Local Time 01:38 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic n selected sub load global array, odd issue data not stored?
Supertech
Posted: 02:41pm 21 Nov 2025
This is the issue. Ive tried this in Geoff MMBasic 5.05.05 and in RP2040 FW 6.00.03 which both does same. Array data in my Condn(n) IS collected and set, however lost as soon as outside "for n = 0 to 15".
Is this an illegal use of a sub or MMBasic limitation?, or something else?
Only happens if "for n = 0 to 15" is used. haven't tried outside a sub, but if in a sub without "for n = 0 to 15", in direct numbered statements, its fine.
OPTION EXPLICIT
OPTION DEFAULT NONE
Const true = 1234 'just make one correct
dim integer Condn(15) 'store 15 (from zero) 'Conditions detected'
print "Simulate array storage issue" : print
ScanCondsim
'Updated 08/11/25.
sub ScanCondsim 'Collect Scan, for latter Display .... Conditions as Status,
local integer n
'Scan, tag condition or cancel dynamic array
for n = 0 to 15
 if n =  0 and true = 9568 then Condn(n) = 1 else Condn(n) = 0
 if n =  1 and true = 1111 then Condn(n) = 1 else Condn(n) = 0
 if n =  2 and true = 4321 then Condn(n) = 1 else Condn(n) = 0
 if n =  3 and true = 1234 then Condn(n) = 1 else Condn(n) = 0 : print n, Condn(3)
 if n =  4 and true = 5684 then Condn(n) = 1 else Condn(n) = 0
 if n =  5 and true = 1540 then Condn(n) = 1 else Condn(n) = 0
 if n =  6 and true = 1346 then Condn(n) = 1 else Condn(n) = 0
 if n =  7 and true = 4852 then Condn(n) = 1 else Condn(n) = 0
 if n =  8 and true = 6784 then Condn(n) = 1 else Condn(n) = 0
 if n =  9 and true = 3468 then Condn(n) = 1 else Condn(n) = 0
 if n = 10 and true = 2675 then Condn(n) = 1 else Condn(n) = 0
 if n = 11 and true = 3457 then Condn(n) = 1 else Condn(n) = 0
 if n = 12 and true = 1986 then Condn(n) = 1 else Condn(n) = 0
 if n = 13 and true = 1234 then Condn(n) = 1 else Condn(n) = 0
 if n = 14 and true = 3465 then Condn(n) = 1 else Condn(n) = 0
 if n = 15 and true = 9999 then Condn(n) = 1 else Condn(n) = 0
next n
print
print "Condn(3) ="Condn(3)", but should be a 1 stored in Condn(3) as Above, but is 0 ?"
end sub
Anybody know why?
Regards, supertech.
Posted: 03:01pm 21 Nov 2025
That can't be the correct statement, what is the real program?
Posted: 03:38pm 21 Nov 2025
Super.
print "Condn(3) =";Condn(3);", but should be a 1 stored in Condn(3) as Above, but is 0 ?"
You need semi colums to separate items in a print statement.
mozzie
Posted: 03:45pm 21 Nov 2025
G'day Supertech,
I spent ages with something similar only to realize that on every iteration of the loop the ELSE statement resets the array elements.
If you set TRUE to 9999 then Condn(15) will = 1 as its the last loop.
Lyle.
Supertech
Posted: 03:52pm 21 Nov 2025
the real bits in my project, substituted as posted renamed to test constant just to illustrate issue of assigned array lost.
OK, A Sample of real, (all 15 work fine, when just number assigned),
here tis,
if (TPbadn > 5 or TP! = 1000) then Condn(3) = 1 else Condn(3) = 0
This one of 15 works fine,
however, I upgraded my sub in this real sample ( 3rd of 15) to,
for n = 0 to 15
...etc
...etc
if n = 3 AND (TPbadn > 5 or TL! = 1000) then Condn(n) = 1 else Condn(n) = 0
...etc
...etc
next n
Should be fine yes?
In fact it dosent seem to matter what they are here * past
"if n = ? and ? then Condn(n) = 1 else Condn(n) = 0", which stores as per print! BUT; ONLY while inside n = 0 to 15 loop in the sub. Once loop n finished, all array of so called stored Condn(n) is lost, or zeroed even before leaving sub!?
I just substituted my data for the 'const true' for showing the issue at hand. I was very supersized when my collected faults vanished due to adding to my real sub the convenience of 'For n = 0 to 15' combined to Condn(n) assignments 1 else 0. Simples.
It just dumps array data or perhaps never stored it?
Posted: 04:02pm 21 Nov 2025
  Supertech said  Anybody know why?
Regards, supertech.
Most of the lines set Condn(n) to 0, not just once but many times.
So, when the line
if n=3 and ...
sets Condn(n) to 1
the next several lines each set it to 0,
I don't know what code you meant but the tests are wrong for whatever you wanted.
To put it another way, each of your elses happens nearly all the time regardless of n.
Summary: MMBasic is working but your code isn't.
BTW your PRINTs ought to have semicolons (or commas) but MMBasic is "lax" in not requiring them.
Edited 2025-11-22 02:07 by JohnS
mozzie
Posted: 04:20pm 21 Nov 2025
G'day Supertech,
Please see my post above.
Pretty sure the last loop with n=15 will set all preceding values of Condn(n) to zero due to the ELSE statement, as "IF N=0.....ELSE Condn(0) = 0" with n=15 is going to trigger the else statement
Also reckon the FOR / NEXT loop is redundant as it will set all the values in a single pass, or is this just for demonstrating the fault?
This assumes I understand the logic correctly
Lyle.
ville56
Posted: 04:27pm 21 Nov 2025
the statement works correctly and does not throw an error, the interpreter is rather relaxed with it.
73 de OE1HGA, Gerald
Supertech
Posted: 04:31pm 21 Nov 2025
  mozzie said  G'day Supertech,
Lyle.
Mozzie, certainly makes sense to me. Thank you.
The why and ways around are more important though. Cant help thinking the ELSE formating might be the answer or even ditch ELSE. I need dynamic results. Ill find another way.
mozzie
Posted: 05:03pm 21 Nov 2025
Supertech,
The following works on MMbasic for DOS, not sure if its the best solution:
If N = 3 then IF true = 1234 then Condn(n) = 1 else Condn(n) = 0
Pretty sure someone here will have a better way if you need to test the value of True depending on the value of N every loop. Select case or choose perhaps?
Hope this helps
Lyle.
Posted: 05:09pm 21 Nov 2025
The reason it fails to do what is wanted is that the else part happens almost all the time for each line.
The code is roughly doing
if (...) else Condn(n)=0
where the (...) part is nearly always false.
Maybe say what you're trying to do as the whole for loop and those elses make no sense.
Edited 2025-11-22 03:11 by JohnS
Posted: 08:44pm 21 Nov 2025
  Quote   those elses make no sense
That is how I see it too.
Start with the array set to 0 (MATH SET first if the array gets used more than once) then use the required logic to set TRUE cells to 1, FALSE cells remain 0.
Edit
If the array is less than 64 cells perhaps you don't need an array at all. FLAG can hold true/false values in an integer.
Edited 2025-11-22 07:20 by phil99
zeitfest
Posted: 09:18pm 21 Nov 2025
( In other systems far far away at least ...    )
the logic clause needs brackets...  otherwise eg in
"if n = 8 ..."
n is set to 0 or 8 etc,  the setting operation  was successful and returns TRUE
so try
"if (n = 8)"...
ed = also i'd avoid using "true" , too similar to system
Edited 2025-11-22 07:27 by zeitfest
Posted: 11:23pm 21 Nov 2025
Removing the elses.
Option EXPLICIT
Option DEFAULT NONE
Const true = 1234 'make one correct
Const true2 = 3465 'make another one correct
Const true3 = 9999 'and another one correct
Dim integer Condn(15) 'store 15 (from zero) 'Conditions detected'
Print "Simulate array storage issue" : Print
ScanCondsim
'Updated 08/11/25.
Sub ScanCondsim 'Collect Scan, for latter Display .... Conditions as Status,
Local integer n
For n = 0 To 15
If (n =  0) And (true = 9568) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  1) And (true = 1111) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  2) And (true = 4321) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  3) And (true = 1234) Then Condn(n) = 1 : Print n, Condn(3)' Else Condn(n) = 0
If (n =  4) And (true = 5684) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  5) And (true = 1540) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  6) And (true = 1346) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  7) And (true = 4852) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  8) And (true = 6784) Then Condn(n) = 1' Else Condn(n) = 0
If (n =  9) And (true = 3468) Then Condn(n) = 1' Else Condn(n) = 0
If (n = 10) And (true = 2675) Then Condn(n) = 1' Else Condn(n) = 0
If (n = 11) And (true = 3457) Then Condn(n) = 1' Else Condn(n) = 0
If (n = 12) And (true = 1986) Then Condn(n) = 1' Else Condn(n) = 0
If (n = 13) And (true = 1234) Then Condn(n) = 1 : Print n, Condn(13)' Else Condn(n) = 0
If (n = 14) And (true2 = 3465) Then Condn(n) = 1 : Print n, Condn(14)' Else Condn(n) = 0
If (n = 15) And (true3 = 9999) Then Condn(n) = 1 : Print n, Condn(15)' Else Condn(n) = 0
Next n
Print
Print "Condn(3) ="Condn(3)", but should be a 1 stored in Condn(3) as Above, but is 0 ?"
Print "Condn(14) ="Condn(14)", but should be a 1 stored in Condn(14) as Above, but is 0 ?"
Print "Condn(15) ="Condn(15)", but should be a 1 stored in Condn(15) as Above, but is 0 ?"
Math V_Print Condn()
Print
> RUN
3       1
13      1
14      1
15      1
Condn(3) = 1, but should be a 1 stored in Condn(3) as Above, but is 0 ?
Condn(14) = 1, but should be a 1 stored in Condn(14) as Above, but is 0 ?
Condn(15) = 1, but should be a 1 stored in Condn(15) as Above, but is 0 ?
0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1
Using FLAG
Option EXPLICIT
Option DEFAULT NONE
'Dim integer
Flags =0 'store 15 (from zero) 'Conditions detected'
ScanCondsim
'Updated 08/11/25.
Local integer n
For n = 0 To 15
If (n =  0) And (true = 9568) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  1) And (true = 1111) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  2) And (true = 4321) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  3) And (true = 1234) Then Flag(n) = 1 : Print n, Flag(3)' Else Condn(n) = 0
If (n =  4) And (true = 5684) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  5) And (true = 1540) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  6) And (true = 1346) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  7) And (true = 4852) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  8) And (true = 6784) Then Flag(n) = 1' Else Condn(n) = 0
If (n =  9) And (true = 3468) Then Flag(n) = 1' Else Condn(n) = 0
If (n = 10) And (true = 2675) Then Flag(n) = 1' Else Condn(n) = 0
If (n = 11) And (true = 3457) Then Flag(n) = 1' Else Condn(n) = 0
If (n = 12) And (true = 1986) Then Flag(n) = 1' Else Condn(n) = 0
If (n = 13) And (true = 1234) Then Flag(n) = 1 : Print n, Flag(13)' Else Condn(n) = 0
If (n = 14) And (true2 = 3465) Then Flag(n) = 1 : Print n, Flag(14)' Else Condn(n) = 0
If (n = 15) And (true3 = 9999) Then Flag(n) = 1 : Print n, Flag(15)' Else Condn(n) = 0
Next n
Print
Print "Condn(3) ="Flag(3)", but should be a 1 stored in Condn(3) as Above, but is 0 ?"
Print "Condn(13) ="Flag(13)", but should be a 1 stored in Condn(3) as Above, but is 0 ?"
Print "Condn(14) ="Flag(14)", but should be a 1 stored in Condn(14) as Above, but is 0 ?"
Print "Condn(15) ="Flag(15)", but should be a 1 stored in Condn(15) as Above, but is 0 ?"
Print :Print Bin$(MM.FLAGS,16)
Print :Print MM.FLAGS
3       1
13      1
14      1
15      1
Condn(13) = 1, but should be a 1 stored in Condn(3) as Above, but is 0 ?
1110000000001000
57352
Edited 2025-11-22 09:49 by phil99
Supertech
Posted: 04:14am 22 Nov 2025
BTW, my last comment on this subject.
The purpose of this array Condn() scan is,
1. Scan live items of change dynamically and add if fail or subtract, each and every one should they occur. Eg Overheating or no longer Overheating. This as Only one of 16, that could be active at any time, all stored ready.
2. With above then referred to CondMsg$() corresponding to appropriate message to suit. In example "Overheating" stored here.
Quite simple.
So Condn() collects 1 or 0, while CondMsg$() displays textual issue if exists. This is also important to be logged efficiently later.
I just wanted to further advance this which revealed the odd issue encountered
Thank you to those that understand objectively. Appreciated.
Regards. Supertech.
Posted: 07:06am 22 Nov 2025
  Quote  Scan live items of change dynamically and add if fail or subtract, each and every one should they occur.
For such repeated operation start the Sub with MATH SET 0, Condn() to clear the array then fill with the new values.
If using the FLAG method start the Sub with FLAGS = 0.
zeitfest
Posted: 08:04am 22 Nov 2025
So is there resolution ? what is it ?
Posted: 08:41am 22 Nov 2025
  Quote  So is there resolution ? what is it ?
The resolution is that the original MMbasic code was incorrect. Every line does a test and if it passes sets condn(n) to 1. All OK so far.
However, the next line fails the test because n doesn't meet its condition. Therefore it immediately sets condn(n) back to zero. Remember, every test is actioned each time through the loop for every value of n
Think about the first two lines with n=0 and true=9568
The first line passes the test and sets condn(0) to 1
Then the second line is run. n is still 0 so it fails the test and actions the else clause setting condn(0) back to 0
It is just incorrect code. If you replace the ifs with a select case on n then you will only action the relevant test for that value of n
select case n
case 0
if true = 9568 Then Condn(n) = 1' Else Condn(n) = 0
case 1
if true = 1111 Then Condn(n) = 1' Else Condn(n) = 0
etc.
end select
Edited 2025-11-22 18:48 by matherp
Posted: 09:34am 22 Nov 2025
You can also use SELECT CASE like this
SELECT value
CASE value <1000 and value >3000
array(1) = 1
CASE value >3000
array(9) = 1
CASE ELSE
anything you like
END SELECT
Posted: 11:03am 22 Nov 2025
For minimum change to the original code I commented out the elses but perhaps should have deleted them to make it more obvious.
Then to make original code work set the array to 0 at the start of the Sub.
OPTION EXPLICIT
OPTION DEFAULT NONE
ScanCondsim
'Updated 08/11/25.
 local integer n
 MATH SET 0, Condn()
 for n = 0 to 15
   if n =  3 and true = 1234 then Condn(n) = 1 : print n, Condn(3)
 next n
 print
end sub
