Local Time 01:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM EDIT Print out
EXAL81
Posted: 12:20pm 09 Nov 2025
Hello,
I have made a few changes to my PICOMITE firmware using MM EDIT and want to just print a few pages.
In the print menu, I select the "customised range" option and set the range of pages; for example, 9-12 , but the program takes no notice of this and starts to print the whole document.
Any know how to get this to work properly ?
Posted: 07:37pm 09 Nov 2025
You didn't say what OS you are running but either way, the best way is to save as RTF and use your word processor to manipulate the output.
EXAL81
Posted: 04:34pm 10 Nov 2025
Thanks for help Jim.
I am running widows 11.
I have now discovered that I can save as PDF and use the PDFgear program, which allows me to print the source code just as it appears on the MMEDIT display (including the coloured items) !
Alan
