Forum Index : Microcontroller and PC projects : How about this for a Christmas surprise?
| Page 1 of 4 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12057 |
MMBasic_Structures_Manual.pdf PicoMiteRP2350 version to play with PicoMiteRP2350EXP.zip Test script ' Comprehensive Structure Test for PicoMite ' Tests all implemented struct features Option Explicit Option Default None Print "=== Structure Tests ===" ' ============================================ ' TEST 1: Basic TYPE definition and simple struct ' ============================================ Print "TEST 1: Basic struct definition and access" Type Point x As INTEGER y As INTEGER End Type Dim p1 As Point p1.x = 100 p1.y = 200 If p1.x = 100 And p1.y = 200 Then Print " PASS: Simple struct assignment and read" Else Print " FAIL: Expected 100,200 got"; p1.x; ","; p1.y EndIf ' ============================================ ' TEST 2: Struct with different member types ' ============================================ Print "TEST 2: Struct with mixed types" Type Person age As INTEGER height As FLOAT name As STRING End Type Dim person1 As Person person1.age = 42 person1.height = 1.85 person1.name = "John" If person1.age = 42 And person1.height = 1.85 And person1.name = "John" Then Print " PASS: Mixed type struct" Else Print " FAIL: Mixed type struct failed" EndIf ' ============================================ ' TEST 3: Array of structures ' ============================================ Print "TEST 3: Array of structures" Dim points(5) As Point points(0).x = 10 : points(0).y = 11 points(1).x = 20 : points(1).y = 21 points(2).x = 30 : points(2).y = 31 points(3).x = 40 : points(3).y = 41 points(4).x = 50 : points(4).y = 51 points(5).x = 60 : points(5).y = 61 Dim ok% = 1 Dim i% For i% = 0 To 5 If points(i%).x <> (i% + 1) * 10 Or points(i%).y <> (i% + 1) * 10 + 1 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Array of structs" Else Print " FAIL: Array of structs" EndIf ' ============================================ ' TEST 4: Pass struct to SUB by reference ' ============================================ Print "TEST 4: Pass struct to SUB by reference" Sub DoublePoint(pt As Point) pt.x = pt.x * 2 pt.y = pt.y * 2 End Sub Dim p2 As Point p2.x = 5 p2.y = 7 DoublePoint p2 If p2.x = 10 And p2.y = 14 Then Print " PASS: Struct passed by reference modified caller" Else Print " FAIL: Expected 10,14 got"; p2.x; ","; p2.y EndIf ' ============================================ ' TEST 5: Pass array element to SUB ' ============================================ Print "TEST 5: Pass array element to SUB" Dim arr(3) As Point arr(1).x = 100 arr(1).y = 200 DoublePoint arr(1) If arr(1).x = 200 And arr(1).y = 400 Then Print " PASS: Array element passed by reference" Else Print " FAIL: Expected 200,400 got"; arr(1).x; ","; arr(1).y EndIf ' ============================================ ' TEST 6: Pass struct array to SUB ' ============================================ Print "TEST 6: Pass struct array to SUB" Sub SumPoints(pts() As Point, count%) Local sum_x% = 0, sum_y% = 0 Local j% For j% = 0 To count% - 1 sum_x% = sum_x% + pts(j%).x sum_y% = sum_y% + pts(j%).y Next j% Print " Sum X ="; sum_x%; ", Sum Y ="; sum_y% End Sub Dim testArr(2) As Point testArr(0).x = 1 : testArr(0).y = 2 testArr(1).x = 3 : testArr(1).y = 4 testArr(2).x = 5 : testArr(2).y = 6 Print " Calling SumPoints (expect Sum X=9, Sum Y=12):" SumPoints testArr(), 3 Print " PASS: Array of structs passed to SUB (verify output above)" ' ============================================ ' TEST 7: Modify struct array in SUB ' ============================================ Print "TEST 7: Modify struct array elements in SUB" Sub ZeroPoints(pts() As Point, count%) Local k% For k% = 0 To count% - 1 pts(k%).x = 0 pts(k%).y = 0 Next k% End Sub ZeroPoints testArr(), 3 ok% = 1 For i% = 0 To 2 If testArr(i%).x <> 0 Or testArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: SUB modified caller's struct array" Else Print " FAIL: Array not properly zeroed" EndIf ' ============================================ ' TEST 8: STRUCT COPY command ' ============================================ Print "TEST 8: STRUCT COPY command" Dim src As Point, dst As Point src.x = 999 src.y = 888 dst.x = 0 dst.y = 0 Struct Copy src To dst If dst.x = 999 And dst.y = 888 Then Print " PASS: STRUCT COPY works" Else Print " FAIL: Expected 999,888 got"; dst.x; ","; dst.y EndIf ' ============================================ ' TEST 9: STRUCT COPY with mixed types ' ============================================ Print "TEST 9: STRUCT COPY with mixed types" Dim src_person As Person, dst_person As Person src_person.age = 25 src_person.height = 1.75 src_person.name = "Alice" Struct Copy src_person To dst_person If dst_person.age = 25 And dst_person.height = 1.75 And dst_person.name = "Alice" Then Print " PASS: STRUCT COPY with mixed types" Else Print " FAIL: STRUCT COPY mixed types failed" EndIf ' ============================================ ' TEST 10: Function returning value from struct member ' ============================================ Print "TEST 10: Function using struct member" Function GetDistance(pt As Point) As FLOAT GetDistance = Sqr(pt.x * pt.x + pt.y * pt.y) End Function Dim p3 As Point p3.x = 3 p3.y = 4 Dim dist! = GetDistance(p3) If dist! = 5 Then Print " PASS: Function with struct parameter" Else Print " FAIL: Expected 5 got"; dist! EndIf ' ============================================ ' TEST 11: Nested struct access in expressions ' ============================================ Print "TEST 11: Struct members in expressions" Dim pA As Point, pB As Point pA.x = 10 : pA.y = 20 pB.x = 30 : pB.y = 40 Dim sum_expr% = pA.x + pB.x + pA.y + pB.y If sum_expr% = 100 Then Print " PASS: Struct members in expressions" Else Print " FAIL: Expected 100 got"; sum_expr% EndIf ' ============================================ ' TEST 12: Array index with variable ' ============================================ Print "TEST 12: Array of structs with variable index" Dim dynArr(9) As Point For i% = 0 To 9 dynArr(i%).x = i% * 2 dynArr(i%).y = i% * 3 Next i% ok% = 1 For i% = 0 To 9 If dynArr(i%).x <> i% * 2 Or dynArr(i%).y <> i% * 3 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Variable index into struct array" Else Print " FAIL: Variable index failed" EndIf ' ============================================ ' TEST 13: Multiple struct types ' ============================================ Print "TEST 13: Multiple struct type definitions" Type Rectangle left As INTEGER top As INTEGER width As INTEGER height As INTEGER End Type Type Circle cx As INTEGER cy As INTEGER radius As FLOAT End Type Dim rect As Rectangle Dim circ As Circle rect.left = 10 : rect.top = 20 : rect.width = 100 : rect.height = 50 circ.cx = 50 : circ.cy = 50 : circ.radius = 25.5 If rect.left = 10 And rect.width = 100 And circ.radius = 25.5 Then Print " PASS: Multiple struct types" Else Print " FAIL: Multiple struct types" EndIf ' ============================================ ' TEST 14: Struct parameter not modified without assignment ' ============================================ Print "TEST 14: Read-only access in SUB" Sub ReadOnlyTest(pt As Point) Local val% = pt.x + pt.y Print " Read value:"; val% End Sub Dim p4 As Point p4.x = 111 p4.y = 222 ReadOnlyTest p4 If p4.x = 111 And p4.y = 222 Then Print " PASS: Struct unchanged after read-only access" Else Print " FAIL: Struct was unexpectedly modified" EndIf ' ============================================ ' TEST 15: Simple struct initialization ' ============================================ Print "TEST 15: Simple struct initialization" Dim initPoint As Point = (42, 99) If initPoint.x = 42 And initPoint.y = 99 Then Print " PASS: Simple struct initialization" Else Print " FAIL: Expected 42,99 got"; initPoint.x; ","; initPoint.y EndIf ' ============================================ ' TEST 16: Struct with string initialization ' ============================================ Print "TEST 16: Struct with string initialization" Dim initPerson As Person = (30, 1.80, "Bob") If initPerson.age = 30 And initPerson.height = 1.80 And initPerson.name = "Bob" Then Print " PASS: Struct with string initialization" Else Print " FAIL: Struct with string init failed" EndIf ' ============================================ ' TEST 17: Array of structs initialization ' ============================================ Print "TEST 17: Array of structs initialization" Dim initArr(1) As Point = (10, 20, 30, 40) If initArr(0).x = 10 And initArr(0).y = 20 And initArr(1).x = 30 And initArr(1).y = 40 Then Print " PASS: Array of structs initialization" Else Print " FAIL: Array init got"; initArr(0).x; ","; initArr(0).y; ","; initArr(1).x; ","; initArr(1).y EndIf ' ============================================ ' TEST 18: Mixed type struct array initialization ' ============================================ Print "TEST 18: Mixed type struct array initialization" Type TestStruct num As INTEGER txt As STRING End Type Dim mixArr(1) As TestStruct = (100, "first", 200, "second") If mixArr(0).num = 100 And mixArr(0).txt = "first" And mixArr(1).num = 200 And mixArr(1).txt = "second" Then Print " PASS: Mixed type struct array initialization" Else Print " FAIL: Mixed init failed" EndIf ' ============================================ ' TEST 19: LOCAL struct in subroutine ' ============================================ Print "TEST 19: LOCAL struct in subroutine" Sub TestLocalStruct Local localPt As Point localPt.x = 555 localPt.y = 666 Print " Local struct values:"; localPt.x; ","; localPt.y If localPt.x = 555 And localPt.y = 666 Then Print " PASS: LOCAL struct works" Else Print " FAIL: LOCAL struct failed" EndIf End Sub TestLocalStruct ' ============================================ ' TEST 20: LOCAL struct array in subroutine ' ============================================ Print "TEST 20: LOCAL struct array in subroutine" Sub TestLocalStructArray Local localArr(2) As Point localArr(0).x = 1 : localArr(0).y = 2 localArr(1).x = 3 : localArr(1).y = 4 localArr(2).x = 5 : localArr(2).y = 6 Local ok% = 1 If localArr(0).x <> 1 Or localArr(0).y <> 2 Then ok% = 0 If localArr(1).x <> 3 Or localArr(1).y <> 4 Then ok% = 0 If localArr(2).x <> 5 Or localArr(2).y <> 6 Then ok% = 0 If ok% Then Print " PASS: LOCAL struct array works" Else Print " FAIL: LOCAL struct array failed" EndIf End Sub TestLocalStructArray ' ============================================ ' TEST 21: LOCAL struct with initialization ' ============================================ Print "TEST 21: LOCAL struct with initialization" Sub TestLocalStructInit Local initPt As Point = (777, 888) If initPt.x = 777 And initPt.y = 888 Then Print " PASS: LOCAL struct initialization works" Else Print " FAIL: Expected 777,888 got"; initPt.x; ","; initPt.y EndIf End Sub TestLocalStructInit ' ============================================ ' TEST 22: Multiple LOCAL struct calls (memory test) ' ============================================ Print "TEST 22: Multiple LOCAL struct calls (memory test)" Sub MemTest Local tmp As Point tmp.x = 123 tmp.y = 456 End Sub ' Call multiple times to verify memory is properly freed MemTest MemTest MemTest MemTest MemTest Print " PASS: Multiple LOCAL struct calls completed (no memory error)" ' ============================================ ' TEST 23: STRUCT SORT by integer field ' ============================================ Print "TEST 23: STRUCT SORT by integer field" Dim sortArr(4) As Point sortArr(0).x = 50 : sortArr(0).y = 5 sortArr(1).x = 20 : sortArr(1).y = 2 sortArr(2).x = 40 : sortArr(2).y = 4 sortArr(3).x = 10 : sortArr(3).y = 1 sortArr(4).x = 30 : sortArr(4).y = 3 Struct Sort sortArr(), x If sortArr(0).x = 10 And sortArr(1).x = 20 And sortArr(2).x = 30 And sortArr(3).x = 40 And sortArr(4).x = 50 Then Print " PASS: STRUCT SORT by integer ascending" Else Print " FAIL: Sort order wrong" EndIf ' ============================================ ' TEST 24: STRUCT SORT reverse ' ============================================ Print "TEST 24: STRUCT SORT reverse" Struct Sort sortArr(), x, 1 If sortArr(0).x = 50 And sortArr(1).x = 40 And sortArr(2).x = 30 And sortArr(3).x = 20 And sortArr(4).x = 10 Then Print " PASS: STRUCT SORT reverse" Else Print " FAIL: Reverse sort order wrong" EndIf ' ============================================ ' TEST 25: STRUCT SORT by string field ' ============================================ Print "TEST 25: STRUCT SORT by string field" Type NamedItem id As INTEGER name As STRING End Type Dim items(4) As NamedItem items(0).id = 1 : items(0).name = "Cherry" items(1).id = 2 : items(1).name = "Apple" items(2).id = 3 : items(2).name = "Elderberry" items(3).id = 4 : items(3).name = "Banana" items(4).id = 5 : items(4).name = "Date" Struct Sort items(), name If items(0).name = "Apple" And items(1).name = "Banana" And items(2).name = "Cherry" And items(3).name = "Date" And items(4).name = "Elderberry" Then Print " PASS: STRUCT SORT by string" Else Print " FAIL: String sort wrong:"; items(0).name; ","; items(1).name; ","; items(2).name EndIf ' Verify ID followed the sort If items(0).id = 2 And items(1).id = 4 And items(2).id = 1 Then Print " PASS: Other fields preserved during sort" Else Print " FAIL: ID values not preserved" EndIf ' ============================================ ' TEST 26: STRUCT SORT case insensitive ' ============================================ Print "TEST 26: STRUCT SORT case insensitive" items(0).name = "cherry" items(1).name = "APPLE" items(2).name = "Elderberry" items(3).name = "banana" items(4).name = "DATE" Struct Sort items(), name, 2 If Left$(items(0).name, 1) = "A" Or Left$(items(0).name, 1) = "a" Then Print " PASS: STRUCT SORT case insensitive (Apple/APPLE first)" Else Print " FAIL: Case insensitive sort wrong, first="; items(0).name EndIf ' ============================================ ' TEST 27: STRUCT SORT by float field ' ============================================ Print "TEST 27: STRUCT SORT by float field" Type Measurement value As FLOAT label As STRING End Type Dim measurements(3) As Measurement measurements(0).value = 3.14 : measurements(0).label = "pi" measurements(1).value = 1.41 : measurements(1).label = "sqrt2" measurements(2).value = 2.71 : measurements(2).label = "e" measurements(3).value = 0.57 : measurements(3).label = "euler" Struct Sort measurements(), value If measurements(0).value < measurements(1).value And measurements(1).value < measurements(2).value And measurements(2).value < measurements(3).value Then Print " PASS: STRUCT SORT by float" Else Print " FAIL: Float sort wrong" EndIf ' ============================================ ' TEST 28: STRUCT SORT empty strings at end ' ============================================ Print "TEST 28: STRUCT SORT empty strings at end" items(0).name = "Zebra" items(1).name = "" items(2).name = "Apple" items(3).name = "" items(4).name = "Mango" Struct Sort items(), name, 4 If items(3).name = "" And items(4).name = "" And items(0).name <> "" Then Print " PASS: STRUCT SORT empty strings at end" Else Print " FAIL: Empty strings not at end" EndIf ' ============================================ ' TEST 29: Function returning struct ' ============================================ Print "TEST 29: Function returning struct" Dim p29 As Point p29 = MakePoint(123, 456) If p29.x = 123 And p29.y = 456 Then Print " PASS: Function returning struct" Else Print " FAIL: Expected 123,456 got"; p29.x; ","; p29.y EndIf ' ============================================ ' TEST 30: Function returning struct with Person (multiple types) ' ============================================ Print "TEST 30: Function returning struct with mixed types" Dim p30 As Person p30 = MakePerson("Bob", 35, 1.75) If p30.name = "Bob" And p30.age = 35 And Abs(p30.height - 1.75) < 0.01 Then Print " PASS: Function returning struct with mixed types" Else Print " FAIL: Expected Bob,35,1.75 got"; p30.name; ","; p30.age; ","; p30.height EndIf ' ============================================ ' TEST 31: Struct packing - string followed by int/float (non-8 aligned) ' ============================================ Print "TEST 31: Struct packing with short string before int/float" Type PackTest label As STRING LENGTH 5 value As INTEGER ratio As FLOAT End Type Dim pk As PackTest pk.label = "Test" pk.value = 12345 pk.ratio = 3.14 If pk.label = "Test" And pk.value = 12345 And Abs(pk.ratio - 3.14) < 0.01 Then Print " PASS: Struct packing with short string" Else Print " FAIL: Got label="; pk.label; " value="; pk.value; " ratio="; pk.ratio EndIf ' ============================================ ' TEST 32: Function returning struct with array member ' ============================================ Print "TEST 32: Function returning struct with array member" Type WithArray id As INTEGER values(3) As INTEGER End Type Dim wa As WithArray wa = MakeWithArray(99, 10, 20, 30, 40) If wa.id = 99 And wa.values(0) = 10 And wa.values(1) = 20 And wa.values(2) = 30 And wa.values(3) = 40 Then Print " PASS: Function returning struct with array member" Else Print " FAIL: Got id="; wa.id; " values="; wa.values(0); ","; wa.values(1); ","; wa.values(2); ","; wa.values(3) EndIf ' ============================================ ' TEST 33: STRUCT CLEAR - single struct ' ============================================ Print "TEST 33: STRUCT CLEAR - single struct" Dim clearTest As Person clearTest.age = 42 clearTest.height = 1.85 clearTest.name = "TestName" Struct Clear clearTest If clearTest.age = 0 And clearTest.height = 0 And clearTest.name = "" Then Print " PASS: STRUCT CLEAR single struct" Else Print " FAIL: Got age="; clearTest.age; " height="; clearTest.height; " name="; clearTest.name EndIf ' ============================================ ' TEST 34: STRUCT CLEAR - array of structs ' ============================================ Print "TEST 34: STRUCT CLEAR - array of structs" Dim clearArr(2) As Point clearArr(0).x = 1 : clearArr(0).y = 2 clearArr(1).x = 3 : clearArr(1).y = 4 clearArr(2).x = 5 : clearArr(2).y = 6 Struct Clear clearArr() ok% = 1 For i% = 0 To 2 If clearArr(i%).x <> 0 Or clearArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: STRUCT CLEAR array of structs" Else Print " FAIL: Array not properly cleared" EndIf ' ============================================ ' TEST 35: STRUCT SWAP ' ============================================ Print "TEST 35: STRUCT SWAP" Dim swapA As Point, swapB As Point swapA.x = 100 : swapA.y = 200 swapB.x = 300 : swapB.y = 400 Struct Swap swapA, swapB If swapA.x = 300 And swapA.y = 400 And swapB.x = 100 And swapB.y = 200 Then Print " PASS: STRUCT SWAP" Else Print " FAIL: Got A="; swapA.x; ","; swapA.y; " B="; swapB.x; ","; swapB.y EndIf ' ============================================ ' TEST 36: STRUCT SWAP with array elements ' ============================================ Print "TEST 36: STRUCT SWAP with array elements" Dim swapArr(1) As Person swapArr(0).name = "Alice" : swapArr(0).age = 25 : swapArr(0).height = 1.60 swapArr(1).name = "Bob" : swapArr(1).age = 30 : swapArr(1).height = 1.80 Struct Swap swapArr(0), swapArr(1) If swapArr(0).name = "Bob" And swapArr(0).age = 30 And swapArr(1).name = "Alice" And swapArr(1).age = 25 Then Print " PASS: STRUCT SWAP array elements" Else Print " FAIL: Swap array elements failed" EndIf ' ============================================ ' TEST 37: STRUCT(FIND) - find by integer member ' ============================================ Print "TEST 37: STRUCT(FIND) - find by integer" Dim findArr(4) As Person findArr(0).name = "Alice" : findArr(0).age = 25 findArr(1).name = "Bob" : findArr(1).age = 30 findArr(2).name = "Charlie" : findArr(2).age = 35 findArr(3).name = "Diana" : findArr(3).age = 40 findArr(4).name = "Eve" : findArr(4).age = 45 Dim foundIdx% = Struct(FIND, findArr(), "age", 35) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by integer found at index 2" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 38: STRUCT(FIND) - find by string member ' ============================================ Print "TEST 38: STRUCT(FIND) - find by string" foundIdx% = Struct(FIND, findArr(), "name", "Diana") If foundIdx% = 3 Then Print " PASS: STRUCT(FIND) by string found at index 3" Else Print " FAIL: Expected index 3, got"; foundIdx% EndIf ' ============================================ ' TEST 39: STRUCT(FIND) - not found returns -1 ' ============================================ Print "TEST 39: STRUCT(FIND) - not found" foundIdx% = Struct(FIND, findArr(), "name", "Zara") If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) returns -1 when not found" Else Print " FAIL: Expected -1, got"; foundIdx% EndIf ' ============================================ ' TEST 40: STRUCT(FIND) - find by float member ' ============================================ Print "TEST 40: STRUCT(FIND) - find by float" findArr(2).height = 1.77 foundIdx% = Struct(FIND, findArr(), "height", 1.77) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by float" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 42: STRUCT(FIND) with start parameter - iterate through duplicates ' ============================================ Print "TEST 42: STRUCT(FIND) with start parameter" ' Add duplicate ages findArr(0).age = 30 ' Alice now 30 findArr(1).age = 30 ' Bob already 30 findArr(4).age = 30 ' Eve now 30 ' Find first person with age 30 foundIdx% = Struct(FIND, findArr(), "age", 30) If foundIdx% <> 0 Then Print " FAIL: First match should be index 0, got"; foundIdx% Else ' Find next person with age 30 starting after first match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 1 Then Print " FAIL: Second match should be index 1, got"; foundIdx% Else ' Find next person with age 30 starting after second match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 4 Then Print " FAIL: Third match should be index 4, got"; foundIdx% Else ' Try to find another - should return -1 foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) with start parameter iterates correctly" Else Print " FAIL: Should return -1 after last match, got"; foundIdx% EndIf EndIf EndIf EndIf ' Restore original ages for remaining tests findArr(0).age = 25 : findArr(1).age = 30 : findArr(4).age = 45 ' ============================================ ' TEST 41: STRUCT SAVE and LOAD ' ============================================ Print "TEST 41: STRUCT SAVE and LOAD" ' Create test data Dim saveArr(2) As Person saveArr(0).name = "Alice" : saveArr(0).age = 25 : saveArr(0).height = 1.65 saveArr(1).name = "Bob" : saveArr(1).age = 30 : saveArr(1).height = 1.75 saveArr(2).name = "Charlie" : saveArr(2).age = 35 : saveArr(2).height = 1.85 ' Save to file Open "structtest.dat" For Output As #1 Struct Save #1, saveArr() Close #1 ' Clear the array Struct Clear saveArr() ' Verify cleared ok% = 1 For i% = 0 To 2 If saveArr(i%).name <> "" Or saveArr(i%).age <> 0 Then ok% = 0 Next i% If ok% = 0 Then Print " FAIL: Array not cleared before load test" Else ' Load back from file Open "structtest.dat" For Input As #1 Struct Load #1, saveArr() Close #1 ' Verify data - check each condition separately to avoid line continuation issues Dim loadOk% = 1 If saveArr(0).name <> "Alice" Or saveArr(0).age <> 25 Then loadOk% = 0 If Abs(saveArr(0).height - 1.65) >= 0.01 Then loadOk% = 0 If saveArr(1).name <> "Bob" Or saveArr(1).age <> 30 Then loadOk% = 0 If Abs(saveArr(1).height - 1.75) >= 0.01 Then loadOk% = 0 If saveArr(2).name <> "Charlie" Or saveArr(2).age <> 35 Then loadOk% = 0 If Abs(saveArr(2).height - 1.85) >= 0.01 Then loadOk% = 0 If loadOk% Then Print " PASS: STRUCT SAVE/LOAD" Else Print " FAIL: Data mismatch after load" Print " [0] "; saveArr(0).name; ","; saveArr(0).age; ","; saveArr(0).height Print " [1] "; saveArr(1).name; ","; saveArr(1).age; ","; saveArr(1).height Print " [2] "; saveArr(2).name; ","; saveArr(2).age; ","; saveArr(2).height EndIf EndIf ' Clean up test file Kill "structtest.dat" ' ============================================ ' TEST 43: STRUCT PRINT - single struct ' ============================================ Print "TEST 43: STRUCT PRINT - single struct" Print " Output should show Person structure with Alice, 25, 1.65:" Dim printTest As Person printTest.name = "Alice" printTest.age = 25 printTest.height = 1.65 Struct Print printTest Print " PASS: (verify output above manually)" ' ============================================ ' TEST 44: STRUCT PRINT - array element ' ============================================ Print "TEST 44: STRUCT PRINT - array element" Print " Output should show Point structure with x=100, y=200:" Dim printArr(2) As Point printArr(0).x = 100 : printArr(0).y = 200 printArr(1).x = 300 : printArr(1).y = 400 Struct Print printArr(0) Print " PASS: (verify output above manually)" ' ============================================ ' TEST 45: STRUCT PRINT - whole array ' ============================================ Print "TEST 45: STRUCT PRINT - whole array" Print " Output should show 2 Point elements:" Struct Print printArr() Print " PASS: (verify output above manually)" ' ============================================ ' TEST 46: STRUCT(SIZE) - basic 1D array ' ============================================ Print "TEST 46: STRUCT(SIZE) - basic 1D array" Dim boundArr1(9) As Point Dim bound1% = Struct(SIZE, boundArr1()) If bound1% = 9 Then Print " PASS: STRUCT(SIZE) returned "; bound1% Else Print " FAIL: Expected 9, got "; bound1% EndIf ' ============================================ ' TEST 47: STRUCT(SIZE) - with dimension parameter ' ============================================ Print "TEST 47: STRUCT(SIZE) - 2D array with dimension" Dim boundArr2(4, 7) As Point Dim dim1% = Struct(SIZE, boundArr2(), 1) Dim dim2% = Struct(SIZE, boundArr2(), 2) If dim1% = 4 And dim2% = 7 Then Print " PASS: Dimension 1 = "; dim1%; ", Dimension 2 = "; dim2% Else Print " FAIL: Expected (4,7), got ("; dim1%; ","; dim2%; ")" EndIf ' ============================================ ' TEST 48: STRUCT(SIZE) - default dimension ' ============================================ Print "TEST 48: STRUCT(SIZE) - default dimension (1)" Dim dim1b% = Struct(SIZE, boundArr2()) If dim1b% = 4 Then Print " PASS: Default dimension returned "; dim1b% Else Print " FAIL: Expected 4, got "; dim1b% EndIf ' ============================================ ' TEST 49: STRUCT COPY array() TO array() ' ============================================ Print "TEST 49: STRUCT COPY array() TO array()" Dim srcCopy(2) As Point srcCopy(0).x = 10 : srcCopy(0).y = 11 srcCopy(1).x = 20 : srcCopy(1).y = 21 srcCopy(2).x = 30 : srcCopy(2).y = 31 Dim dstCopy(4) As Point ' Larger destination Struct Copy srcCopy() To dstCopy() Dim copyOk% = 1 If dstCopy(0).x <> 10 Or dstCopy(0).y <> 11 Then copyOk% = 0 If dstCopy(1).x <> 20 Or dstCopy(1).y <> 21 Then copyOk% = 0 If dstCopy(2).x <> 30 Or dstCopy(2).y <> 31 Then copyOk% = 0 If copyOk% Then Print " PASS: Array copy successful" Else Print " FAIL: Array copy data mismatch" Print " [0] "; dstCopy(0).x; ","; dstCopy(0).y Print " [1] "; dstCopy(1).x; ","; dstCopy(1).y Print " [2] "; dstCopy(2).x; ","; dstCopy(2).y EndIf ' ============================================ ' TEST 50: STRUCT COPY array preserves extra elements ' ============================================ Print "TEST 50: STRUCT COPY array preserves extra dest elements" ' Set destination element 3 and 4 before copy Dim srcCopy2(1) As Point srcCopy2(0).x = 100 : srcCopy2(0).y = 101 srcCopy2(1).x = 200 : srcCopy2(1).y = 201 Dim dstCopy2(3) As Point dstCopy2(2).x = 999 : dstCopy2(2).y = 998 dstCopy2(3).x = 888 : dstCopy2(3).y = 887 Struct Copy srcCopy2() To dstCopy2() Dim copy2Ok% = 1 If dstCopy2(0).x <> 100 Or dstCopy2(0).y <> 101 Then copy2Ok% = 0 If dstCopy2(1).x <> 200 Or dstCopy2(1).y <> 201 Then copy2Ok% = 0 If dstCopy2(2).x <> 999 Or dstCopy2(2).y <> 998 Then copy2Ok% = 0 If dstCopy2(3).x <> 888 Or dstCopy2(3).y <> 887 Then copy2Ok% = 0 If copy2Ok% Then Print " PASS: Extra elements preserved" Else Print " FAIL: Extra elements overwritten" Print " [2] "; dstCopy2(2).x; ","; dstCopy2(2).y; " (expected 999,998)" Print " [3] "; dstCopy2(3).x; ","; dstCopy2(3).y; " (expected 888,887)" EndIf ' ============================================ ' Summary ' ============================================ Print "=== All Tests Complete ===" Print "Review output above for any FAIL messages" End ' ============================================ ' Function definitions (must be after END) ' ============================================ Function MakePoint(xval%, yval%) As Point MakePoint.x = xval% MakePoint.y = yval% End Function Function MakePerson(n$, a%, h!) As Person MakePerson.age = a% MakePerson.height = h! MakePerson.name = n$ End Function Function MakeWithArray(id%, v0%, v1%, v2%, v3%) As WithArray MakeWithArray.id = id% MakeWithArray.values(0) = v0% MakeWithArray.values(1) = v1% MakeWithArray.values(2) = v2% MakeWithArray.values(3) = v3% End Function Edited 2025-12-23 00:05 by matherp |
Very pretty Peter, but do existing variable, subroutine and function names containing periods continue to work ... or does this break everything I ever wrote .Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Everything works as before. I'm just finalising the version that has nested types. Currently the only test failing is: mydatasets(0).points(1).values(3) = 42.5 |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
Hi Peter, yes, that's a lovely surprise! Thank you so much for your work! Kind regards Michael |
| karlelch Guru Joined: 30/10/2014 Location: GermanyPosts: 361 |
Yes, please!!!!! However, I share Tom's concern. To structure my code, I often use the dot to group variables .... I am just starting to write the code for my latest robot project and I am not far yet. Maybe that's an opportunity to test your new addition/suggestion. Best wishes and merry xmas Thomas |
Looks like you are working on nested array fields too, nice. I guess I'll be duplicating this in MMB4L eventually then, instead of my original plan to implement untyped structs/objects like JavaScript .You seem to have discovered unit-testing too, is that Claude's influence ? Best wishes, Tom Edited 2025-12-23 00:50 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 418 |
Interesting Christmas gift! I hope the grandchildren will go to bed early during X-mas so I get some time to play with the new "toy". (In reality I will however be more tired than them in the evenings.) ...probably more efficient learning after New Year. Thank you Peter for this gift and all the other gifts received over the years! Fred / Pluto |
Wow... The weather must be really bad round there at the moment. :) This is very interesting. Something I've never used or even considered using. What I would do with it I've no idea at the moment. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
... used the experimental version and tested code where I used dots for structuring - it worked w/o any problem. @Peter: Are you planing to allow arrays as structure elements as well? |
Updated version and manual. Now fully supports nested types MMBasic_Structures_Manual_v2.pdf PicoMiteRP2350EXP.zip Updated test script. Tom: note tests 55 to 58 Karlech: check test 54 ' Comprehensive Structure Test for PicoMite ' Tests all implemented struct features Option Explicit Option Default None Print "=== Structure Tests ===" ' ============================================ ' TEST 1: Basic TYPE definition and simple struct ' ============================================ Print "TEST 1: Basic struct definition and access" Type Point x As INTEGER y As INTEGER End Type Dim p1 As Point p1.x = 100 p1.y = 200 If p1.x = 100 And p1.y = 200 Then Print " PASS: Simple struct assignment and read" Else Print " FAIL: Expected 100,200 got"; p1.x; ","; p1.y EndIf ' ============================================ ' TEST 2: Struct with different member types ' ============================================ Print "TEST 2: Struct with mixed types" Type Person age As INTEGER height As FLOAT name As STRING End Type Dim person1 As Person person1.age = 42 person1.height = 1.85 person1.name = "John" If person1.age = 42 And person1.height = 1.85 And person1.name = "John" Then Print " PASS: Mixed type struct" Else Print " FAIL: Mixed type struct failed" EndIf ' ============================================ ' TEST 3: Array of structures ' ============================================ Print "TEST 3: Array of structures" Dim points(5) As Point points(0).x = 10 : points(0).y = 11 points(1).x = 20 : points(1).y = 21 points(2).x = 30 : points(2).y = 31 points(3).x = 40 : points(3).y = 41 points(4).x = 50 : points(4).y = 51 points(5).x = 60 : points(5).y = 61 Dim ok% = 1 Dim i% For i% = 0 To 5 If points(i%).x <> (i% + 1) * 10 Or points(i%).y <> (i% + 1) * 10 + 1 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Array of structs" Else Print " FAIL: Array of structs" EndIf ' ============================================ ' TEST 4: Pass struct to SUB by reference ' ============================================ Print "TEST 4: Pass struct to SUB by reference" Sub DoublePoint(pt As Point) pt.x = pt.x * 2 pt.y = pt.y * 2 End Sub Dim p2 As Point p2.x = 5 p2.y = 7 DoublePoint p2 If p2.x = 10 And p2.y = 14 Then Print " PASS: Struct passed by reference modified caller" Else Print " FAIL: Expected 10,14 got"; p2.x; ","; p2.y EndIf ' ============================================ ' TEST 5: Pass array element to SUB ' ============================================ Print "TEST 5: Pass array element to SUB" Dim arr(3) As Point arr(1).x = 100 arr(1).y = 200 DoublePoint arr(1) If arr(1).x = 200 And arr(1).y = 400 Then Print " PASS: Array element passed by reference" Else Print " FAIL: Expected 200,400 got"; arr(1).x; ","; arr(1).y EndIf ' ============================================ ' TEST 6: Pass struct array to SUB ' ============================================ Print "TEST 6: Pass struct array to SUB" Sub SumPoints(pts() As Point, count%) Local sum_x% = 0, sum_y% = 0 Local j% For j% = 0 To count% - 1 sum_x% = sum_x% + pts(j%).x sum_y% = sum_y% + pts(j%).y Next j% Print " Sum X ="; sum_x%; ", Sum Y ="; sum_y% End Sub Dim testArr(2) As Point testArr(0).x = 1 : testArr(0).y = 2 testArr(1).x = 3 : testArr(1).y = 4 testArr(2).x = 5 : testArr(2).y = 6 Print " Calling SumPoints (expect Sum X=9, Sum Y=12):" SumPoints testArr(), 3 Print " PASS: Array of structs passed to SUB (verify output above)" ' ============================================ ' TEST 7: Modify struct array in SUB ' ============================================ Print "TEST 7: Modify struct array elements in SUB" Sub ZeroPoints(pts() As Point, count%) Local k% For k% = 0 To count% - 1 pts(k%).x = 0 pts(k%).y = 0 Next k% End Sub ZeroPoints testArr(), 3 ok% = 1 For i% = 0 To 2 If testArr(i%).x <> 0 Or testArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: SUB modified caller's struct array" Else Print " FAIL: Array not properly zeroed" EndIf ' ============================================ ' TEST 8: STRUCT COPY command ' ============================================ Print "TEST 8: STRUCT COPY command" Dim src As Point, dst As Point src.x = 999 src.y = 888 dst.x = 0 dst.y = 0 Struct Copy src To dst If dst.x = 999 And dst.y = 888 Then Print " PASS: STRUCT COPY works" Else Print " FAIL: Expected 999,888 got"; dst.x; ","; dst.y EndIf ' ============================================ ' TEST 9: STRUCT COPY with mixed types ' ============================================ Print "TEST 9: STRUCT COPY with mixed types" Dim src_person As Person, dst_person As Person src_person.age = 25 src_person.height = 1.75 src_person.name = "Alice" Struct Copy src_person To dst_person If dst_person.age = 25 And dst_person.height = 1.75 And dst_person.name = "Alice" Then Print " PASS: STRUCT COPY with mixed types" Else Print " FAIL: STRUCT COPY mixed types failed" EndIf ' ============================================ ' TEST 10: Function returning value from struct member ' ============================================ Print "TEST 10: Function using struct member" Function GetDistance(pt As Point) As FLOAT GetDistance = Sqr(pt.x * pt.x + pt.y * pt.y) End Function Dim p3 As Point p3.x = 3 p3.y = 4 Dim dist! = GetDistance(p3) If dist! = 5 Then Print " PASS: Function with struct parameter" Else Print " FAIL: Expected 5 got"; dist! EndIf ' ============================================ ' TEST 11: Nested struct access in expressions ' ============================================ Print "TEST 11: Struct members in expressions" Dim pA As Point, pB As Point pA.x = 10 : pA.y = 20 pB.x = 30 : pB.y = 40 Dim sum_expr% = pA.x + pB.x + pA.y + pB.y If sum_expr% = 100 Then Print " PASS: Struct members in expressions" Else Print " FAIL: Expected 100 got"; sum_expr% EndIf ' ============================================ ' TEST 12: Array index with variable ' ============================================ Print "TEST 12: Array of structs with variable index" Dim dynArr(9) As Point For i% = 0 To 9 dynArr(i%).x = i% * 2 dynArr(i%).y = i% * 3 Next i% ok% = 1 For i% = 0 To 9 If dynArr(i%).x <> i% * 2 Or dynArr(i%).y <> i% * 3 Then ok% = 0 EndIf Next i% If ok% Then Print " PASS: Variable index into struct array" Else Print " FAIL: Variable index failed" EndIf ' ============================================ ' TEST 13: Multiple struct types ' ============================================ Print "TEST 13: Multiple struct type definitions" Type Rectangle left As INTEGER top As INTEGER width As INTEGER height As INTEGER End Type Type Circle cx As INTEGER cy As INTEGER radius As FLOAT End Type Dim rect As Rectangle Dim circ As Circle rect.left = 10 : rect.top = 20 : rect.width = 100 : rect.height = 50 circ.cx = 50 : circ.cy = 50 : circ.radius = 25.5 If rect.left = 10 And rect.width = 100 And circ.radius = 25.5 Then Print " PASS: Multiple struct types" Else Print " FAIL: Multiple struct types" EndIf ' ============================================ ' TEST 14: Struct parameter not modified without assignment ' ============================================ Print "TEST 14: Read-only access in SUB" Sub ReadOnlyTest(pt As Point) Local val% = pt.x + pt.y Print " Read value:"; val% End Sub Dim p4 As Point p4.x = 111 p4.y = 222 ReadOnlyTest p4 If p4.x = 111 And p4.y = 222 Then Print " PASS: Struct unchanged after read-only access" Else Print " FAIL: Struct was unexpectedly modified" EndIf ' ============================================ ' TEST 15: Simple struct initialization ' ============================================ Print "TEST 15: Simple struct initialization" Dim initPoint As Point = (42, 99) If initPoint.x = 42 And initPoint.y = 99 Then Print " PASS: Simple struct initialization" Else Print " FAIL: Expected 42,99 got"; initPoint.x; ","; initPoint.y EndIf ' ============================================ ' TEST 16: Struct with string initialization ' ============================================ Print "TEST 16: Struct with string initialization" Dim initPerson As Person = (30, 1.80, "Bob") If initPerson.age = 30 And initPerson.height = 1.80 And initPerson.name = "Bob" Then Print " PASS: Struct with string initialization" Else Print " FAIL: Struct with string init failed" EndIf ' ============================================ ' TEST 17: Array of structs initialization ' ============================================ Print "TEST 17: Array of structs initialization" Dim initArr(1) As Point = (10, 20, 30, 40) If initArr(0).x = 10 And initArr(0).y = 20 And initArr(1).x = 30 And initArr(1).y = 40 Then Print " PASS: Array of structs initialization" Else Print " FAIL: Array init got"; initArr(0).x; ","; initArr(0).y; ","; initArr(1).x; ","; initArr(1).y EndIf ' ============================================ ' TEST 18: Mixed type struct array initialization ' ============================================ Print "TEST 18: Mixed type struct array initialization" Type TestStruct num As INTEGER txt As STRING End Type Dim mixArr(1) As TestStruct = (100, "first", 200, "second") If mixArr(0).num = 100 And mixArr(0).txt = "first" And mixArr(1).num = 200 And mixArr(1).txt = "second" Then Print " PASS: Mixed type struct array initialization" Else Print " FAIL: Mixed init failed" EndIf ' ============================================ ' TEST 19: LOCAL struct in subroutine ' ============================================ Print "TEST 19: LOCAL struct in subroutine" Sub TestLocalStruct Local localPt As Point localPt.x = 555 localPt.y = 666 Print " Local struct values:"; localPt.x; ","; localPt.y If localPt.x = 555 And localPt.y = 666 Then Print " PASS: LOCAL struct works" Else Print " FAIL: LOCAL struct failed" EndIf End Sub TestLocalStruct ' ============================================ ' TEST 20: LOCAL struct array in subroutine ' ============================================ Print "TEST 20: LOCAL struct array in subroutine" Sub TestLocalStructArray Local localArr(2) As Point localArr(0).x = 1 : localArr(0).y = 2 localArr(1).x = 3 : localArr(1).y = 4 localArr(2).x = 5 : localArr(2).y = 6 Local ok% = 1 If localArr(0).x <> 1 Or localArr(0).y <> 2 Then ok% = 0 If localArr(1).x <> 3 Or localArr(1).y <> 4 Then ok% = 0 If localArr(2).x <> 5 Or localArr(2).y <> 6 Then ok% = 0 If ok% Then Print " PASS: LOCAL struct array works" Else Print " FAIL: LOCAL struct array failed" EndIf End Sub TestLocalStructArray ' ============================================ ' TEST 21: LOCAL struct with initialization ' ============================================ Print "TEST 21: LOCAL struct with initialization" Sub TestLocalStructInit Local initPt As Point = (777, 888) If initPt.x = 777 And initPt.y = 888 Then Print " PASS: LOCAL struct initialization works" Else Print " FAIL: Expected 777,888 got"; initPt.x; ","; initPt.y EndIf End Sub TestLocalStructInit ' ============================================ ' TEST 22: Multiple LOCAL struct calls (memory test) ' ============================================ Print "TEST 22: Multiple LOCAL struct calls (memory test)" Sub MemTest Local tmp As Point tmp.x = 123 tmp.y = 456 End Sub ' Call multiple times to verify memory is properly freed MemTest MemTest MemTest MemTest MemTest Print " PASS: Multiple LOCAL struct calls completed (no memory error)" ' ============================================ ' TEST 23: STRUCT SORT by integer field ' ============================================ Print "TEST 23: STRUCT SORT by integer field" Dim sortArr(4) As Point sortArr(0).x = 50 : sortArr(0).y = 5 sortArr(1).x = 20 : sortArr(1).y = 2 sortArr(2).x = 40 : sortArr(2).y = 4 sortArr(3).x = 10 : sortArr(3).y = 1 sortArr(4).x = 30 : sortArr(4).y = 3 Struct Sort sortArr(), x If sortArr(0).x = 10 And sortArr(1).x = 20 And sortArr(2).x = 30 And sortArr(3).x = 40 And sortArr(4).x = 50 Then Print " PASS: STRUCT SORT by integer ascending" Else Print " FAIL: Sort order wrong" EndIf ' ============================================ ' TEST 24: STRUCT SORT reverse ' ============================================ Print "TEST 24: STRUCT SORT reverse" Struct Sort sortArr(), x, 1 If sortArr(0).x = 50 And sortArr(1).x = 40 And sortArr(2).x = 30 And sortArr(3).x = 20 And sortArr(4).x = 10 Then Print " PASS: STRUCT SORT reverse" Else Print " FAIL: Reverse sort order wrong" EndIf ' ============================================ ' TEST 25: STRUCT SORT by string field ' ============================================ Print "TEST 25: STRUCT SORT by string field" Type NamedItem id As INTEGER name As STRING End Type Dim items(4) As NamedItem items(0).id = 1 : items(0).name = "Cherry" items(1).id = 2 : items(1).name = "Apple" items(2).id = 3 : items(2).name = "Elderberry" items(3).id = 4 : items(3).name = "Banana" items(4).id = 5 : items(4).name = "Date" Struct Sort items(), name If items(0).name = "Apple" And items(1).name = "Banana" And items(2).name = "Cherry" And items(3).name = "Date" And items(4).name = "Elderberry" Then Print " PASS: STRUCT SORT by string" Else Print " FAIL: String sort wrong:"; items(0).name; ","; items(1).name; ","; items(2).name EndIf ' Verify ID followed the sort If items(0).id = 2 And items(1).id = 4 And items(2).id = 1 Then Print " PASS: Other fields preserved during sort" Else Print " FAIL: ID values not preserved" EndIf ' ============================================ ' TEST 26: STRUCT SORT case insensitive ' ============================================ Print "TEST 26: STRUCT SORT case insensitive" items(0).name = "cherry" items(1).name = "APPLE" items(2).name = "Elderberry" items(3).name = "banana" items(4).name = "DATE" Struct Sort items(), name, 2 If Left$(items(0).name, 1) = "A" Or Left$(items(0).name, 1) = "a" Then Print " PASS: STRUCT SORT case insensitive (Apple/APPLE first)" Else Print " FAIL: Case insensitive sort wrong, first="; items(0).name EndIf ' ============================================ ' TEST 27: STRUCT SORT by float field ' ============================================ Print "TEST 27: STRUCT SORT by float field" Type Measurement value As FLOAT label As STRING End Type Dim measurements(3) As Measurement measurements(0).value = 3.14 : measurements(0).label = "pi" measurements(1).value = 1.41 : measurements(1).label = "sqrt2" measurements(2).value = 2.71 : measurements(2).label = "e" measurements(3).value = 0.57 : measurements(3).label = "euler" Struct Sort measurements(), value If measurements(0).value < measurements(1).value And measurements(1).value < measurements(2).value And measurements(2).value < measurements(3).value Then Print " PASS: STRUCT SORT by float" Else Print " FAIL: Float sort wrong" EndIf ' ============================================ ' TEST 28: STRUCT SORT empty strings at end ' ============================================ Print "TEST 28: STRUCT SORT empty strings at end" items(0).name = "Zebra" items(1).name = "" items(2).name = "Apple" items(3).name = "" items(4).name = "Mango" Struct Sort items(), name, 4 If items(3).name = "" And items(4).name = "" And items(0).name <> "" Then Print " PASS: STRUCT SORT empty strings at end" Else Print " FAIL: Empty strings not at end" EndIf ' ============================================ ' TEST 29: Function returning struct ' ============================================ Print "TEST 29: Function returning struct" Dim p29 As Point p29 = MakePoint(123, 456) If p29.x = 123 And p29.y = 456 Then Print " PASS: Function returning struct" Else Print " FAIL: Expected 123,456 got"; p29.x; ","; p29.y EndIf ' ============================================ ' TEST 30: Function returning struct with Person (multiple types) ' ============================================ Print "TEST 30: Function returning struct with mixed types" Dim p30 As Person p30 = MakePerson("Bob", 35, 1.75) If p30.name = "Bob" And p30.age = 35 And Abs(p30.height - 1.75) < 0.01 Then Print " PASS: Function returning struct with mixed types" Else Print " FAIL: Expected Bob,35,1.75 got"; p30.name; ","; p30.age; ","; p30.height EndIf ' ============================================ ' TEST 31: Struct packing - string followed by int/float (non-8 aligned) ' ============================================ Print "TEST 31: Struct packing with short string before int/float" Type PackTest label As STRING LENGTH 5 value As INTEGER ratio As FLOAT End Type Dim pk As PackTest pk.label = "Test" pk.value = 12345 pk.ratio = 3.14 If pk.label = "Test" And pk.value = 12345 And Abs(pk.ratio - 3.14) < 0.01 Then Print " PASS: Struct packing with short string" Else Print " FAIL: Got label="; pk.label; " value="; pk.value; " ratio="; pk.ratio EndIf ' ============================================ ' TEST 32: Function returning struct with array member ' ============================================ Print "TEST 32: Function returning struct with array member" Type WithArray id As INTEGER values(3) As INTEGER End Type Dim wa As WithArray wa = MakeWithArray(99, 10, 20, 30, 40) If wa.id = 99 And wa.values(0) = 10 And wa.values(1) = 20 And wa.values(2) = 30 And wa.values(3) = 40 Then Print " PASS: Function returning struct with array member" Else Print " FAIL: Got id="; wa.id; " values="; wa.values(0); ","; wa.values(1); ","; wa.values(2); ","; wa.values(3) EndIf ' ============================================ ' TEST 33: STRUCT CLEAR - single struct ' ============================================ Print "TEST 33: STRUCT CLEAR - single struct" Dim clearTest As Person clearTest.age = 42 clearTest.height = 1.85 clearTest.name = "TestName" Struct Clear clearTest If clearTest.age = 0 And clearTest.height = 0 And clearTest.name = "" Then Print " PASS: STRUCT CLEAR single struct" Else Print " FAIL: Got age="; clearTest.age; " height="; clearTest.height; " name="; clearTest.name EndIf ' ============================================ ' TEST 34: STRUCT CLEAR - array of structs ' ============================================ Print "TEST 34: STRUCT CLEAR - array of structs" Dim clearArr(2) As Point clearArr(0).x = 1 : clearArr(0).y = 2 clearArr(1).x = 3 : clearArr(1).y = 4 clearArr(2).x = 5 : clearArr(2).y = 6 Struct Clear clearArr() ok% = 1 For i% = 0 To 2 If clearArr(i%).x <> 0 Or clearArr(i%).y <> 0 Then ok% = 0 Next i% If ok% Then Print " PASS: STRUCT CLEAR array of structs" Else Print " FAIL: Array not properly cleared" EndIf ' ============================================ ' TEST 35: STRUCT SWAP ' ============================================ Print "TEST 35: STRUCT SWAP" Dim swapA As Point, swapB As Point swapA.x = 100 : swapA.y = 200 swapB.x = 300 : swapB.y = 400 Struct Swap swapA, swapB If swapA.x = 300 And swapA.y = 400 And swapB.x = 100 And swapB.y = 200 Then Print " PASS: STRUCT SWAP" Else Print " FAIL: Got A="; swapA.x; ","; swapA.y; " B="; swapB.x; ","; swapB.y EndIf ' ============================================ ' TEST 36: STRUCT SWAP with array elements ' ============================================ Print "TEST 36: STRUCT SWAP with array elements" Dim swapArr(1) As Person swapArr(0).name = "Alice" : swapArr(0).age = 25 : swapArr(0).height = 1.60 swapArr(1).name = "Bob" : swapArr(1).age = 30 : swapArr(1).height = 1.80 Struct Swap swapArr(0), swapArr(1) If swapArr(0).name = "Bob" And swapArr(0).age = 30 And swapArr(1).name = "Alice" And swapArr(1).age = 25 Then Print " PASS: STRUCT SWAP array elements" Else Print " FAIL: Swap array elements failed" EndIf ' ============================================ ' TEST 37: STRUCT(FIND) - find by integer member ' ============================================ Print "TEST 37: STRUCT(FIND) - find by integer" Dim findArr(4) As Person findArr(0).name = "Alice" : findArr(0).age = 25 findArr(1).name = "Bob" : findArr(1).age = 30 findArr(2).name = "Charlie" : findArr(2).age = 35 findArr(3).name = "Diana" : findArr(3).age = 40 findArr(4).name = "Eve" : findArr(4).age = 45 Dim foundIdx% = Struct(FIND, findArr(), "age", 35) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by integer found at index 2" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 38: STRUCT(FIND) - find by string member ' ============================================ Print "TEST 38: STRUCT(FIND) - find by string" foundIdx% = Struct(FIND, findArr(), "name", "Diana") If foundIdx% = 3 Then Print " PASS: STRUCT(FIND) by string found at index 3" Else Print " FAIL: Expected index 3, got"; foundIdx% EndIf ' ============================================ ' TEST 39: STRUCT(FIND) - not found returns -1 ' ============================================ Print "TEST 39: STRUCT(FIND) - not found" foundIdx% = Struct(FIND, findArr(), "name", "Zara") If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) returns -1 when not found" Else Print " FAIL: Expected -1, got"; foundIdx% EndIf ' ============================================ ' TEST 40: STRUCT(FIND) - find by float member ' ============================================ Print "TEST 40: STRUCT(FIND) - find by float" findArr(2).height = 1.77 foundIdx% = Struct(FIND, findArr(), "height", 1.77) If foundIdx% = 2 Then Print " PASS: STRUCT(FIND) by float" Else Print " FAIL: Expected index 2, got"; foundIdx% EndIf ' ============================================ ' TEST 42: STRUCT(FIND) with start parameter - iterate through duplicates ' ============================================ Print "TEST 42: STRUCT(FIND) with start parameter" ' Add duplicate ages findArr(0).age = 30 ' Alice now 30 findArr(1).age = 30 ' Bob already 30 findArr(4).age = 30 ' Eve now 30 ' Find first person with age 30 foundIdx% = Struct(FIND, findArr(), "age", 30) If foundIdx% <> 0 Then Print " FAIL: First match should be index 0, got"; foundIdx% Else ' Find next person with age 30 starting after first match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 1 Then Print " FAIL: Second match should be index 1, got"; foundIdx% Else ' Find next person with age 30 starting after second match foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% <> 4 Then Print " FAIL: Third match should be index 4, got"; foundIdx% Else ' Try to find another - should return -1 foundIdx% = Struct(FIND, findArr(), "age", 30, foundIdx% + 1) If foundIdx% = -1 Then Print " PASS: STRUCT(FIND) with start parameter iterates correctly" Else Print " FAIL: Should return -1 after last match, got"; foundIdx% EndIf EndIf EndIf EndIf ' Restore original ages for remaining tests findArr(0).age = 25 : findArr(1).age = 30 : findArr(4).age = 45 ' ============================================ ' TEST 41: STRUCT SAVE and LOAD ' ============================================ Print "TEST 41: STRUCT SAVE and LOAD" ' Create test data Dim saveArr(2) As Person saveArr(0).name = "Alice" : saveArr(0).age = 25 : saveArr(0).height = 1.65 saveArr(1).name = "Bob" : saveArr(1).age = 30 : saveArr(1).height = 1.75 saveArr(2).name = "Charlie" : saveArr(2).age = 35 : saveArr(2).height = 1.85 ' Save to file Open "structtest.dat" For Output As #1 Struct Save #1, saveArr() Close #1 ' Clear the array Struct Clear saveArr() ' Verify cleared ok% = 1 For i% = 0 To 2 If saveArr(i%).name <> "" Or saveArr(i%).age <> 0 Then ok% = 0 Next i% If ok% = 0 Then Print " FAIL: Array not cleared before load test" Else ' Load back from file Open "structtest.dat" For Input As #1 Struct Load #1, saveArr() Close #1 ' Verify data - check each condition separately to avoid line continuation issues Dim loadOk% = 1 If saveArr(0).name <> "Alice" Or saveArr(0).age <> 25 Then loadOk% = 0 If Abs(saveArr(0).height - 1.65) >= 0.01 Then loadOk% = 0 If saveArr(1).name <> "Bob" Or saveArr(1).age <> 30 Then loadOk% = 0 If Abs(saveArr(1).height - 1.75) >= 0.01 Then loadOk% = 0 If saveArr(2).name <> "Charlie" Or saveArr(2).age <> 35 Then loadOk% = 0 If Abs(saveArr(2).height - 1.85) >= 0.01 Then loadOk% = 0 If loadOk% Then Print " PASS: STRUCT SAVE/LOAD" Else Print " FAIL: Data mismatch after load" Print " [0] "; saveArr(0).name; ","; saveArr(0).age; ","; saveArr(0).height Print " [1] "; saveArr(1).name; ","; saveArr(1).age; ","; saveArr(1).height Print " [2] "; saveArr(2).name; ","; saveArr(2).age; ","; saveArr(2).height EndIf EndIf ' Clean up test file Kill "structtest.dat" ' ============================================ ' TEST 43: STRUCT PRINT - single struct ' ============================================ Print "TEST 43: STRUCT PRINT - single struct" Print " Output should show Person structure with Alice, 25, 1.65:" Dim printTest As Person printTest.name = "Alice" printTest.age = 25 printTest.height = 1.65 Struct Print printTest Print " PASS: (verify output above manually)" ' ============================================ ' TEST 44: STRUCT PRINT - array element ' ============================================ Print "TEST 44: STRUCT PRINT - array element" Print " Output should show Point structure with x=100, y=200:" Dim printArr(2) As Point printArr(0).x = 100 : printArr(0).y = 200 printArr(1).x = 300 : printArr(1).y = 400 Struct Print printArr(0) Print " PASS: (verify output above manually)" ' ============================================ ' TEST 45: STRUCT PRINT - whole array ' ============================================ Print "TEST 45: STRUCT PRINT - whole array" Print " Output should show 2 Point elements:" Struct Print printArr() Print " PASS: (verify output above manually)" ' ============================================ ' TEST 46: STRUCT(SIZE) - basic 1D array ' ============================================ Print "TEST 46: STRUCT(SIZE) - basic 1D array" Dim boundArr1(9) As Point Dim bound1% = Struct(SIZE, boundArr1()) If bound1% = 9 Then Print " PASS: STRUCT(SIZE) returned "; bound1% Else Print " FAIL: Expected 9, got "; bound1% EndIf ' ============================================ ' TEST 47: STRUCT(SIZE) - with dimension parameter ' ============================================ Print "TEST 47: STRUCT(SIZE) - 2D array with dimension" Dim boundArr2(4, 7) As Point Dim dim1% = Struct(SIZE, boundArr2(), 1) Dim dim2% = Struct(SIZE, boundArr2(), 2) If dim1% = 4 And dim2% = 7 Then Print " PASS: Dimension 1 = "; dim1%; ", Dimension 2 = "; dim2% Else Print " FAIL: Expected (4,7), got ("; dim1%; ","; dim2%; ")" EndIf ' ============================================ ' TEST 48: STRUCT(SIZE) - default dimension ' ============================================ Print "TEST 48: STRUCT(SIZE) - default dimension (1)" Dim dim1b% = Struct(SIZE, boundArr2()) If dim1b% = 4 Then Print " PASS: Default dimension returned "; dim1b% Else Print " FAIL: Expected 4, got "; dim1b% EndIf ' ============================================ ' TEST 49: STRUCT COPY array() TO array() ' ============================================ Print "TEST 49: STRUCT COPY array() TO array()" Dim srcCopy(2) As Point srcCopy(0).x = 10 : srcCopy(0).y = 11 srcCopy(1).x = 20 : srcCopy(1).y = 21 srcCopy(2).x = 30 : srcCopy(2).y = 31 Dim dstCopy(4) As Point ' Larger destination Struct Copy srcCopy() To dstCopy() Dim copyOk% = 1 If dstCopy(0).x <> 10 Or dstCopy(0).y <> 11 Then copyOk% = 0 If dstCopy(1).x <> 20 Or dstCopy(1).y <> 21 Then copyOk% = 0 If dstCopy(2).x <> 30 Or dstCopy(2).y <> 31 Then copyOk% = 0 If copyOk% Then Print " PASS: Array copy successful" Else Print " FAIL: Array copy data mismatch" Print " [0] "; dstCopy(0).x; ","; dstCopy(0).y Print " [1] "; dstCopy(1).x; ","; dstCopy(1).y Print " [2] "; dstCopy(2).x; ","; dstCopy(2).y EndIf ' ============================================ ' TEST 50: STRUCT COPY array preserves extra elements ' ============================================ Print "TEST 50: STRUCT COPY array preserves extra dest elements" ' Set destination element 3 and 4 before copy Dim srcCopy2(1) As Point srcCopy2(0).x = 100 : srcCopy2(0).y = 101 srcCopy2(1).x = 200 : srcCopy2(1).y = 201 Dim dstCopy2(3) As Point dstCopy2(2).x = 999 : dstCopy2(2).y = 998 dstCopy2(3).x = 888 : dstCopy2(3).y = 887 Struct Copy srcCopy2() To dstCopy2() Dim copy2Ok% = 1 If dstCopy2(0).x <> 100 Or dstCopy2(0).y <> 101 Then copy2Ok% = 0 If dstCopy2(1).x <> 200 Or dstCopy2(1).y <> 201 Then copy2Ok% = 0 If dstCopy2(2).x <> 999 Or dstCopy2(2).y <> 998 Then copy2Ok% = 0 If dstCopy2(3).x <> 888 Or dstCopy2(3).y <> 887 Then copy2Ok% = 0 If copy2Ok% Then Print " PASS: Extra elements preserved" Else Print " FAIL: Extra elements overwritten" Print " [2] "; dstCopy2(2).x; ","; dstCopy2(2).y; " (expected 999,998)" Print " [3] "; dstCopy2(3).x; ","; dstCopy2(3).y; " (expected 888,887)" EndIf ' ============================================ ' TEST 51: Nested structure - basic access ' ============================================ Print "TEST 51: Nested structure - basic access" ' Define inner struct (Point already defined above) ' Define outer struct with nested Point Type Line startPt As Point endPt As Point thickness As INTEGER End Type Dim testLine As Line testLine.startPt.x = 10 testLine.startPt.y = 20 testLine.endPt.x = 100 testLine.endPt.y = 200 testLine.thickness = 3 Dim nestedOk% = 1 If testLine.startPt.x <> 10 Or testLine.startPt.y <> 20 Then nestedOk% = 0 If testLine.endPt.x <> 100 Or testLine.endPt.y <> 200 Then nestedOk% = 0 If testLine.thickness <> 3 Then nestedOk% = 0 If nestedOk% Then Print " PASS: Nested structure access works" Else Print " FAIL: Nested structure access failed" Print " startPt: "; testLine.startPt.x; ","; testLine.startPt.y Print " endPt: "; testLine.endPt.x; ","; testLine.endPt.y Print " thickness: "; testLine.thickness EndIf ' ============================================ ' TEST 52: Nested structure in array ' ============================================ Print "TEST 52: Nested structure in array of structs" Dim lines(2) As Line lines(0).startPt.x = 1 lines(0).startPt.y = 2 lines(0).endPt.x = 3 lines(0).endPt.y = 4 lines(1).startPt.x = 10 lines(1).startPt.y = 20 lines(1).endPt.x = 30 lines(1).endPt.y = 40 Dim arrNestedOk% = 1 If lines(0).startPt.x <> 1 Or lines(0).endPt.y <> 4 Then arrNestedOk% = 0 If lines(1).startPt.x <> 10 Or lines(1).endPt.y <> 40 Then arrNestedOk% = 0 If arrNestedOk% Then Print " PASS: Array of structs with nested access" Else Print " FAIL: Array nested access failed" EndIf ' ============================================ ' TEST 53: Array of nested structure members (Phase 2) ' ============================================ Print "TEST 53: Array of nested structure members" Type DataPoint values(4) As FLOAT End Type Type DataSet points(2) As DataPoint name As STRING End Type Dim mydata As DataSet mydata.name = "Test" mydata.points(0).values(0) = 1.1 mydata.points(0).values(2) = 1.3 mydata.points(1).values(1) = 2.2 mydata.points(2).values(4) = 3.5 Dim phase2Ok% = 1 If mydata.points(0).values(0) <> 1.1 Then phase2Ok% = 0 If mydata.points(0).values(2) <> 1.3 Then phase2Ok% = 0 If mydata.points(1).values(1) <> 2.2 Then phase2Ok% = 0 If mydata.points(2).values(4) <> 3.5 Then phase2Ok% = 0 If phase2Ok% Then Print " PASS: Array of nested structure members" Else Print " FAIL: Array of nested structure members failed" EndIf ' ============================================ ' TEST 54: Arrays of structs with array of nested members ' ============================================ Print "TEST 54: Full nesting: arr(i).member(j).member(k)" Dim mydatasets(1) As DataSet mydatasets(0).name = "Set0" mydatasets(0).points(1).values(3) = 42.5 mydatasets(1).name = "Set1" mydatasets(1).points(2).values(0) = 99.9 Dim fullNestOk% = 1 If mydatasets(0).points(1).values(3) <> 42.5 Then fullNestOk% = 0 If mydatasets(1).points(2).values(0) <> 99.9 Then fullNestOk% = 0 If mydatasets(0).name <> "Set0" Then fullNestOk% = 0 If mydatasets(1).name <> "Set1" Then fullNestOk% = 0 If fullNestOk% Then Print " PASS: Full nesting array(i).array(j).array(k)" Else Print " FAIL: Full nesting failed" EndIf ' ============================================ ' TEST 55: Variables with dots in names (legacy MMBasic feature) ' ============================================ Print "TEST 55: Variables with dots in names (non-struct)" Dim My.Variable% = 42 Dim Another.Dotted.Name! = 3.14159 Dim String.With.Dots$ = "Hello" Dim dotVarOk% = 1 If My.Variable% <> 42 Then dotVarOk% = 0 If Another.Dotted.Name! <> 3.14159 Then dotVarOk% = 0 If String.With.Dots$ <> "Hello" Then dotVarOk% = 0 ' Modify and check My.Variable% = 100 Another.Dotted.Name! = 2.718 String.With.Dots$ = "World" If My.Variable% <> 100 Then dotVarOk% = 0 If Another.Dotted.Name! <> 2.718 Then dotVarOk% = 0 If String.With.Dots$ <> "World" Then dotVarOk% = 0 If dotVarOk% Then Print " PASS: Dotted variable names work correctly" Else Print " FAIL: Dotted variable names broken" EndIf ' ============================================ ' TEST 56: Subroutines with dots in names ' ============================================ Print "TEST 56: Subroutines with dots in names" Dim subTestResult% = 0 My.Test.Sub 10, 20 If subTestResult% = 30 Then Print " PASS: Dotted subroutine names work" Else Print " FAIL: Dotted subroutine call failed" EndIf ' ============================================ ' TEST 57: Functions with dots in names ' ============================================ Print "TEST 57: Functions with dots in names" Dim funResult% = My.Test.Function%(5, 7) If funResult% = 35 Then Print " PASS: Dotted function names work" Else Print " FAIL: Dotted function call failed, got"; funResult% EndIf ' ============================================ ' TEST 58: Mix of dotted variables and struct members ' ============================================ Print "TEST 58: Dotted variables alongside struct members" Dim coord.offset% = 50 Dim pt As Point pt.x = 10 pt.y = 20 Dim mixOk% = 1 ' Use dotted variable and struct in same expression Dim result% = pt.x + coord.offset% If result% <> 60 Then mixOk% = 0 ' Assign from one to other pt.x = coord.offset% If pt.x <> 50 Then mixOk% = 0 coord.offset% = pt.y If coord.offset% <> 20 Then mixOk% = 0 If mixOk% Then Print " PASS: Mixed dotted vars and struct members" Else Print " FAIL: Mixed usage broken" EndIf ' ============================================ ' TEST 59: Arrays with dots in names ' ============================================ Print "TEST 59: Arrays with dots in names" Dim Data.Array%(5) Data.Array%(0) = 100 Data.Array%(3) = 300 Data.Array%(5) = 500 Dim arrDotOk% = 1 If Data.Array%(0) <> 100 Then arrDotOk% = 0 If Data.Array%(3) <> 300 Then arrDotOk% = 0 If Data.Array%(5) <> 500 Then arrDotOk% = 0 If arrDotOk% Then Print " PASS: Dotted array names work" Else Print " FAIL: Dotted array names broken" EndIf ' ============================================ ' Summary ' ============================================ Print "=== All Tests Complete ===" Print "Review output above for any FAIL messages" End ' ============================================ ' Function definitions (must be after END) ' ============================================ Function MakePoint(xval%, yval%) As Point MakePoint.x = xval% MakePoint.y = yval% End Function Function MakePerson(n$, a%, h!) As Person MakePerson.age = a% MakePerson.height = h! MakePerson.name = n$ End Function Function MakeWithArray(id%, v0%, v1%, v2%, v3%) As WithArray MakeWithArray.id = id% MakeWithArray.values(0) = v0% MakeWithArray.values(1) = v1% MakeWithArray.values(2) = v2% MakeWithArray.values(3) = v3% End Function ' Subroutine with dots in name (Test 56) Sub My.Test.Sub(a%, b%) subTestResult% = a% + b% End Sub ' Function with dots in name (Test 57) Function My.Test.Function%(x%, y%) My.Test.Function% = x% * y% End Function Edited 2025-12-23 01:12 by matherp |
All I can say is "Wow", you've outdone yourself. I look forward to trying to the grok the implementation at some point in the (distant) future. Merry Christmas & Happy New Year, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 763 |
Peter, no way - is this real? Just wow! I think this is a HUGE improvement since it simplifies a lot of things for me (I am doing a lot of work-arounds for achiving this)! Greetings Daniel Edited 2025-12-23 01:19 by Amnesie |
Found a bug: I tried to define a type as a structure element (ok, that was maybe a bit too courageous) and the Picomite went into a error loop Error : Unknown type in TYPE definition [68] velA As TVelocity Error : Unknown type in TYPE definition [68] velA As TVelocity Error : Unknown type in TYPE definition [68] velA As TVelocity ... Neither rebooting, resetting, hard reboot or reinstalling th firmware helps. Now I will nuke ... Best Thomas Edited 2025-12-23 01:25 by karlelch |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12057 |
list the complete file so I can test and fix. This is tested. Are you defining the types in the correct order. nested types must be defined before the type that includes them Edited 2025-12-23 01:26 by matherp |
... wow, nuke did not help ... but installing the latest release firmware stopped the loop. |
I lost the last version of the source file because only uploading the firmware helped . I'll load your newest version and see if I can still reproduce the error. |
| NPHighview Senior Member Joined: 02/09/2020 Location: United StatesPosts: 222 |
Peter - this is phenomenal. My personal development style is to define all the data elements before starting to code, and this has depended heavily on structs during my career doing C development. A couple of functional and OOP features you may want to consider: * Map/Reduce - you provide the function that gets applied to a list or array. * Function (pointers) as struct elements - very useful for callback operations . Live in the Future. It's Just Starting Now! |
@Peter: With the second version, this error is gone. These are the structures I tested. Type TMotor vel As Float velStep As Float newVel As Float End Type Type TRobot motor(1) As TMotor nSteps As Integer End Type Thanks! This is cool! Best Thomas Edited 2025-12-23 01:54 by karlelch |
I know the issue. You can't have errors in the pre-processor as each time it calls it it hits the same error and loops. I'm afraid that the fix will be the same as other pre-processor errors which is to delete the program |
You don't actually need that explicitly, or you've already got it depending on your point of view. The pre-existing CALL command and CALL() function already allow you to call a SUB/FUNCTION given its name as a string. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Page 1 of 4 |
