Local Time 01:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION FNKey and F5
Frank N. Furter
Posted: 12:54pm 11 Nov 2025
Hi to all,
I stupidly deleted the entry for deleting the monitor with F5. What do I have to enter with FNKey to make it work again?
The manual says:
F5 Sends ESC sequence to clear the VT100 screen. Also clears the console.
Unfortunately, it doesn't say which sequence will be sent...
THANKS!
Frank
Posted: 01:06pm 11 Nov 2025
VT52/VT100/...
ESC[2J erase entire screen
Frank N. Furter
Posted: 01:19pm 11 Nov 2025
But what is the syntax with OPTION FNKey? It worked in the command prompt, but when I try to assign it to a function key, I either get a syntax error or it doesn't work...
Frank
Posted: 02:22pm 11 Nov 2025
Hi Frank
Blindly (did not test):
OPTION F5 chr$(27)+"[2J"
Frank N. Furter
Posted: 07:32pm 11 Nov 2025
Hi Volhout,
unfortunately, I can't try it out today. But I think I already tried your syntax. I think I got an error message saying that [ was not allowed. I'll try again tomorrow...
THANKS!
Frank
Posted: 08:09pm 11 Nov 2025
To reset the function key to it's default setting
OPTION F5 ""
Frank N. Furter
Posted: 08:05am 12 Nov 2025
@Volhout:
Unfortunately, your suggestion just prints [2J on the screen.
> option f5 chr$(27)+"[2J"
> [2J
@TassyJim:
Thank you very much, Jim! Your suggestion with OPTION F5 "" worked. Is that mentioned anywhere in the manual?
Frank
Posted: 10:48am 12 Nov 2025
A search through the R3 manual for OPTION F5 "" came up blank.
Posted: 11:19am 12 Nov 2025
Maybe I am biassed, but..
In MMbasic
a$="Hello" 'assign a value to a$
a$=""       'assign nothing to a$
What does OPTION F5 do..?
OPTION F5 "Hello" 'assign the value "Hello" to function key F5
OPTION F5 ""      'assign nothing to F5
Is this needed to be documented in the manual ?
Posted: 11:46am 12 Nov 2025
On the PicoMite by default (as it used to be anyway):
At the command line F5 does nothing
In the editor F5 pastes the text previously selected using F4
Whereabouts in the manual is this?
"The manual says:
F5 Sends ESC sequence to clear the VT100 screen. Also clears the console."
Is it even for the PicoMite? :)
disco4now
Posted: 12:01pm 12 Nov 2025
Shortcut Keys (page 15)
The function keys on the keyboard used for the console can be used at the command prompt to automatically
enter common commands. These function keys will insert the text followed by the Enter key so that the
command is immediately executed:
F2 RUN
F3 LIST
F4 EDIT
F5 Sends ESC sequence to clear the VT100 screen. Also clears the console.(Unless it has been programmed with custom text)
F10 AUTOSAVE
F11 XMODEM RECEIVE
F12 XMODEM SEND
Function keys F1, and F5 to F9 can be programmed with custom text. See the OPTION FNKey command
The red could be added, but is it implied anyway?. It can't do two things at once. It is in the Picomites.
F4 H7FotSF4xGT
Posted: 12:12pm 12 Nov 2025
Ah - F5 has been added since my old printed manual.  :)
I keep intending to print a new one but I don't get round to it...
Frank N. Furter
Posted: 06:08pm 12 Nov 2025
It would be great if this also worked with CLS on the console...
Frank
Posted: 07:15pm 12 Nov 2025
ou have to remember what the console is intended for. It's not supposed to be a general purpose display, it's a diagnostic and maintenance tool. The chances are that you don't want cls to keep wiping out the diagnostic info that you are displaying in real time while a program is running. :)
Frank N. Furter
Posted: 07:28pm 12 Nov 2025
Yes, but that's exactly why it would be good! It quickly becomes confusing if you can't clear the screen from time to time...
Frank
Posted: 07:44pm 12 Nov 2025
That's what F5 is for....  :)
No, I don't think I'd like the diagnostic stuff deleted by the program. If I wanted that I'd display it on the display screen, not the console. You can make it less confusing by using PRINT@ to put bits of info where you want them on the console rather than just all over the place.
Posted: 08:13pm 12 Nov 2025
Manual for V6.00.03 is the first one I looked at.
Under OPTIONS:
  Quote  OPTION FNKey string$
I tried a couple of things before I found using a blank string did the trick.
It wasn't difficult and didn't need the help of AI
Posted: 08:25pm 12 Nov 2025
What isn't obvious from the manual is that an empty string not only removes the current function but restores the original function.
I think that is worth a mention in the manual.
Posted: 08:28pm 12 Nov 2025
How would you set a Fn key not to send anything?
Posted: 08:53pm 12 Nov 2025
Presumably you can set F6 to F9 to nothing as they don't have an original function.
Define the string that will be generated when a function key is pressed at the command prompt.
‘FNKey’ can be F1, and F5 thru to F9.
Example:
OPTION F8 “RUN “+chr$(34)+”myprog” +chr$(34)+chr$(13)+chr$(10).
This command must be run at the command prompt (not in a program).
Edited 2025-11-13 06:59 by phil99
