Local Time 01:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : <img border=
homa
Posted: 12:00pm 30 Dec 2025
> option list
PicoMite MMBasic RP2040 V6.01.00
OPTION COLOURCODE ON
OPTION CONTINUATION LINES ON
OPTION CPUSPEED (KHz) 200000
OPTION DISPLAY 40, 80
> list
Dim integer s(9)=(1,2,3,4,5,6,7,8,9,10), t(9)
Array Insert t(),s()
> run
[2] Array Insert t(),s()
Error : Argument count
Question: What is the easiest way to copy one array into another? Without using a loop!
Direct assignment is unfortunately not possible: t()=s()
“Array Insert” is only for multidimensional arrays?!
Or am I missing something here? “Array Insert t(), ,s()” doesn't work either.
Posted: 12:06pm 30 Dec 2025
manual page 139
  Quote  MATH SCALE in(), scale,out()
This scales the matrix in() by the scalar scale and puts the answer in out().
Works for arrays of any dimensionality of both integer and float and can
convert between. Setting b to 1 is optimised and is the fastest way of copying
an entire array.
homa
Posted: 12:15pm 30 Dec 2025
Thanks, works! I hadn't even considered MATH ...
Read it right away :-)
bfwolf
Posted: 04:38pm 30 Dec 2025
Found an other way in the manual (but didn't try):
  Quote  ARRAY ADD in(),value,out()
This adds (or appends for strings) the value 'value' to every element of the
matrix in() and puts the answer in out(). Works for arrays of any
dimensionality of strings and both integer and float (can convert between
integer and float). Setting num to 0 or “” is optimised and is a fast way of
copying an entire array.
in() and out() can be the same array.
This is also "more obvious" because it is also an 'ARRAY' command.
So @homa: You looked just 1 "table line" too far down..
Edited 2025-12-31 02:38 by bfwolf
homa
Posted: 11:17pm 30 Dec 2025
Sometimes examples are more helpful than reading manuals!
@bfwolf Further exciting findings:
> list
Dim integer s(9)=(5,1,3,4,7,7,3,0,0,1),t(9)
Dim integer x,i
Math v_print s()
x=Math(max s(),i)
Print x,i
Array Add s(),0,t()
Math v_print t()
Array Add s(),-1,t()
Math v_print t()
Array Set 0,t()
Math v_print t()
Math scale s(),1,t()
Math v_print t()
Math scale s(),2,t()
Math v_print t()
> run
5, 1, 3, 4, 7, 7, 3, 0, 0, 1
7       4
4, 0, 2, 3, 6, 6, 2, -1, -1, 0
0, 0, 0, 0, 0, 0, 0, 0, 0, 0
10, 2, 6, 8, 14, 14, 6, 0, 0, 2
