Local Time 01:25 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Simple
     Page 1 of 3
marcos_lm
Posted: 12:46pm 01 Dec 2025
Hi all,
My name is Marcos, I write from Spain. Sorry for my English, I don't practice it very often.
I am very new to MMBasic and to the PicoMite HDMI/USB. To learn, I made a small "Bad Apple" demo that plays video with audio from the SD card.
Almost everything is written in plain MMBasic (only a small CSUB), so the code is not very optimal, but it works good enough for me now. I am just a hobbyist.
If someone wants to test it or look at the code, the project is here:
https://github.com/marcoslm/BadApple-PicoMite
And here is a short video of the demo running:
https://www.youtube.com/watch?v=hlqbMI7XZ-w
I’m sure the code is far from perfect, so any suggestions to improve performance, structure or style are very welcome.
Thanks a lot for MMBasic and the PicoMite, it is a very fun system.
Posted: 01:06pm 01 Dec 2025
Wow!  That is so impressive on so many levels both artistic and technical.
Posted: 01:14pm 01 Dec 2025
Truly excellent
Can you explain the format of the converted video file ba.vid. I'd love to find a way to make it work at full speed purely in Basic
marcos_lm
Posted: 01:19pm 01 Dec 2025
  Geoffg said  Wow!  That is so impressive on so many levels both artistic and technical.
Thanks a lot, Geoff.
I really appreciate your comment.
marcos_lm
Posted: 01:37pm 01 Dec 2025
  matherp said  Truly excellent
Thanks! Sure, I can explain the format.
The video file is basically a stream of pixels (just black and white) compressed with RLE. There is no header in the file. The width, height, number of frames and framerate are all fixed in the player code.
To make it smaller and avoid extra reads, every line always starts with 'black'. After each run, the decoder automatically toggles the colour (black/white). When the encoder needs to change the colour without drawing or moving X, it writes a run-length of zero.
Right now my Basic version uses a normal string as buffer, so I’m limited to reading 256-byte chunks. I saw in the manual that longstrings exist, so maybe they could help load a whole frame at once, but I still need to test that.
The CSUB and the pure Basic decoder both run at a “minimum guaranteed fps”. If I disable the fps limiter, the frame time varies a lot (peaks and drops), so sync with audio becomes messy.
ba.vid is 320x240 at 22fps.
balq.vid is 160x120 at 6fps (Basic alone can’t go much faster on my code).
If you want, I can try generating a 30fps file just for testing (it would be amazing if it ran at full speed only in Basic).
Edited 2025-12-01 23:46 by marcos_lm
Footnote added 2025-12-01 23:51 by marcos_lm
If you want to test it, in my code I have these variables acting as flags to enable/disable the FPS limiter and other options:
CONST SHOW_FPS     = 0   ' Show current FPS
CONST SHOW_FPS_MIN = 0   ' Show the lowest FPS
CONST LIMIT_FPS    = 1   ' Enable FPS limit to the target value
Posted: 01:46pm 01 Dec 2025
Hi Marcos,
I have to check audio-video sync, but the LQ also runs on a 252MHz RP2040 VGA in mode 2 VGA. I simply commented out the CPUSPEED check. This is on V6.01.00rc21.
The 22fps version does not run on a 2040 (probably needs re-compile of the CSUB).
Edited 2025-12-01 23:50 by Volhout
Posted: 02:09pm 01 Dec 2025
Marcos, which version of the firmware are you using? The csub doesn't work for me on 6.01.00RC20
marcos_lm
Posted: 02:13pm 01 Dec 2025
matherp, V6.00.03
Martin H.
Posted: 03:24pm 01 Dec 2025
Hi Marcos,
Wow, that's really excellent.
I also had the idea of animating the BA video, but with the approach of drawing the images using the fast "polygon" command, which would compress the images even more, of course.
Unfortunately, I failed at vectorizing the frames (my contour tracing never worked properly., or rather, I didn't pursue it any further.
'no comment
marcos_lm
Posted: 03:48pm 01 Dec 2025
  Martin H. said  Unfortunately, I failed at vectorizing the frames (my contour tracing never worked properly., or rather, I didn't pursue it any further.
Thanks Martin!
Funny thing: my first idea was also to try polygons, especially after seeing the 'polygon' command in the manual. Something like the old “State of the Art” demo on the Amiga. But some frames have so many separate “objects” at the same time that vectorizing all that looked too complex for me (and I wanted quick results), so in the end I trusted the PicoMite to draw lines fast enough and went for the method I used.
I also thought about using predefined tiles and encoding each frame with tile indexes. That would probably be very fast too, but the image quality would be much lower.
Thanks again!
Posted: 03:56pm 01 Dec 2025
Marco, I'm up to about 8FPS average Basic only 320x240. I haven't tried to sync the audio yet. Having the audio and video files on different devices as in my source makes a small difference but the big change is buffering all the writes. Apologies for mangling your elegant code.
' Bad Apple Demo para PicoMite HDMI/USB
' Autor: Marcos LM (2025)
'   - Version HQ: decodificador CSUB en C (320x240 @ 22 FPS)
'   - Version LQ: decodificador MMBasic   (160x120 @ 6 FPS)
' Requisitos:
'   - Firmware PicoMite HDMI/USB >= 6.00.03
'   - Archivos: ba.vid, balq.vid, ba.aud, ba.jpg en la SD
' Controles:
'   - Cursores arriba/abajo: seleccionar opcion
'   - ENTER                : aceptar
'   - ESC                  : parar reproduccion / salir
Option EXPLICIT
Option console serial
' Configuracion de video
Dim INTEGER vidWidth, vidHeight, vDelay,l
Dim FLOAT fps, totalFrames
Dim STRING vidFile, audFile
' Configuracion extra
Const HQ_DECODE = 0, LQ_DECODE = 1
Const T_ESC=27, T_ENTER=13, T_UP=128, T_DOWN=129
Const F_HANDLER    = 1   ' canal para la apertura del archivo
Const C_WHITE      = RGB(255,255,255)
Const C_GRAY       = RGB(128,128,128)
Const C_BLACK      = RGB(0,0,0)
Const SHOW_FPS     = 0   ' Muestra FPS actuales
Const SHOW_FPS_MIN = 0   ' Muestra el FPS mas bajo
Const LIMIT_FPS    = 1   ' Activa el limite a FPS objetivo
' Variables generales
Dim FLOAT frameIndex
Dim INTEGER x, y
Dim INTEGER runLen
Dim INTEGER colorIsWhite
Dim STRING chunk        ' buffer de datos comprimidos
Const CHUNK_SIZE = 255  ' 255 como maximo (limitacion de bytes para string)
Dim INTEGER bytesInChunk
Dim INTEGER chunkPos
Dim FLOAT targetTime
Dim FLOAT frameDuration
Dim FLOAT fpsCurrent
Dim FLOAT frameStartTime
Dim FLOAT fpsMin = 1000
Dim INTEGER selection   ' Menu
Dim integer x1(799),x2(799),y1(799),ch(1023)
' Comprobacisn inicial
' Comprobar velocidad de CPU (debe ser 315000 KHz para sincronizar A/V)
Dim FLOAT cpuhz
cpuhz = Val(MM.Info(CPUSPEED$))
If cpuhz <> 315000000 Then
Print "Bad Apple demo expects CPUSPEED = 315000 (315 MHz)"
B  Print "Current: "; MM.Info(CPUSPEED$); " Hz"
Print
Print "Adjust with: OPTION RESOLUTION 640x480,315000"
End
' Menu de Seleccion
' E inicializacion
selection = MenuSel()
' Ajustamos configuracion
    ' Demo con decoder BASIC
    vidWidth    = 320
    vidHeight   = 240
    fps         = 8
    vidFile     = "a:/ba.vid"
    audFile     = "b:/ba.aud"
    totalFrames = 4754
    targetTime  = 1000000/fps   ' ms por frame objetivo
    vDelay      = 0
' Salir
' Configuracion de pantalla y framebuffers
MODE 2 : Font 8
Color C_WHITE, C_BLACK
CLS
' Creamos un framebuffer donde dibujaremos y despues copiaremos al visible
' para evitar parpadeo (double buffering)
FRAMEBUFFER CREATE
FRAMEBUFFER WRITE N : CLS
FRAMEBUFFER WRITE F : CLS
' Abrir archivo de video
Open vidFile For INPUT As F_HANDLER
loadchunk 'prime the chunk buffer
' Lanzar audio
Play WAV audFile
Pause vDelay  ' ajuste de tiempo para cuadrar audio con video
SYNC targettime
' Bucle de reproduccion
Timer        = 0
fpsCurrent   = 0
frameIndex   = 0
' Dibujamos en F
FRAMEBUFFER WRITE F
Do While frameIndex < totalFrames
 CLS
Math set 0,x1()
Math set 0,x2()
Math set 0,y1()
l=0
 ' Carga de 'chunk' y decodificar frame completo
 For y = 0 To vidHeight - 1
    ' Inicializar linea para nuevo frame
    x = 0
    colorIsWhite = 0  ' RLE personalizado: cada linea empieza en negro
    Do While x < vidWidth
      runLen = Byte(chunk, chunkPos)
  ' Si es tramo blanco y longitud > 0, dibujar la linea
      If colorIsWhite And runLen > 0 Then
        x1(l)=x
        x2(l)=x+runLen-1
        y1(l)=y
        Inc l
      Inc x,runlen
      colorIsWhite = 1 - colorIsWhite  ' alternar negro/blanco
      Inc chunkPos
      If chunkPos > bytesInChunk Then loadchunk
 Next
 Line x1(),y1(),x2(),y1()
 Print Timer
 SYNC
 Timer =0
 FRAMEBUFFER COPY F, N
 Inc frameIndex = frameIndex
 If Asc(Inkey$) = T_ESC Then Play STOP : Exit Do
Close F_HANDLER
Do While MM.Info(SOUND)="WAV"
 Pause 20
Play STOP
FRAMEBUFFER CLOSE
' SUBs y Funciones
' Menu de seleccion
Function MenuSel() As INTEGER
Const NOPC = 2
Local STRING opciones(NOPC-1) = (" Bad Apple Demo    ", " Exit              ")
Local STRING ayudas(NOPC-1) = ("Lanzar version optimizada in Basic","Salir de la demo                 ")
Local INTEGER estado=0, tecla, i
Local INTEGER x=20, y=110
MODE 4 : CLS
Load JPG "ba.jpg"
  ' Pintar opciones
  Font 7
  For i = 0 To NOPC-1
    If i = estado Then
    Else
      Color C_BLACK, C_WHITE
    Text x, y + i * 10, opciones(i)
  Next i
  ' Texto de ayuda
  Font 8
  Color C_GRAY, C_WHITE
  Text 20, 230, ayudas(estado)
  ' Esperar tecla
    tecla = Asc(Inkey$)
  Loop While tecla = 0
  If tecla = T_ENTER Then Exit Do
  Play TONE 500, 550, 20
  Select Case tecla
    Case T_ESC
      estado = -1
      Exit Do
    Case T_UP
      If estado > 0 Then estado = estado-1
    Case T_DOWN
      If estado < NOPC-1 Then estado = estado+1
  End Select
Play TONE 1000,1000,20  ' Beep de confirmacion
Do While MM.Info(SOUND)="TONE"
  Pause 5
MenuSel=estado
End Function
' Lee un nuevo bloque del video comprimido (RLE)
Sub LoadChunk
chunk        = Input$(CHUNK_SIZE, F_HANDLER)
bytesInChunk = Len(chunk)
chunkPos     = 1
If bytesInChunk = 0 Then
  FRAMEBUFFER CLOSE : Play STOP : Close F_HANDLER
  Print "EOF inesperado en frame"; frameIndex
  End ' Abortamos
Edited 2025-12-02 02:27 by matherp
Posted: 04:22pm 01 Dec 2025
Anything but "Simple". Terrific job--congratulations.
twofingers
Posted: 05:18pm 01 Dec 2025
Simply fantastic! Congratulations!
Posted: 05:40pm 01 Dec 2025
But you can't run  "Bad Apple" on a microcontroller...  ;)
This is brilliant! :)
Plasmamac
Posted: 10:16pm 01 Dec 2025
Cool.
Thx for the code
Plasma
Posted: 10:20pm 01 Dec 2025
Marcos
This is my best effort using every trick I can think of. The printout on the console shows the average frame write time. 320x240 basic gives 11FPS average
' Requisitos:
' Controles:
'   - ENTER                : aceptar
Option EXPLICIT
Dim INTEGER vidWidth, vidHeight, vDelay,l,total
Dim INTEGER x, y
Dim INTEGER runLen
Const CHUNK_SIZE = 192  ' 255 como maximo (limitacion de bytes para string)
Dim integer x1(1999),x2(1999),y1(1999)
'get the address of the dimension size of y1
Dim integer y1add=Peek(varheader y1())+36
Dim FLOAT cpuhz
Print
End
' Menu de Seleccion
' E inicializacion
    vidWidth    = 319
    vidHeight   = 239
    fps         = 10
    totalFrames = 4754
    vDelay      = 0
' Salir
MODE 2 : Font 8
CLS
FRAMEBUFFER CREATE
' Lanzar audio
Play WAV audFile
SYNC targettime
Timer        = 0
fpsCurrent   = 0
frameIndex   = 0
' Dibujamos en F
FRAMEBUFFER WRITE F
 CLS
Math set 0,x1()
Math set 0,x2()
Math set 0,y1()
l=0
    x = 0
    loadchunk
    Do While x <= vidWidth
      runlen =Byte(chunk,chunkpos)
      Inc x,runlen
      Inc chunkPos
      If x>vidWidth Then Exit
      If runLen > 0 Then
        x1(l)=x
        x2(l)=x+runLen-1
        y1(l)=y
        Inc l
      Inc x,runlen
      Inc chunkPos
      Inc x,runlen
      Inc chunkPos
      If runLen > 0 Then
        x1(l)=x
        x2(l)=x+runLen-1
        y1(l)=y
        Inc l
      Inc x,runlen
      Inc chunkPos
 Next
'set the array size to the number of lines
 Poke word y1add,l-1
 If l Then Line x1(),y1(),x2(),y1()
 Poke word y1add,1999
 Inc total,Timer
 SYNC
 Timer =0
 Print total\frameindex
Close F_HANDLER
 Pause 20
Play STOP
FRAMEBUFFER CLOSE
' SUBs y Funciones
' Menu de seleccion
Const NOPC = 2
MODE 4 : CLS
Load JPG "ba.jpg"
  ' Pintar opciones
  Font 7
  For i = 0 To NOPC-1
    If i = estado Then
    Else
  Next i
  ' Texto de ayuda
  Font 8
  ' Esperar tecla
    tecla = Asc(Inkey$)
  Select Case tecla
    Case T_ESC
      estado = -1
      Exit Do
    Case T_UP
    Case T_DOWN
  End Select
  Pause 5
MenuSel=estado
End Function
Sub LoadChunk
 chunk=Right$(chunk,Len(chunk)-chunkpos+1)
 bytesinchunk=Len(chunk)
 chunkPos     = 1
 If bytesinchunk<64 Then
   Inc chunk,Input$(CHUNK_SIZE,F_HANDLER)
   End ' Abortamos
LeoNicolas
Posted: 10:37am 02 Dec 2025
Marcos, great job!
Super cool project
Peter, maybe we can have another contest similar to the octahedron to improve performance
I'm traveling to visit family. My projects are on hold until January
Posted: 11:10am 02 Dec 2025
  Quote  Peter, maybe we can have another contest similar to the octahedron to improve performance
The average frame time over the whole sequence is now 50.9mSec giving an average of 19.6FPS
Major changes are:
Buffering a frames worth of video data at the beginning of each frame into a longstring
Writing all lines with a single LINE command using arrays of coordinates
Use of "peek(bp" to get the data which auto increments the pointer saving an instruction
making use of the knowledge that all lines start with black to remove black/white toggle
inline process 8 black/white transitions outside the loop which caters for many lines
' Requisitos:
' Controles:
'   - ENTER                : aceptar
Option EXPLICIT
Dim FLOAT fps, totalFrames,total
Drive "b:"
Dim INTEGER x, y
Dim INTEGER runLen
Dim integer x1(1299),x2(1299),y1(1299),f(500)
Dim integer cadd=Peek(varaddr f())+8 'point to the data in the longstring
Dim integer csadd=cadd
Dim FLOAT cpuhz
Print
End
If totalframes Then Print total/totalframes
' Menu de Seleccion
' E inicializacion
   vidWidth    = 319
   vidHeight   = 239
   fps         = 15
   vidFile     = "ba.vid"
   audFile     = "a:/ba.aud"
   totalFrames = 4754
   vDelay      = 0
' Salir
MODE 2 : Font 8
CLS
FRAMEBUFFER CREATE
' Lanzar audio
Play WAV audFile
SYNC targettime
Timer        = 0
fpsCurrent   = 0
frameIndex   = 0
' Dibujamos en F
FRAMEBUFFER WRITE F
 CLS
 l=0
 loadchunk
   x = 0
   Inc x,Peek(bp cadd)
   If x>vidWidth Then Continue For
   runlen=Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
   Inc x,Peek(bp cadd)
   If runLen > 0 Then
     x1(l)=x
     x2(l)=x+runLen-1
     y1(l)=y
     Inc l
     Inc x,runlen
     Inc x,Peek(bp cadd)
     If runLen > 0 Then
       x1(l)=x
       x2(l)=x+runLen-1
       y1(l)=y
       Inc l
       Inc x,runlen
     Inc x,Peek(bp cadd)
     If runLen > 0 Then
       x1(l)=x
       x2(l)=x+runLen-1
       y1(l)=y
       Inc l
       Inc x,runlen
 Next
 Poke word y1add,l-1
 Poke word y1add,1299
 Inc total, Timer
 SYNC
 Timer =0
 Inc frameIndex
Close F_HANDLER
 Pause 20
Play STOP
FRAMEBUFFER CLOSE
' SUBs y Funciones
' Menu de seleccion
Const NOPC = 2
MODE 4 : CLS
Load JPG "ba.jpg"
 ' Pintar opciones
 Font 7
 For i = 0 To NOPC-1
   If i = estado Then
   Else
 Next i
 ' Texto de ayuda
 Font 8
 ' Esperar tecla
   tecla = Asc(Inkey$)
 Select Case tecla
   Case T_ESC
     estado = -1
     Exit Do
   Case T_UP
   Case T_DOWN
 End Select
 Pause 5
MenuSel=estado
End Function
Sub LoadChunk
 Local s$
 LongString right f(),f(),LLen(f())-(cadd-csadd)
 cadd=csadd
 Do While LLen(f())<3000
   s$=Input$(250,1)
   If Len(s$)=0 Then Exit
   LongString append f(),s$
 bytesinchunk=LLen(f())
   End ' Abortamos
Edited 2025-12-03 01:28 by matherp
Posted: 05:10pm 04 Dec 2025
Really crazy version!
LeoNicolas
Posted: 05:57pm 04 Dec 2025
Bad apple running on a homebrew computer
https://www.youtube.com/watch?v=Y1_MUXKX-oY
The porting details:
https://www.youtube.com/watch?v=2g1h5coj6iA
Edited 2025-12-05 03:58 by LeoNicolas
     Page 1 of 3
