Forum Index : Microcontroller and PC projects : pushsafer
venatici
Posted: 07:29pm 01 Nov 2025
hello ,
I am trying to send a notification using pushsafer api without success .
I am using webmite on pico2 .
Have anyone done this before ?
Pushsafer requires an post method request with the message.
Thank you in advance.
Posted: 11:01am 03 Nov 2025
Maybe post a short sample.
venatici
Posted: 08:09pm 03 Nov 2025
here is my code
Option escape
' === Setup WiFi ===
Do While MM.Info(IP ADDRESS) = "0.0.0.0"
If Timer >5000 Then CPU RESTART
' === Set the API endpoint ===
url$ = "www.pushsafer.com/api"
port% = 80                          ' for HTTP; if HTTPS is supported youll need different handling
path$ = "/api"   ' the API path
eol$=Chr$(10)+Chr$(13)
' === Build the POST data ===
privateKey$ = "mysecretkey"
title$      = "Alert"
message$    = "notification"
dev$     = "a"   ' a means all devices or specify a device id/group
Dat$ = "k=" + privateKey$ + "&t=" + title$ +  "&m=" + message$ +   "&d=" + dev$
' === Build the HTTP request ===
req$="POST"+path$+ " HTTP/1.1"+eol$+"Host: " + url$+eol$
req$=req$+"Content-Type:application/x-www-form-urlencoded" +eol$
req$=req$+"Content-Length: "+Str$(Len(dat$))+eol$+"Connection:Keep-Alive"
req$=req$ +eol$ + Dat$+eol$
Print req$
Dim buff%(1000)
' === Open TCP connection ===
Print "--"
  WEB OPEN TCP CLIENT "www.pushsafer.com/api",80
WEB tcp client request req$,buff%()
LongString print buff%()
' === Close connection ===
WEB CLOSE tcp client
i think the problem is in
web open tcp client "www.pushsafer.com/api"
the / return an error.
Edited 2025-11-04 06:09 by venatici
