable chunk size Const VL53_I2C_FREQ = 1000 Const VL53_DEV_ID = &HF0 Const VL53_REV_ID = &H02 Const VL53_RES_4x4 = 16 Const VL53_RES_8x8 = 64 Const VL53_RMODE_CONTINOUS = 1 Const VL53_RMODE_AUTONOMOUS = 3 Const VL53_VERBOSE = 0 ' Register map Const VL53_REG_SOFT_RESET = &H0000 Const VL53_REG_PAGE_SEL = &H7FFF Const VL53_REG_CMD_STAT = &H2C00 Const VL53_REG_BOOT_STAT = &H0006 Const VL53_REG_SYSTEM_STAT = &H00E5 Const VL53_KUI_CMD_START = &H2C04 Const VL53_KUI_CMD_END = &H2FFF Const VL53_KDCI_FREQ_HZ = &H5458 Const VL53_KDCI_ZONE_CONFIG = &H5450 Const VL53_KDCI_DSS_CONFIG = &HAD38 Const VL53_KDCI_RANGE_MODE = &HAD30 ' Firmware section and buffer sizes Const VL53_FW_PART1_SIZE = &H8000 ' 32KB Const VL53_FW_PART2_SIZE = &H8000 ' 32KB Const VL53_FW_PART3_SIZE = &H5000 ' 20KB Const VL53_KNMV_DATA_SIZE = 492 Const VL53_KOFFS_DATA_SIZE = 488 Const VL53_KTEMP_BUF_SIZE = 1440 Const VL53_KXTALK_DATA_SIZE = 776 Const VL53_KCONFIG_SIZE = 972 ' Internal structure Type TVL53 stream_count As integer dread_size As integer kBHTypeShift As integer kBHTypeMask As integer kBHSizeShift As integer kBHSizeMask As integer kBHIdxShift As integer kBHIdxMask As integer frame_count As Integer End Type ' Ranging data pixel Type TVL53Pixel dist_mm As integer ' distance in [mm] t_state As integer ' pixel state (see list above) n_trgts As integer ' # of targets detected End Type ' ---------------------------------------------------------------------------- Sub VL53.test _res%, _freq% ' Testing the sensor Dim Integer res = 0, iFr If _res% = 0 Then _res% = VL53_RES_8x8 If _freq% = 0 Then _freq% = 5 VL53.init Pause 500 tof_params.dxy = Int(Sqr(_res%)) tof_params.freq_Hz = _freq% res = VL53.set_freq_Hz(_freq%) Print "Ranging frequency [Hz]=";VL53.get_freq_Hz() res = VL53.set_resolution(_res%) Print "Resolution=";VL53.get_resolution() res = VL53.set_ranging_mode(VL53_RMODE_CONTINOUS) res = VL53.get_ranging_mode() Print "Ranging mode=";Choice(res = 1, "continuous", "autonomous") res = VL53.start_ranging() Print "Start ranging ->";res Pause 200 For iFr=0 To 199 VL53.update_data Struct Print vl53_data() Pause 500 Next res = VL53.stop_ranging() Print "Stop ranging ->";res VL53.close Print "Done." End Sub ' ============================================================================= ' Initialization/finalization of sensor ' ----------------------------------------------------------------------------- Sub VL53.init ' Initialize sensor and load firmware Local Integer res, n, m, tmp, status = 0, i, p_tmp, p2 Local string path$ Local Float t_ms = Timer ' Some global data buffers and variables Dim Integer vl53_offs_data(VL53_KOFFS_DATA_SIZE -1) Dim Integer vl53_xtalk_data(VL53_KXTALK_DATA_SIZE -1) Dim Integer vl53_tmp_buf(VL53_KTEMP_BUF_SIZE -1) p_tmp = Peek(VarAddr vl53_tmp_buf()) Dim _vl53 As TVL53 _vl53.kBHTypeShift = 0 _vl53.kBHTypeMask = &H000F << _vl53.kBHTypeShift _vl53.kBHSizeShift = 4 _vl53.kBHSizeMask = &H0FFF << _vl53.kBHSizeShift _vl53.kBHIdxShift = 16 _vl53.kBHIdxMask = &HFFFF << _vl53.kBHIdxShift Dim vl53_data(VL53_RES_8x8 -1) As TVL53Pixel ' Setup I2C Print "Opening VL53L5CX ..." SetPin VL53_I2C_SDA, VL53_I2C_SCL, I2C I2C OPEN VL53_I2C_FREQ, 1000 ' Check sensor presence I2C Write VL53_I2C_ADDR, 0, 1, 0 If MM.I2C = 0 And VL53.isAlife(1) Then Print "| Sensor detected." Else Print "| Error: Sensor not found at &H"; Hex$(VL53_I2C_ADDR) I2C CLOSE Exit Sub EndIf Pause 500 ' Check if sensor already initialized, if so, exit res = VL53.get_resolution() If res = 16 Or res = 64 Then Print "| Sensor already initialized" Exit Sub EndIf ' Initializing sensor Print "| Initializing sensor ..." ' Sw reboot sequence _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 _WriteI2CReg16 &H0009, &H04 _WriteI2CReg16 &H000F, &H40 _WriteI2CReg16 &H000A, &H03 tmp = _ReadI2CReg16(&H7FFF) _WriteI2CReg16 &H000C, &H01 _WriteI2CReg16 &H0101, &H00 _WriteI2CReg16 &H0102, &H00 _WriteI2CReg16 &H010A, &H01 _WriteI2CReg16 &H4002, &H01 _WriteI2CReg16 &H4002, &H00 _WriteI2CReg16 &H010A, &H03 _WriteI2CReg16 &H0103, &H01 _WriteI2CReg16 &H000C, &H00 _WriteI2CReg16 &H000F, &H43 Pause 1 _WriteI2CReg16 &H000F, &H40 _WriteI2CReg16 &H000A, &H01 Pause 100 ' Wait for sensor booted (several ms required to get sensor ready) ' (self.poll_for_answer(1, 0, &H06, 0xff, 1)) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 status = status Or VL53._waitForStatus(1, 0, &H06, &HFF, 1) _WriteI2CReg16 &H000E, &H01 _WriteI2CReg16 VL53_REG_PAGE_SEL, &H02 ' Enable Fw access ' (self.poll_for_answer(1, 0, &H21, &H10, &H10)) _WriteI2CReg16 &H03, &H0D _WriteI2CReg16 VL53_REG_PAGE_SEL, &H01 status = status Or VL53._waitForStatus(1, 0, &H21, &H10, &H10) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 ' Enable host access to GO1 _WriteI2CReg16 &H000C, &H01 ' Power ON status _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 _WriteI2CReg16 &H0101, &H00 _WriteI2CReg16 &H0102, &H00 _WriteI2CReg16 &H010A, &H01 _WriteI2CReg16 &H4002, &H01 _WriteI2CReg16 &H4002, &H00 _WriteI2CReg16 &H010A, &H03 _WriteI2CReg16 &H0103, &H01 _WriteI2CReg16 &H400F, &H00 _WriteI2CReg16 &H021A, &H43 _WriteI2CReg16 &H021A, &H03 _WriteI2CReg16 &H021A, &H01 _WriteI2CReg16 &H021A, &H00 _WriteI2CReg16 &H0219, &H00 _WriteI2CReg16 &H021B, &H00 ' Wake up MCU _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 _WriteI2CReg16 &H000C, &H00 _WriteI2CReg16 VL53_REG_PAGE_SEL, &H01 _WriteI2CReg16 &H0020, &H07 _WriteI2CReg16 &H0020, &H06 ' Load firmware in three sections Print "| Loading firmware ..." path$ = "/vl53l5cx/firmware.bin" _WriteI2CReg16 VL53_REG_PAGE_SEL, &H09 n = 0 m = VL53_FW_PART1_SIZE res = VL53._loadFirmwareSect(Path$, 0, n, m, 1) If Not(res) Then GoTo VL53.LoadError _WriteI2CReg16 VL53_REG_PAGE_SEL, &H0A n = VL53_FW_PART1_SIZE m = VL53_FW_PART2_SIZE res = VL53._LoadFirmwareSect(Path$, 0, n, m) If Not(res) Then GoTo VL53.LoadError _WriteI2CReg16 VL53_REG_PAGE_SEL, &H0B n = VL53_FW_PART1_SIZE +VL53_FW_PART2_SIZE m = VL53_FW_PART3_SIZE res = VL53._LoadFirmwareSect(Path$, 0, n, m, 2) If Not(res) Then GoTo VL53.LoadError ' Check if FW correctly downloaded ' (self.poll_for_answer(1, 0, &H21, &H10, &H10)) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H02 _WriteI2CReg16 &H0003, &H0D _WriteI2CReg16 VL53_REG_PAGE_SEL, &H01 status = status Or VL53._waitForStatus(1, 0, &H21, &H10, &H10) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 _WriteI2CReg16 &H000C, &H01 ' Reset MCU And wait boot ' (self.poll_for_answer(1, 0, &H06, &Hff, &H00)) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 _WriteI2CReg16 &H0114, &H00 _WriteI2CReg16 &H0115, &H00 _WriteI2CReg16 &H0116, &H42 _WriteI2CReg16 &H0117, &H00 _WriteI2CReg16 &H000B, &H00 _WriteI2CReg16 &H000C, &H00 _WriteI2CReg16 &H000B, &H01 status = status Or VL53._waitForStatus(1, 0, &H06, &HFF, 0) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H02 ' Get offset NVM data and store them into the offset buffer ' (self.poll_for_answer(4, 0, self.kUiCmdStatus, 0xff, 0x02)) path$ = "/vl53l5cx/nvm_cmd.bin" res = VL53._loadSmallFile(Path$, &H2FD8, 40) If Not(res) Then GoTo VL53.LoadError res = VL53._waitForStatus(4, 0, VL53_REG_CMD_STAT, &HFF, &H02) If res Then Print "| Error: NVM command timeout" GoTo VL53.LoadError EndIf _ReadI2CReg16Mult VL53_KUI_CMD_START, vl53_tmp_buf(), VL53_KNMV_DATA_SIZE p2 = Peek(VarAddr vl53_offs_data()) Memory Copy Integer p_tmp, p2, VL53_KOFFS_DATA_SIZE res = _sendOffsetData(VL53_RES_4X4) ' Set default Xtalk shape, send Xtalk to sensor path$ = "/vl53l5cx/xtalk.bin" res = VL53._loadSmallFile(Path$, 0, VL53_KXTALK_DATA_SIZE, 1) If Not(res) Then Print "| Error: Timeout when loading calibration data" GoTo VL53.LoadError EndIf p2 = Peek(VarAddr vl53_xtalk_data()) Memory Copy Integer p_tmp, p2, VL53_KXTALK_DATA_SIZE res = _sendXTalkData(VL53_RES_4x4) If res Then GoTo VL53.LoadError ' Send default configuration to VL53L5CX firmware ' (self.poll_for_answer(4, 1, self.kUiCmdStatus, 0xff, 0x03)) path$ = "/vl53l5cx/conf.bin" res = VL53._loadSmallFile(Path$, &H2C34, VL53_KCONFIG_SIZE) If Not(res) Then GoTo VL53.LoadError res = VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) If res Then Print "| Error: Timeout when loading configuration" GoTo VL53.LoadError EndIf ' Set to kNbTargetPerZone=1 and single_range=0x01 Local Integer buf(3) = (1, 0, &H01, 0), srange = &H01 res = _DCIWriteData(buf(), &HCF78, 4) Memory Unpack Peek(VarAddr srange), buf(), 4, 8 res = _DCIWriteData(buf(), &HCD5C, 4) Print "| Done in ";Str$((Timer -t_ms)/1000,0,1);" sec." Exit Sub VL53.LoadError: Print "| Error: Firmware load failed" I2C CLOSE End Sub Sub VL53.close I2C Close Print "VL53L5CX closed." End Sub ' ----------------------------------------------------------------------------- ' Method to check if sensor is alife ' ----------------------------------------------------------------------------- Function VL53.isAlife(log%) ' Returns True if device is alife Local integer devID, revID _WriteI2CReg16 VL53_REG_PAGE_SEL, &H00 devID = _ReadI2CReg16(0) revID = _ReadI2CReg16(1) _WriteI2CReg16 VL53_REG_PAGE_SEL, &H02 If log% Then Print "| Device ID=";Hex$(devID,4);" revision ID=";Hex$(revID,4) EndIf VL53.isAlife = (devID = VL53_DEV_ID) And (revID = VL53_REV_ID) End Function ' ----------------------------------------------------------------------------- ' Methods for setting/getting sensor parameters (frequency, resolution, mode) ' ----------------------------------------------------------------------------- Function VL53.get_freq_Hz() ' Returns the current ranging frequency in Hz Local integer stat stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_FREQ_HZ, 4) VL53.get_freq_Hz = vl53_tmp_buf(1) End Function Function VL53.set_freq_Hz(freq%) ' Sets current ranging frequency in Hz, returns True if successful Local integer stat, tmp(1) = (freq%, 0) stat = _DCIReplaceData(vl53_tmp_buf(), VL53_KDCI_FREQ_HZ, 4, tmp(), 1, 1) VL53.set_freq_Hz = (stat = 0) End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Function VL53.get_resolution() ' Returns the current resolution with 16 for 4x4 and 64 for 8x8 Local integer stat stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_ZONE_CONFIG, 8) VL53.get_resolution = vl53_tmp_buf(0) *vl53_tmp_buf(1) End Function Function VL53.set_resolution(resol%) ' Sets resolution, returns 0 if successful Local integer stat = 0 If resol% = VL53_RES_4x4 Then stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_DSS_CONFIG, 16) vl53_tmp_buf(&H04) = 64 vl53_tmp_buf(&H06) = 64 vl53_tmp_buf(&H09) = 4 stat = stat Or _DCIWriteData(vl53_tmp_buf(), VL53_KDCI_DSS_CONFIG, 16) stat = stat Or _DCIReadData(vl53_tmp_buf(), VL53_KDCI_ZONE_CONFIG, 8) vl53_tmp_buf(&H00) = 4 vl53_tmp_buf(&H01) = 4 vl53_tmp_buf(&H04) = 8 vl53_tmp_buf(&H05) = 8 stat = stat Or _DCIWriteData(vl53_tmp_buf(), VL53_KDCI_ZONE_CONFIG, 8) Else If resol% = VL53_RES_8x8 Then stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_DSS_CONFIG, 16) vl53_tmp_buf(&H04) = 16 vl53_tmp_buf(&H06) = 16 vl53_tmp_buf(&H09) = 1 stat = stat Or _DCIWriteData(vl53_tmp_buf(), VL53_KDCI_DSS_CONFIG, 16) stat = stat Or _DCIReadData(vl53_tmp_buf(), VL53_KDCI_ZONE_CONFIG, 8) vl53_tmp_buf(&H00) = 8 vl53_tmp_buf(&H01) = 8 vl53_tmp_buf(&H04) = 4 vl53_tmp_buf(&H05) = 4 stat = stat Or _DCIWriteData(vl53_tmp_buf(), VL53_KDCI_ZONE_CONFIG, 8) Else Print "Error: Invalid resolution" EndIf stat = stat Or _sendOffsetData(resol%) stat = stat Or _sendXTalkData(resol%) VL53.set_resolution = stat End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Function VL53.get_ranging_mode() ' Returns the current ranging mode Local Integer stat stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_RANGE_MODE, 8) If vl53_tmp_buf(1) = &H01 Then VL53.get_ranging_mode = VL53_RMODE_CONTINOUS Else VL53.get_ranging_mode = VL53_RMODE_AUTONOMOUS EndIf End Function Function VL53.set_ranging_mode(_mode%) ' Set the ranging mode. Two modes are `continuous` and `autonomous Local Integer stat, sr(3) = (0, 0, 0, 0) stat = _DCIReadData(vl53_tmp_buf(), VL53_KDCI_RANGE_MODE, 8) If _mode% = VL53_RMODE_CONTINOUS Then vl53_tmp_buf(1) = &H01 vl53_tmp_buf(3) = &H03 Else If _mode% = VL53_RMODE_AUTONOMOUS Then vl53_tmp_buf(1) = &H03 vl53_tmp_buf(3) = &H02 sr(0) = &H01 Else stat = 1 EndIf If stat = 0 Then stat = stat Or _DCIWriteData(vl53_tmp_buf(), VL53_KDCI_RANGE_MODE, 8) stat = stat Or _DCIWriteData(sr(), &HCD5C, 4) EndIf VL53.set_ranging_mode = stat End Function ' ----------------------------------------------------------------------------- ' Methods for starting/stoping ranging and checking for/retrieving new data ' ----------------------------------------------------------------------------- Function VL53.start_ranging() ' Starts ranging ... Local Integer stat = 0, op_size = 12, TrgtPerZone = 1 Local Integer bh_ptr_type, bh_ptr_size, bh_ptr_idx, resol, i, j Local Integer hconf(1) = (0, 0), buf(4* op_size -1) Local Integer cmd(3) = (0, &H03, 0, 0), output(op_size -1) Local Integer output_bh_enable(3) = (&H07, 0, 0, &HC0000000) resol = VL53.get_resolution() _vl53.stream_count = 255 _vl53.dread_size = 0 _vl53.frame_count = 0 output(0) = &H0000000D output(1) = &H54B400C0 output(2) = &H54C00040 output(3) = &H54D00104 output(4) = &H55D00404 output(5) = &HCF7C0401 output(6) = &HCFBC0404 output(7) = &HD2BC0402 output(8) = &HD33C0402 output(9) = &HD43C0401 output(10) = &HD47C0401 output(11) = &HCC5008C0 ' Enable selected outputs /* Inc output_bh_enable(0), 8 ' VL53L5CX_ENABLE_AMBIENT_PER_SPAD Inc output_bh_enable(0), 16 ' VL53L5CX_ENABLE_NB_SPADS_ENABLED Inc output_bh_enable(0), 64 ' VL53L5CX_ENABLE_SIGNAL_PER_SPAD Inc output_bh_enable(0), 128 ' VL53L5CX_ENABLE_RANGE_SIGMA_MM Inc output_bh_enable(0), 512 ' VL53L5CX_ENABLE_REFLECTANCE_PERCENT Inc output_bh_enable(0), 2048 ' VL53L5CX_ENABLE_MOTION_INDICATOR */ Inc output_bh_enable(0), 32 ' VL53L5CX_ENABLE_NB_TARGET_DETECTED Inc output_bh_enable(0), 256 ' VL53L5CX_ENABLE_DISTANCE_MM Inc output_bh_enable(0), 1024 ' VL53L5CX_ENABLE_TARGET_STATUS ' Send output addresses For i=0 To 11 j = (output_bh_enable(i \32) And (1 << (i Mod 32))) = 0 If (output(i) = 0) Or j Then Continue For bh_ptr_type = (output(i) And _vl53.kBHTypeMask) >> _vl53.kBHTypeShift bh_ptr_size = (output(i) And _vl53.kBHSizeMask) >> _vl53.kBHSizeShift bh_ptr_idx = (output(i) And _vl53.kBHIdxMask) >> _vl53.kBHIdxShift If (bh_ptr_type >= &H01) And (bh_ptr_type < &H0d) Then If (bh_ptr_idx >= &H54D0) And (bh_ptr_idx < &H54D0 +960) Then bh_ptr_size = resol output(i) = output(i) And (INV _vl53.kBHSizeMask) output(i) = output(i) Or (resol << _vl53.kBHSizeShift) Else bh_ptr_size = resol *TrgtPerZone output(i) = output(i) And (INV _vl53.kBHSizeMask) output(i) = output(i) Or ((resol *TrgtPerZone) << _vl53.kBHSizeShift) EndIf Inc _vl53.dread_size, bh_ptr_type *bh_ptr_size Else Inc _vl53.dread_size, bh_ptr_size EndIf Inc _vl53.dread_size, 4 Next Inc _vl53.dread_size, 20 _uint32ArrayToBytes output(), buf(), op_size stat = stat Or _DCIWriteData(buf(), &HCD78, op_size *4) hconf(0) = _vl53.dread_size hconf(1) = i +2 _uint32ArrayToBytes hconf(), buf(), 2 stat = stat Or _DCIWriteData(buf(), &HCD60, 8) _uint32ArrayToBytes output_bh_enable(), buf(), 4 stat = stat Or _DCIWriteData(buf(), &HCD68, 16) ' Start xshut bypass (interrupt mode) _WriteI2CReg16 &H7FFF, &H00 _WriteI2CReg16 &H0009, &H05 _WriteI2CReg16 &H7FFF, &H02 ' Start ranging session _WriteI2CReg16Mult VL53_KUI_CMD_END -(4 -1), cmd(), 4 stat = stat Or VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) VL53.start_ranging = stat End Function ' ............................................................................. Function VL53.check_data_ready() ' Checks if new data is ready, returns True if so. Local Integer check _ReadI2CReg16Mult 0, vl53_tmp_buf(), 4 check = vl53_tmp_buf(0) <> _vl53.stream_count check = check And (vl53_tmp_buf(0) <> 255) And (vl53_tmp_buf(1) = 5) check = check And ((vl53_tmp_buf(2) And &H05) = &H05) If check And ((vl53_tmp_buf(3) And &H10) = &H10) Then _vl53.stream_count = vl53_tmp_buf(0) VL53.check_data_ready = 1 Exit Function EndIf If VL53_VERBOSE Then Print "buf=";Hex$(vl53_tmp_buf(0),2);" ";Hex$(vl53_tmp_buf(1),2); Print " ";Hex$(vl53_tmp_buf(2),2);" ";Hex$(vl53_tmp_buf(3),2) EndIf VL53.check_data_ready = 0 End Function ' ............................................................................. Sub VL53.update_data() ' Gets the ranging data, using the selected output and resolution, and ' and saves it in `vl53_data().dist_mm` 'Local Float t = Timer Static Integer ptb = Peek(VarAddr vl53_tmp_buf()), bh, pbh = Peek(VarAddr bh) Static Integer tmp(VL53_RES_8x8 -1), p_t = Peek(VarAddr tmp()) Static Integer ntg(VL53_RES_8x8 -1), p_n = Peek(VarAddr ntg()) Local Integer bh_ptr_type, bh_ptr_size, bh_ptr_idx Local Integer stat = 0, i, msize, p ' Get the data _ReadI2CReg16Mult 0, vl53_tmp_buf(), _vl53.dread_size _vl53.stream_count = vl53_tmp_buf(0) _swapBuffer vl53_tmp_buf(), _vl53.dread_size Inc _vl53.frame_count, 1 ' Start conversion at position 16 to avoid headers For i=16 To _vl53.dread_size -1 Step 4 Memory Pack ptb +i*8, pbh, 4, 8 bh_ptr_type = (bh And _vl53.kBHTypeMask) >> _vl53.kBHTypeShift bh_ptr_size = (bh And _vl53.kBHSizeMask) >> _vl53.kBHSizeShift bh_ptr_idx = (bh And _vl53.kBHIdxMask) >> _vl53.kBHIdxShift msize = bh_ptr_size If (bh_ptr_type > &H01) And (bh_ptr_type < &H0D) Then msize = msize *bh_ptr_type EndIf p = ptb +(i+4)*8 ' Extract selected data If bh_ptr_idx = &HCF7C Then ' # of targets detected Memory Copy Integer p, p_n, msize Struct Insert ntg(), vl53_data().n_trgts Else If bh_ptr_idx = &HD33C Then ' Distances stat = _BytesToI16Arr(vl53_tmp_buf(), tmp(), i+4, msize) Struct Insert tmp(), vl53_data().dist_mm Else If bh_ptr_idx = &HD47C Then ' target status Memory Copy Integer p, p_t, msize Struct Insert tmp(), vl53_data().t_state Exit For EndIf ' Advance by payload size Inc i, msize Next ' Negate pixel distances for which no target was detected Math Scale ntg(), 2, ntg() Math Add ntg(), -1, ntg() Math C_Mult ntg(), vl53_data().dist_mm, vl53_data().dist_mm 't = Timer -t : Print "update_ranging_data t=";t End Sub ' ............................................................................. Function VL53.stop_ranging() ' Stops a ranging session. It must be used when the sensor streams, ' after calling `VL53.start_ranging()`. Returns 0 if successful Local integer stat = 0, asf(3), tout = 0, tmp = 0 _ReadI2CReg16Mult &H2FFC, asf(), 4 If Not((asf(0)=0) And (asf(1)=0) And (asf(2)=4) And (asf(3)=&HFF)) Then _WriteI2CReg16 &H7FFF, &H00 ' Provoke MCU stop _WriteI2CReg16 &H15, &H16 _WriteI2CReg16 &H14, &H01 ' Poll for G02 status 0 MCU stop Do While (((tmp And &H80) >> 7) = 0) And (tout < 500) tmp = _ReadI2CReg16(&H06) Pause 10 Inc tout, 1 If tout >= 500 Then stat = 255 Loop EndIf ' Undo MCU stop _WriteI2CReg16 &H7FFF, &H00 _WriteI2CReg16 &H14, &H00 _WriteI2CReg16 &H15, &H00 ' Stop xshut bypass _WriteI2CReg16 &H09, &H04 _WriteI2CReg16 &H7FFF, &H02 VL53.stop_ranging = stat End Function ' ============================================================================ ' Internal methods ' ----------------------------------------------------------------------------- Function VL53._loadFirmwareSect(fname$, tAddr, fOffs, sectSize, flag) ' Load a section of firmware from file Local Integer bytesRead, totalRead, currAddr Local Integer i, j, writeSize, byteVal, res, n Local Integer DataBuf(VL53_BUF_SIZE \8 +1), pDB = Peek(VarAddr DataBuf()) Local Integer writeBuf(VL53_I2C_CHUNK +2 -1) VL53._loadFirmwareSect = 0 currAddr = tAddr totalRead = 0 ' Check if file exists If Not(MM.Info(EXISTS FILE fname$)) Then Print "| Error: File `";fname$;"` not found" Exit Function EndIf ' Open file for binary reading Open fname$ For RANDOM As #1 If flag = 1 Then Print "| Reading `";fname$;"` "; ' Read and write in chunks Do While totalRead < sectSize ' Calculate chunk size to read bytesRead = Min(VL53_BUF_SIZE, sectSize -totalRead) ' Read chunk from file Seek #1, fOffs +totalRead +1 n = LInput(DataBuf(), #1, bytesRead) If n <> bytesRead Then Print "| Error: Size issue with file `";fname$;"`" Exit Function EndIf Memory Copy Integer pDB +8, pDB, bytesRead \8 ' Write chunk to sensor via I2C j = 0 Do While j < bytesRead writeSize = Min(VL53_I2C_CHUNK, bytesRead -j) ' Prepare I2C data writeBuf(0) = (currAddr >> 8) And &HFF writeBuf(1) = currAddr And &HFF For i=0 To writeSize -1 writeBuf(i +2) = Peek(Var DataBuf(), j +i) Next ' Write to I2C I2C WRITE VL53_I2C_ADDR, 0, writeSize +2, writeBuf() res = MM.I2C If res <> 0 Then Print "| I2C write error ";res;" at 0x";Hex$(currAddr) Close #1 VL53._loadFirmwareSect = 0 Exit Function EndIf Inc currAddr, writeSize Inc j, writeSize Loop Inc totalRead, bytesRead ' Show progress If (totalRead Mod VL53_BUF_SIZE) = 0 Then Print "."; Loop Close #1 If flag = 2 Then Print " Done" VL53._LoadFirmwareSect = 1 End Function ' ----------------------------------------------------------------------------- Function VL53._loadSmallFile(fname$, tAddr, fSize, toTmpBuf) ' Load small configuration file and write it to the I2C register or into ' `vl53_tmp_buf()` Local Integer n1, tmp1(fSize \8 +1) VL53._loadSmallFile = 1 If Not(MM.Info(EXISTS FILE fname$)) Then Print "| Error: File `";fname$;"` not found" VL53._loadSmallFile = 0 Exit Function EndIf ' Open file for binary reading Open fname$ For RANDOM As #1 Print "| Reading `";fname$;"` ..."; ' Read entire small file to buffer Seek #1, 1 n1 = LInput(tmp1(), #1, fSize) If n1 <> fSize Then Print "| Error: Size issue with file `";fname$;"`" VL53._loadSmallFile = 0 Exit Function EndIf Memory Unpack Peek(VarAddr tmp1()) +8, vl53_tmp_buf(), fSize, 8 Close #1 ' Write directly to I2C bus, if requested If Not(toTmpBuf) Then _WriteI2CReg16Mult tAddr, vl53_tmp_buf(), fsize EndIf Print " Done" End Function ' ----------------------------------------------------------------------------- Function VL53._waitForStatus(n%, p%, reg%, mask%, vExp%) ' Wait for status register to reach expected value Local Integer stat = 0, j, buf(Max(n% -1, 1)) Local Integer tout_ms = 2000 If VL53_VERBOSE Then Print "_waitForStatus ";n%;" ";p%;" ";reg%;" ";mask%;" ";vExp% EndIf Do _ReadI2CReg16Mult reg%, buf(), n% If (n% >= 4) Then If (buf(2) >= &H7F) Then stat = stat Or 1 EndIf If (buf(p%) And mask%) = vExp% Then VL53._waitForStatus = stat If VL53_VERBOSE Then Print "->ok" Exit Function EndIf Pause 10 Inc tout_ms, -10 Loop Until tout_ms <= 0 stat = stat Or buf(2) VL53._waitForStatus = stat If VL53_VERBOSE Then Print "->timeout" End Function ' ----------------------------------------------------------------------------- ' Support functions ' ----------------------------------------------------------------------------- Function _sendXTalkData(res%) ' Set the Xtalk data from generic configuration, or user's calibration. ' (`vl53_tmp_buf()` already contains the xtalk_data) Local Integer stat1 = 0, i, j, v, p11, p21 Local Integer sg(63) ' Copy xtalk data into temp buffer p11 = Peek(VarAddr vl53_xtalk_data()) P21 = Peek(VarAddr vl53_tmp_buf()) Memory Copy Integer p11, P21, VL53_KXTALK_DATA_SIZE If res% = VL53_RES_4x4 Then ' Data extrapolation is required for 4x4 Xtalk vl53_tmp_buf(&H08) = &H0F vl53_tmp_buf(&H08 +1) = &H04 vl53_tmp_buf(&H08 +2) = &H04 vl53_tmp_buf(&H08 +3) = &H17 vl53_tmp_buf(&H08 +4) = &H08 vl53_tmp_buf(&H08 +5) = &H10 vl53_tmp_buf(&H08 +6) = &H10 vl53_tmp_buf(&H08 +7) = &H07 vl53_tmp_buf(&H20) = &H00 vl53_tmp_buf(&H20 +1) = &H78 vl53_tmp_buf(&H20 +2) = &H00 vl53_tmp_buf(&H20 +3) = &H08 vl53_tmp_buf(&H20 +4) = &H00 vl53_tmp_buf(&H20 +5) = &H00 vl53_tmp_buf(&H20 +6) = &H00 vl53_tmp_buf(&H20 +7) = &H08 _swapBuffer vl53_tmp_buf(), VL53_KXTALK_DATA_SIZE For i=0 To 63 sg(i) = vl53_tmp_buf(&H34 +i) Next For j=0 To 3 For i=0 To 3 v = 0 Inc v, sg((2 *i) +(16 *j) +0) Inc v, sg((2 *i) +(16 *j) +1) Inc v, sg((2 *i) +(16 *j) +8) Inc v, sg((2 *i) +(16 *j) +9) sg(i +(4 *j)) = v \4 Next Next ' TODO: The cpp lib was a bit odd here, it appeared to memset well ' past the end of the arrays. Not sure if that was intentional or ' necessary ' It's possible these were located at known memory locations in the ' cpp lib and we wanted to zero out the stuff directly after them ' as well Memory Set Integer Peek(VarAddr sg()) +&H10 *8, 0, 64 -&H10 For i=0 To 63 vl53_tmp_buf(&H34 +i) = sg(i) Next _swapBuffer vl53_tmp_buf(), VL53_KXTALK_DATA_SIZE vl53_tmp_buf(&H134) = &HA0 vl53_tmp_buf(&H134 +1) = &HFC vl53_tmp_buf(&H134 +2) = &H01 vl53_tmp_buf(&H134 +3) = &H00 Memory Set Integer Peek(VarAddr vl53_tmp_buf()) +&H078 *8, 0, 4 EndIf _WriteI2CReg16Mult &H2CF8, vl53_tmp_buf(), VL53_KXTALK_DATA_SIZE stat1 = stat1 Or VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) _sendXTalkData = stat1 End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Function _sendOffsetData(resol%) ' Set the offset data gathered from NVM Local Integer stat1 = 0, i1, j1, v, p11, p21 Local Integer sg(63), rg(63) ' Copy offset data into temp buffer p11 = Peek(VarAddr vl53_offs_data()) p21 = Peek(VarAddr vl53_tmp_buf()) Memory Copy Integer p11, p21, VL53_KOFFS_DATA_SIZE If resol% = VL53_RES_4x4 Then vl53_tmp_buf(&H10) = &H0F vl53_tmp_buf(&H10 +1) = &H04 vl53_tmp_buf(&H10 +2) = &H04 vl53_tmp_buf(&H10 +3) = &H00 vl53_tmp_buf(&H10 +4) = &H08 vl53_tmp_buf(&H10 +5) = &H10 vl53_tmp_buf(&H10 +6) = &H10 vl53_tmp_buf(&H10 +7) = &H07 _swapBuffer vl53_tmp_buf(), VL53_KOFFS_DATA_SIZE For i1=0 To 63 sg(i1) = vl53_tmp_buf(&H03C +i1) rg(i1) = vl53_tmp_buf(&H140 +i1) Next For j1=0 To 3 For i1=0 To 3 v = 0 Inc v, sg((2 *i1) +(16 *j1) +0) Inc v, sg((2 *i1) +(16 *j1) +1) Inc v, sg((2 *i1) +(16 *j1) +8) Inc v, sg((2 *i1) +(16 *j1) +9) sg(i1 +(4 *j1)) = v \4 v = 0 Inc v, rg((2 *i1) +(16 *j1) +0) Inc v, rg((2 *i1) +(16 *j1) +1) Inc v, rg((2 *i1) +(16 *j1) +8) Inc v, rg((2 *i1) +(16 *j1) +9) rg(i1 +(4 *j1)) = v \4 Next Next ' TODO: The cpp lib was a bit odd here, it appeared to memset well ' past the end of the arrays. Not sure if that was intentional or ' necessary ' It's possible these were located at known memory locations in the ' cpp lib and we wanted to zero out the stuff directly after them ' as well Memory Set Integer Peek(VarAddr rg()) +&H10 *8, 0, 64 -&H10 Memory Set Integer Peek(VarAddr sg()) +&H10 *8, 0, 64 -&H10 For i1=0 To 63 vl53_tmp_buf(&H03C +i1) = sg(i1) vl53_tmp_buf(&H140 +i1) = rg(i1) Next _swapBuffer vl53_tmp_buf(), VL53_KOFFS_DATA_SIZE EndIf For i1=0 To VL53_KOFFS_DATA_SIZE -4 -1 vl53_tmp_buf(i1) = vl53_tmp_buf(i1 +8) Next vl53_tmp_buf(&H1E0) = 0 vl53_tmp_buf(&H1E0 +1) = 0 vl53_tmp_buf(&H1E0 +2) = 0 vl53_tmp_buf(&H1E0 +3) = &H0F vl53_tmp_buf(&H1E0 +4) = &H03 vl53_tmp_buf(&H1E0 +5) = &H01 vl53_tmp_buf(&H1E0 +6) = &H01 vl53_tmp_buf(&H1E0 +7) = &HE4 _WriteI2CReg16Mult &H2E18, vl53_tmp_buf(), VL53_KOFFS_DATA_SIZE stat1 = stat1 Or VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) _sendOffsetData = stat1 End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Function _DCIReadData(_data%(), index%, n%) ' Read 'extra data' from DCI, returns 0 if o.k. Local integer stat2 = 0, rd_size = n% +12, i Local integer cmd(11) = (0, 0, 0, 0, 0, 0, 0, &H0F, 0, &H02, 0, &H08) cmd(0) = index% >> 8 cmd(1) = index% And &HFF cmd(2) = (n% And &HFF0) >> 4 cmd(3) = (n% And &HF) << 4 ' Request data reading from FW _WriteI2CReg16Mult VL53_KUI_CMD_END -11, cmd(), 12 stat2 = stat2 Or VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) ' Read new data sent (4 bytes header + data_size + 8 bytes footer) _ReadI2CReg16Mult VL53_KUI_CMD_START, vl53_tmp_buf(), rd_size _swapBuffer vl53_tmp_buf(), rd_size For i=0 To n% -1 : _data%(i) = vl53_tmp_buf(i +4) : Next _DCIReadData = stat2 End Function Function _DCIWriteData(_data%(), index%, n%) ' Write 'extra data' to DCI, returns 0 if o.k. Local integer stat2 = 0, addr, i2 Local integer header(3), footer(7) = (0, 0, 0, &H0F, &H05, &H01, 0, 0) header(0) = index% >> 8 header(1) = index% And &HFF header(2) = (n% And &HFF0) >> 4 header(3) = (n% And &HF) << 4 footer(6) = (n% +8) >> 8 footer(7) = (n% +8) And &HFF addr = VL53_KUI_CMD_END -(n% +12) +1 ' Copy data from array to FW format (+4 bytes to add header) and ' add headers and footer _swapBuffer _data%(), n% For i2=n% -1 To 0 Step -1 : vl53_tmp_buf(i2 +4) = _data%(i2) : Next For i2=0 To 3 : vl53_tmp_buf(i2) = header(i2) : Next For i2=0 To 7 : vl53_tmp_buf(i2 +4 +n%) = footer(i2) : Next ' Send data to FW _WriteI2CReg16Mult addr, vl53_tmp_buf(), n% +12 stat2 = stat2 Or VL53._waitForStatus(4, 1, VL53_REG_CMD_STAT, &HFF, &H03) _swapBuffer _data%(), n% _DCIWriteData = stat2 End Function Function _DCIReplaceData(_data%(), index%, n%, _data2%(), n2%, p%) ' Replace 'extra data' in DCI, returns 0 if successful Local integer stat1 = 0, i stat1 = stat1 Or _DCIReadData(_data%(), index%, n%) For i=p% To p% +n2% -1 : _data%(i) = _data2%(i -p%) : Next stat1 = stat1 Or _DCIWriteData(_data%(), index%, n%) _DCIReplaceData = stat1 End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Sub _WriteI2CReg16 reg%, _val% ' Write a single byte to a 16-bit register Local Integer _data(2) _data(0) = (reg% >> 8) And &HFF _data(1) = reg% And &HFF _data(2) = _val% And &HFF I2C WRITE VL53_I2C_ADDR, 0, 3, _data() End Sub Sub _WriteI2CReg16Mult reg%, vals%(), n% ' Write multiple bytes to a 16-bit register Local Integer chMaxSize = 128, _data(chMaxSize +1) Local Integer i3, j3, nCh = n% \chMaxSize +1 Local Integer pCh, chLen, currReg, m If VL53_VERBOSE Then Print "_WriteI2CReg16Mult" For i3=0 To nCh -1 ' Send data in chunks currReg = reg% +i3 *chMaxSize _data(0) = (currReg >> 8) And &HFF _data(1) = currReg And &HFF pCh = i3 *chMaxSize chLen = Min(n% -chMaxSize *i3, chMaxSize) For j3=0 To chLen -1 ' Copy chunk to output array _data(2 +j3) = vals%(pCh +j3) And &HFF Next m = Choice(j3 < (chLen -1), 1, 0) I2C WRITE VL53_I2C_ADDR, m, chLen +2, _data() Next If VL53_VERBOSE Then _printByteArrayAsHex vals%(), n% End Sub Function _ReadI2CReg16(reg%) ' Read a single byte from a 16-bit register and returns the byte Local Integer _data(1), res3 _data(0) = (reg% >> 8) And &HFF _data(1) = reg% And &HFF I2C WRITE VL53_I2C_ADDR, 0, 2, _data() I2C READ VL53_I2C_ADDR, 0, 1, res3 _ReadI2CReg16 = res3 End Function Sub _ReadI2CReg16Mult reg%, vals%(), n% ' Read multiple bytes from a 16-bit register into `vals%()` I2C WRITE VL53_I2C_ADDR, 0, 2, (reg% >> 8) And &HFF, reg% And &HFF I2C READ VL53_I2C_ADDR, 0, n%, vals%() End Sub Sub _swapBuffer buf%(), size% ' Reverse the sequence of groups of 4 values Local Integer tmp3(size% -1), n3 = size% /4 Local Integer pb = Peek(VarAddr buf%()), pt = Peek(VarAddr tmp3()) Memory Copy Integer pb, pt+24, n3, 4, 4 Memory Copy Integer pb+8, pt+16, n3, 4, 4 Memory Copy Integer pb+16, pt+8, n3, 4, 4 Memory Copy Integer pb+24, pt, n3, 4, 4 Memory Copy Integer pt, pb, size% End Sub Sub _uint32ArrayToBytes _uint32%(), _bytes%(), n_uint32% ' Converts a list of uint32 values to a list of bytes. Local Integer i3 Math Set 0, _bytes%() For i3=0 To n_uint32% -1 _bytes%(i3*4) = _uint32(i3) And &HFF _bytes%(i3*4 +1) = (_uint32(i3) >> 8) And &HFF _bytes%(i3*4 +2) = (_uint32(i3) >> 16) And &HFF _bytes%(i3*4 +3) = _uint32(i3) >> 24 Next End Sub /* Function _BytesToUI32Arr(_bytes%(), _uint32%(), p%, n%) ' Converts a list of `n% bytes into uint32 values, starting from byte `p% ' Returns 0 if successful Local Integer nb, i3, tmp3(3) Local Integer pb3 = Peek(VarAddr _bytes%()) +p% Local Integer pt3 = Peek(VarAddr tmp3()) nb = Choice(n% = 0, Bound(_bytes%()) +1 -p%, n%) If (nb Mod 4) <> 0 Then _BytesToUI32Arr = -1 Else If (Bound(_uint32%()) +1) < (nb \4) Then _BytesToUI32Arr = -1 Else For i3=0 To nb-1 Step 4 Memory Copy pb3 +p% +i3*4, pt3, 4 Memory Pack tmp3(), Peek(VarAddr _uint32%()) +i3\4, 4, 8 Next EndIf _BytesToUI32Arr = 0 End Function */ Function _BytesToI16Arr(_bytes%(), _int16%(), p%, n%) ' Converts a list of `n%` bytes into int16 values, starting from byte `p%`; ' returns 0 if successful 'Local Integer i3 Local Integer _pb = Peek(VarAddr _bytes%()) +p% *8 Local Integer _pi = Peek(VarAddr _int16%()) If (n% Mod 2) <> 0 Then _BytesToI16Arr = -1 Else If (Bound(_int16%()) +1) < (n% \2) Then _BytesToI16Arr = -1 Else Memory Copy _pb, _pi, n%, 16, 8 Memory Copy _pb +8, _pi +1, n%, 16, 8 /* _printByteArrayAsHex _bytes%(), n%, p% _printByteArrayAsHex _int16%(), n% \2 For i3=0 To n%-1 Step 2 _int16%(i3 \2) = (_bytes%(p% +i3 +1) << 8) Or _bytes%(p% +i3) 'If _int16%(i3 \2) > 32767 Then Inc _int16%(i3 \2), -65536 Next _printByteArrayAsHex _int16%(), n% \2 */ _BytesToI16Arr = 0 EndIf End Function ' - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Sub _printByteArrayAsHex _array%(), _size%, _p% Local Integer i2 For i2=_p% To _size% +_p% -1 If (i2 Mod 16) = 0 Then Print Str$(i2, 3);": "; Print Hex$(_array%(i2), 2);" "; If ((i2 +1) Mod 16) = 0 Or i2 = (_size% -1) Then Print Next End Sub Sub _printMat m%(), title$, dy%, scl! ' Print `m%() as matrix, convert to matrix, if 1D, and scale it by `scl` Local Integer nx = Bound(m%(), 1), ny = Bound(m%(), 2) Local Integer ix, iy, nn = 0 If scl! = 0 Then scl! = 1 ' Make sure that data is in matrix form and scale If ny = 0 Then nn = nx +1 nx = nn \dy% -1 ny = dy% -1 Else nn = (nx +1) *(ny +1) EndIf Local Integer tmp2d(nx, ny), pt = Peek(VarAddr tmp2d()) Memory Copy Integer Peek(VarAddr m%()), pt, nn Local Float vals(nx, ny) Math Scale tmp2d(), scl!, vals() ' Print matrix Print "| ";title$ For iy=0 To ny Print "| "; For ix=0 To nx : Print Str$(vals(ix, iy), 4, 1) +" "; : Next Next End Sub ' ----------------------------------------------------------------------------- |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1156 |
Many thanks for sharing! Frank |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6195 |
Hi Thomas, Thanks for sharing. Your output is currently numerical. Is this going to feed a robot for autonomous movement ? The range is up to 2 meters, correct ? Volhout PicomiteVGA PETSCII ROBOTS |
Hi Volhout, Yes, this is just the driver "VL53.update_data" updates the global structure "vl53_data()", which contains 64 (8x8) distance measurements in mm plus for each pixel some information about measurement reliability. The range is up to 2 m, under good conditions. The data is a in linear array for simplicity, it needs to be mapped to a 8x8 array to get the spatial arrangement back. My robot code (to be published soon) uses this driver as a library to calculate distances in front of the robot. Currently, I am working on filtering the data for reliability and calculating the distances relative to a flat surface to detect obstacles and cliffs. These data will then steer the robot. Best Thomas |
