Local Time 00:52 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RS232 serial interface to PicoMite
mhoward
Posted: 10:04pm 05 Jan 2026
I recently put together a PicoMite so I could program in BASIC. I would like to do this
"old school" if possible. I have a VT100 terminal with a RS232 serial port and I purchased an Adafruit RS232 Full Breakout module (part # 6253). I'm not sure how to
connect the module to the PicoMite and also how configure it. If possible I would like
the USB port and the RS232 port to be active at the same time. I would really appreciate some help with my project.
Thanks,
Mike
homa
Posted: 10:19pm 05 Jan 2026
COM1 Valid pins are
RX: GP1, GP13 or GP17
TX: GP0, GP12, GP16 or GP28
or
COM2 Valid pins are
RX: GP5, GP9 or GP21
TX: GP4, GP8 or GP20
with your Adafruit RS232 Full Breakout module (part # 6253).
AND
OPTION SERIAL CONSOLE uartapin, uartbpin [,B]
Specify that the console be accessed via a hardware serial port (instead
of virtual serial over USB).
‘uartapin’ and ‘uartbpin’ can be any valid pair of rx and tx pins for either
COM1 or COM2. The order that they are specified is not important.
The speed defaults to 115200 baud but can be changed with OPTION
BAUDRATE. Adding the "B" parameter means output will go to "B"oth
the serial port and the USB.
OPTION SERIAL CONSOLE DISABLE
Revert to the normal the USB console.
These commands must be run at the command prompt (not in a program).
Posted: 11:48pm 05 Jan 2026
Adafruit RS232 Full Breakout module (part # 6253) uses the TI MAX3243 chip.
The data sheet says its maximum RS232 signal voltages are +/-7V with a maximum difference of 13V.
Much older equipment requires a minimum of +/-10V and maximum of +/-20V as that was the original RS232 specification.
Several decades ago , after encountering that issue, I made a transistor inverter / level shifter / +/-12v voltage generator module for Rx and Tx. If you need that I will try to find the circuit.
Also some old equipment requires additional hardware I/O signals that your module can pass through but the Pico does not supply/accept.
If that is the case you may be able to deal with that in a program but the console and editor could be a problem.
mhoward
Posted: 12:17am 06 Jan 2026
When I input command:  OPTION SERIAL CONSOLE GP5, GP4 [,B]   I get Error: Expression Syntax.
I have used my VT100 on a Raspberry Pi 4b with a serial hat and it worked fine.
PhenixRising
Posted: 12:57am 06 Jan 2026
Only on my phone, no docs.
I suspect that the [,B] is where you specify the baud. Just a numeric value, without the brackets which usually mean that the value is optional
Posted: 01:00am 06 Jan 2026
[,xx] signifies that is where you place an optional parameter. In this case that is "B" so try :-
OPTION SERIAL CONSOLE GP5, GP4 ,B
If you didn't get an error message it has ignored the parameter and you may no longer have the USB console.
If that is the case connect a USB-to-TTL Serial module to GP8 and GP9 plus ground as per the manual then enter :-
 to restore the USB console so you can enter :-
Edited 2026-01-06 11:07 by phil99
Posted: 01:01am 06 Jan 2026
  mhoward said  When I input command:  OPTION SERIAL CONSOLE GP5, GP4 [,B]   I get Error: Expression Syntax.
You do know that the B is optional? Either OPTION SERIAL CONSOLE GP5, GP4 or
OPTION SERIAL CONSOLE GP5, GP4, B
toml_12953
Posted: 04:52am 06 Jan 2026
  PhenixRising said  Only on my phone, no docs.
The B is for Both. Both the USB serial port and the pins can be used when that's specified. You add ,B to the end of the command. No brackets.
