Local Time 01:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : V6.01.00D  final release candidate
EDNEDN
Posted: 01:14am 11 Dec 2025
MMDebug based on PicoMite v6.01.00RC25.
The code is clean and solid.   Every issue brought up in the release thread has been resolved.  It uses 12 KB of flash and if never activated it actually has more SRAM available to the user than the PicoMite_v6.01.00 firmware.
@matherp   Would it make sense to post the source to the build tree?   You could do a quick diff and see it hardly touches the main MMBasic source code at all.   And any place it does touch the main source code, it is very obvious why it needs to make a small change and that the change does not affect the normal operation of MMBasic.
Perhaps v6.01.00D could be used as the starting code base for v6.02.00 ?
PicoMite_v6.01.00RC25D---Documentation.zip
PicoMite_v6.01.00RC25D---Firmware.zip
Edited 2025-12-11 11:25 by EDNEDN
