Local Time 01:51 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Firmware v6 - Fishiness?
vegipete
Posted: 11:03pm 08 Nov 2025
Something odd is happening with a CMM2 G2 that I'm testing. Firmware version 6 seems to be misbehaving with some simple commands.
480MHz Colour Maximite 2 G2
MMBasic Version 6.00.00b4
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
> USB Keyboard Connected OK
> ? mm.info(version)
6
> ? hex$(255)
HEX is not declared
> ? bin$(255)
BIN is not declared
Compare with older firmware: (same hardware)
MMBasic Version 5.07.02b11
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> ? mm.info(version)
5.0702
> ? hex$(255)
FF
> ? bin$(255)
11111111
Posted: 05:23am 09 Nov 2025
I wonder if in v6, Peter got rid of the HEX$ and BIN$ functions?
Can you find them listed in the functions area of the v6 manual?
disco4now
Posted: 05:33am 09 Nov 2025
Peter has given me the CMM2 firmware to look after.
I have been working on beta5, mostly finishing the porting of new featues from the Picomites.
I will add what I currently have to the 6.00.00 Betas thread.
The Hex$,Bin$ issue I had already seen and fixed. MM.info(VERSION) is now fixed as well.
Gerry
F4 H7FotSF4xGT
Posted: 07:20am 09 Nov 2025
