Local Time 01:38 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic subroutine performance tips
Posted: 09:58am 23 Nov 2025
To optimise performance do not use the same name for local variables in nested subroutines.
Variables are created in a hash table. So by definition if you use i as an index in a subroutine called by a subroutine that also uses i. There will have been a hash table collision that the firmware resolves by looking for the next free slot. This is completely benign but does take extra time: not a lot but some.
Also, it is very slightly quicker if variables are typed at declaration rather than being typed with a suffix
Demo 1
fred
Sub fred
 Local i%=22,ii%=23
 bert
 Print i%,ii%
Sub bert
 Local i%,j%,ii%,jj%
 Timer =0
 For i%=1 To 100000
 ii%=i%
 Next
 Print Timer
 Timer =0
 For j%=1 To 100000
 jj%=j%
 Next
Print Timer
Demo2
Option explicit
Option default integer
fred
Sub fred
 Local i=22,ii=23
 bert
 Print i,ii
Sub bert
 Local i,j,ii,jj
 Timer =0
 For i=1 To 100000
 ii=i
 Next
 Print Timer
 Timer =0
 For j=1 To 100000
 jj=j
 Next
Print Timer
LeoNicolas
Posted: 10:37am 23 Nov 2025
Thank you for the tip
That makes sense. Hash tables have an O(1) time access for the best scenario, and O(N) for the worst case, when keys collide. It is still possible to have a key collision even with keys with different names, if both strings have the same hash, but the chance to happen is very low.
Is it possible to store the local variable in the hash table using a composite key consisting of the method name + variable name? This should solve the issue.
Bleep
Posted: 10:26am 24 Nov 2025
Hi Peter,
While I agree with what you have said, there are exceptions/problems.
I was optimising
Sub mm.user_bitmap(x%,y%,w%,h%,s%,Fc%,Bc%,bitmap%)
to
Sub mm.user_bitmap(x As Integer,y As Integer,w As Integer,h As Integer, s As Integer,Fc As Integer,Bc As Integer,bitmap As Integer)
and removing all the % in the subroutine, but it actually got slower, presumably because the parser had to parse all those 'As Integer' statements, I got round it by using 'Option Default Integer' but this can't work if there are a mixture of types. Assuming it is the length of the declaration, which slows it down, is a short form possible, relativly easy for you? maybe:-
xyz As %, pqr As %, abc As !, ghi As $
Or even
xyz %, pqy %, abc !, ghi $    'note space
This is of course assuming it is the length of the decleration that is causing the slow down, it may not be.?
Regards Kevin.
PhenixRising
Posted: 10:48am 24 Nov 2025
MM.REPLACE: I haven't seen any mention of it. Could this be used to replace CONSTants with literals for improved performance?
Posted: 12:07pm 24 Nov 2025
Kevin
You can use OPTION DEFAULT for your primary variable type and then just type anything else with the appropriate suffix. I would never declare a subroutine using the "as" syntax
  Quote  I haven't seen any mention of it. Could this be used to replace CONSTants with literals for improved performance?
No because is then modifies the source. This is how #define works on the CMM2 because it is totally a disk based system and the user never sees the garbled version that actually runs. The PicoMite is like all other variants where the source is de-tokenised for editing/listing/saving and then tokenised into flash for running. If you then edited a file with #defines they would have disappeared and all the literals would be in the source defeating the object
twofingers
Posted: 12:15pm 26 Nov 2025
Thanks Peter,
I think we get far too few tips like this.
I have a question about the buffer requirements of "Play MP3" (WAV, FLAC): How much free space should be available for the buffer? Is 35KB (heap) enough? I haven't been able to find any information on this.
Michaeol
