Local Time 01:52 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Increasing the TX buffer using MMBASIC PICO 2-W web commands
Johnfd
Posted: 06:11am 12 Nov 2025
The manual talks about increasing the TX buffer to allow for many variables being passed to index.html
WEB TRANSMIT PAGE
cb%, filename$ [,buffersize]
I've tried increasing the default in increasing amounts and it doesn't seem to change anything. I still have lost data on web access and at the same place. e.g. WEB TRANSMIT PAGE a%,"index.html",8192
As the variables increase in size information disappears from the bottom of the page. This says insufficient buffer to me.
I appreciate that my variable sizes are less than the content and the manual talks about that. My next step to break up the content into smaller parcels, but the manual says I should be able to  do it by increasing the buffer size.
What am I doing wrong?
Edit: solved by making contents of the variables sent to index.html less than the name of the variable (as in manual). A lot more variables in use now but working smoothly.
Previously I had eight shortish names with a 54 character string in each. I now have 25 variables with max length of 12.
Edited 2025-11-14 09:46 by Johnfd
